#4532 |
It is my understanding that 89 240s didn't come with consult port. I've been researching BLAZT and other datascan programs. The all describe the cable being on the driver side near the fuse box under the steering area. I found this. What is this?
#4534 |
That's what I was thinking. I mean it certainly looks like it and I've google image searched and when I put in "nissan 240sx obd1 connector" a similar pic comes up. Hmmmmm... maybe my car is a 90 and not an 89 as I thought.
#4536 |
wonder if 17x9 +17 up front 18x9.5 +12 in rear will fit with just a roll. i dont want to rent a fender roller and end up needing to take it to the shop for a pull. Oh this is an s13 also. Thanks.
#4540 |
s13 driver side motor mount. The motor can't go up much more without crushing the seam on the fire wall (don't want that) and without my car getting off the jacks more. I can't get the motor mount off cause its such an awkward angle that i cant spin it or slide it since it hits the steering or the power steering pump.
How do most people get that shit off? The bolt is off the engine side, but i cant get it to come off the chassis side. Passenger side was a breeze
street dancer. GLEAM |
#4541 |
no i was asking if i can use the z32 axles with the vlsd on my s13 i know that the diff fits with some changes but not shure about the 5 bolt axles cause many ppl say you can and others say you could not but in my case im using the upright so not shure if the axles will fit.
#4543 | ||
![]() Join Date: Dec 2003
I usually take the bolts off the bottom first and pull the motor mounts with the engine. Quote:
SO your not sure if your z32 axles will fit in your z32 uprights while connected to your z32 diff? Your losing me kid. More/cleaner exhaust flow is always good on a turbo. Assuming your talking about an aftermarket replacement elbow.
![]() **CoUpe LOve** Member #00 |
#4547 | ||
Check RimTuck.com for references offset looks good to me, but you're gonna need to stretch the tires some. 225/245 maybe? Quote:
Also, try twisting it.
'89 Sil80, SR20DET, GT2871r .64 |
#4549 |
i couldn't pull the engine, otherwise i woulda done that. In my frustration i over looked the bolts on the engine mount that connect the engine to the mount bracket.. i got that shit off in 10 minutes lol. I spend like 1 hour and bent the shit out of some screw drivers trying to pry it off
#4550 |
![]() Join Date: Dec 2010
ok, zilvia search function isnt working again and i need to guy buy this so i can change some axles out
QUESTION: What size 12 point socket do i need to remove rear drive axle nuts from the axles in the hubs of my s13? is it a 42mm? thx |
#4552 |
#4554 | |
When i did mine, i jacked it up, removed the wheel and all that, then put wheel back on and set it on the ground without center caps on. Slip the socket on like that then do it cause the ebrake might not grip enough without being on the floor.
#4556 |
#4557 |
under the stock oil sensor there was a little allen-screw plug like the ones on sandwich plates/relocators.
Can i use this as a sensor tap or is it for something else?
#4559 |
i have a hicas with abs. i had to change out a spindle and the replacement didnt have the fitting for the abs sensor. it wont be up for a while so im wondering if ill have any problems with the brakes once i start driving it? lol i have no idea.
