02-16-2011, 12:39 PM | #1 |
s14 sr20det problems
so i was running stock everything with exhaust, and FMIC, at 12.5psi. i had my safc tuned and made 292rwhp 316rwtq on a mustang dyno. my turbo blew a couple of weeks later, i swapped it out with a gt2860rs and put on an RYO bottom mount manifold with stainless steel lines. the turbo had roughly 5000 miles when i bought it. my car ran sweet for a couple of days, and then i started to realize i wasnt feeling the turbo at all till 4000rpm (i had been feeling it at full boost around 3.5k). i did a compression test and i had 120s across the board. i had been losing coolant, and my engine overheated but i didnt drive it when it was overheated, i put in a new thermostat, filled up the coolant, and its been fine since. i havnt lost anymore coolant. i have no smoke coming from my exhaust, my oil is normal, no bubbles in my radiator. any thoughts???
02-16-2011, 02:25 PM | #2 |
Compression numbers are pretty low, retest the compression and hold the throttle all the way open, also if you're oil gets really black before 2K miles, you definately have some blow by. Might need to rering engine if compression test is low. Also compression being low would also affect how quickly a turbo spools for sure. I say do a retest and post pics of your spark plugs all in order. But 155Psi is a healthy SR, anything below 125Pis is considered needing a rebuild or do a leak down test and see where the Psi is escaping from, sometimes its just valves that aren't seating well due to carbon buildup.
02-19-2011, 08:21 PM | #4 |
Might just be valves not seating. An Sr20DET longblock (no manifolds or turbo) costs around $900-1000 nowadays from an importer. Might want to go that route since you have everything else.
02-19-2011, 10:58 PM | #5 |
or you have a boost leak. You might have damaged the engine if the tune is bad, did you not upgrade the injectors when it went over the 250rwhp mark? And what is controlling them? and 320 horsepower on an s14 t-28 is unbelievable, not to mention its a mustang dyno.
02-20-2011, 12:43 AM | #6 | |
-3" exhaust -apexi neosafc -hks evc boost controller and then i put on an RYO manifold and gt2860rs turbo and everything ran amazing for a few days and then went downhill
02-20-2011, 12:44 AM | #7 | |
this is what im thinking. what sites are reliable that i can find a long block on?
02-20-2011, 01:34 AM | #8 |
Wow so your boosting that engine with a bigger turbo on a stock fuel system (370cc injectors) thats dumb,
Your maxing out your injectors and running lean. On a stock 370cc Injectors a T28 with max them shits out in no time above 10psi. im surprised that engine hasnt grenaded yet, I have a dyno chart around here showing the AFR's on my SR with a T28 on stock fuel injectors. Sure you might be able to cheat a little by bumping up the Fuel pressure and running a garbage ass SAFC but I'll guarantee you that engine wont last long. As you can see its starting to show
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
