#31 |
![]() Join Date: Dec 2006
i like these... they visually look the same as PBM, but judging by the reviews, they sound like a much more street friendly version. So thats really cool.
Wouldn't mind trying these in hte future, but for now my PBM's will suffice
#33 | |
basically a set of guidelines that describe a company's quality management system current version is ISO 9001:2008 it's funny to me that it's being used here as a feature to add value to a budget coilover is all Last edited by ManoNegra; 10-14-2009 at 01:29 PM.. |
#36 |
![]() Join Date: Jul 2005
The collars just twist off. You just unscrew the lower bracket and unscrew two of the collars, then twist the bracket back on and twist the two collars back on so you still have something to lock against the bracket. They are just below the bracket instead of on top of it.
You'll have to pick between a 215/45, 225/45, and 235/40 because finding a 225/40/17 will not be cost effective. Either way, you should be able to go low enough without removing the collars with a 215/45 and 8k springs, the 9k springs are a little longer so you may have to remove the collars.
![]() Instagram - SJKnoop |
#37 | |
I'd like to see a shock dyno please of these! And do you have z32 rear lower mounts optional for those of us using the aluminum uprights from the tt? |
#39 |
Yes, they have Z32 lower mounts. I just converted the rears on my car.
The shock dyno is at the bottom of the page: Fortune Auto USA. Home of 50mm Performance Coilovers, Titanium Shift Knobs & Titanium Lug nuts - Fortune 500 series coilovers
#40 | |
I have never owned coilovers before so I didnt know.
#41 | |
We are also s-chassis enthusiasts, so we keep you guys in mind with what we have on hand!
#42 |
it says that fortune auto basically copied the technology of making coilovers from japan. So how would these be compared to the Japanese coilovers like Tein? They are similarly priced after all
#44 |
![]() Join Date: Nov 2006
I have these on my S13 and i absolutely love them. On the softest setting they're about one step up from lowering springs.
Its like the jump from stock suspension to lowering springs, you notice the 'stiffness' but its really not that bad. I have mine at about 5 clicks for daily, and it handles bumps really well. I was going to go with stance, but for the $200 or so more you'd have to spend, i highly doubt they could be any better than these. Well, in my opinion, id rather have the $200 in my pocket, since i dont think there could be much better coilovers for the money lol. HIGHLY recommend these to others. I've ridden on D2's, Megans, and BC's, and i must say i like these the most. If you're looking to go HELLA low, i MIGHT pass, as i had to flip the bracket as well as remove all collars to get to this height. ![]() not toooo big of a deal. crossmember to ground is about 3 fingers i think? dont know how much lower you really want to go lol. |
#45 |
I daily on these as well, I think I have em 3 clicks up all around and they are slightly better than my old lowering spring combo.
I'm on 7k/6k springs and it's only slightly uncomfortable on the really whacky bumps or potholes, other than that it's fine. At my current height, in the front I still have about 1cm left before I have to remove a collar, and the rear I can drop it down another 3 or 4 inches. ![]() |
#46 |
![]() Join Date: Aug 2006
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Thats good to hear. Thanks for the review. I was also impressed with their race version which I didnt know about:
Fortune Titan Coilovers - Fortune Auto USA. Home of 50mm Performance Coilovers, Titanium Shift Knobs & Titanium Lug nuts ![]() I just thought they were another showy super low coilover company.
Sold the Z, sold the S14, now I drive a G35 6MT coupe. |
#47 |
#48 | |
They work flawless on the street. Finish looks brand new still, great company, warranty, rebuildable. The unit is beefier then Ksport as well. I bought these for reliability and durability, not necessarily for the best performance, so far they are living up to my expectations. |
#51 |
I thought I'd give this a little bit of an update. I recently took my shocks up to Fortune to get them rebuilt for some Swift springs. I went from a 9k/7k set up to a 10k/9k set up. I haven't been able to drive on them yet, I just got them on the car tonight and its raining until Saturday.
As you can see the front swift springs are 1" shorter then my old ones: ![]() ![]() The car on the ground: ![]() If you were running anything other then OEM aero this height just wouldn't be possible. I can't even get my finger under the lowest parts of the side skirt: ![]() As you can see the front fender (which has been flared and therefore the edge of it is up higher then a stock fender) is ~22.5" off the ground. The Fender is resting right on the tire at this point. ![]() A side shot: ![]() If you had a stock fender beam the tire would be resting on it for sure. I have about 1-1.5" of clearance and I have shortened mine by ~2". Here's my shock dyno, it got a little damaged in shipping, but you can clearly see the digressive compression curve on the top part of the dyno - this is something no other coilovers have in this price range. ![]() Terry at Fortune made a video of the rebuild process, and outlined what they do and why its so special: I will be sure to update the thread with my thoughts on the springs/rebuild after I drive on them.
![]() Instagram - SJKnoop Last edited by 95KA-Turbo; 02-25-2011 at 08:49 AM.. |
#53 |
I'm not trying to starting anything, but you don't see stance posting pictures of the internals of their coils or shock dynos. I had talked with stance a while back about revalving shocks and they were great with communicating with me, that is until I said I would want a shock dyno for each shock when they were done. They literally never responded to me again. This leaves me to believe they were going to tell me they did something and then not do it - ie rip me off.
#55 |
Got my fortunes the other day, put them on (on one corner) and found out that my weak ass FWD wheels (getting better wheels come summer) rub a litte bit (these coils are a LOT beefier than they look in pictures!) so i have to get a 5mm spacer.
Also i have to call fortune today and figure out whats wrong with my set. 3 out of 4 of the adjustment knobs refuse to turn. I tried using as much force as possible (like opening a brand-new ragu bottle without hitting the bottom of the glass) and they managed to turn barely 1/4 turn in either direction. The one working coilover turns without a problem and clicks and everything. |
#56 | ||
#57 |
If you they are calling their shocks digressive because of the compression curve than almost all coilovers in this price range are digressive. If you compare this to a megan dyno, its the same valving, megan's look more digressive. if anything it's got less rebound force and less adjustment range than megan's. better off buying megans if you want something cheap.
megan has 600lbs at 10secs , fortune has 400lbs at 10secs. |
#58 |
Am I missing something? Those shock dynos aren't even kind of the same.
The shock dyno you posted shows a nearly linear compression curve and an almost flat rebound - like the rebound is basically constantly at 100-200 ish.
#59 |
haha. its same. your dyno is flipped. the compression is on the bottom on megan. look at your dyno, your compression barely passes 100.
fortune auto, s14 |
