03-09-2011, 12:29 AM | #1 |
s14 zenki slammed flush canibeat featured
okay so im getting out the import scene so im selling my car i have been building for over 2 years now
alot of people can vouch for this car im selling the car for 11,500 but very negotiable 95 240sx non se 5 speed with 155xxx on it motor cp pistons .20 over 9-1 eagle rods arp main and head studs and rod bolts new nissan oem water pump oil pump timing chains guides thermostat valve cover gasket oil pan gasket block was honed to .20 over and both head and block were decked for perfect seal felpro head gasket rebuilt stock head new felrpo valves seals ect s13 cams and head with s14 block s14 tranny with short shifter spec stage 3 clutch engine harness with injector clips z32 maf and resitors pbm mid mount intercooler misimoto rad aspec burnt tip left staggered 3 inch exasut with dyno max race bullet muffler turbo turbonetics .50 63 t/3 t/4 ceramic coated tgs manifold cermamic coasted tial wastegate 38mm with 4- 8-10 psi springs jim wolf fuel rail prescion 75lb injectors only used for 3 hours enapthly rom ecu setup for this setup needs a couple dyno pulls for perfection cx racing modified down pipe perfect fit suspension stance gr+ pro circuit sports tie rods tensions rods traction rods toe rods rucas welded diff megan tie rod boots extrior kouki skirts greddy lip (broken but stictched ) circuit sport headlight covers 8000k high beams 6500k low beams clear signal very clean zenki tails with led bulbs agency stuby antenna fiber glass roof wing and pbm hood risers interior sparco 350mm 34t i think wheels circuit sports short hub circuit sports q/r carbon dash bevel glow shift oil pressure water temp boost guages aem wideband blue checkered floor mats pbm hyrdo with lines brakes fresh rebuilt z32 front calipers agency lines hawk pads circuit sports cross driller rotors all around wheels setup rpf1 10.5 all around sbc 225-40-18 front tires 265-35 -18 rear tires ik im forgeting a bunch of stuff pics are from a few months ago the only difference now is the lip has been cracked and zip tied A True Flo-Rida | Canibeat
http://strictlycoolstuff.tumblr.com/ Last edited by s14fbs; 03-10-2011 at 06:08 PM.. |
03-09-2011, 12:01 PM | #9 |
http://strictlycoolstuff.tumblr.com/ |
03-10-2011, 03:06 PM | #14 |
Damn another Zenki going bye bye.
GLWS.
http://www.tarmac-spl.blogspot.com/ |
03-10-2011, 04:27 PM | #15 |
thanks for the kind words guys
i would love to keep the car but i started racing mx again and i need a small truck to get shit around with and the car just sits and i could really use the money right now not having a job
03-10-2011, 04:51 PM | #16 |
wow i hate to see this thing go but it is LEGIT AS FUCK
this car will make you cool, o you get the ladies trust me.
@UpshiftEngineering |
03-10-2011, 04:59 PM | #17 |
hellaflush gets all the bitches lmfao
03-10-2011, 06:07 PM | #19 |
typo ill fix it right now i had the fronts and back swapped
03-11-2011, 11:06 AM | #23 |
thanks for the offer but im looking to build or buy a v6 ranger long travel dessert truck
03-12-2011, 04:56 PM | #26 |
9500$ come get it i found what I want next need cash
03-12-2011, 08:49 PM | #28 |
i never drive the car thats why u probally have never seen it lol
