Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Electronics
Old 01-20-2011, 03:22 PM   #1
Chase Bays
Chase Bays's Avatar
Chase Bays is an unknown quantity at this point
Chase Bays S13 SR20DET and S13 KA24DE Engine Harnesses Available Now!!
Finally complete!
Chase Bays S13 SR20DET Engine Harness
Chase Bays S13 KA24DE Engine Harness
A few things to note on the harnesses...
SR20DET- We have integrated the upper and lower harnesses together to keep things clean and simple. The engine to chassis plugs are long enough to reach where they need to go whether you have stock fusebox location or relocated. We put the Coil Igniter plugs inside the car near the ECU/ECCS. This helps clean up the engine bay of course. MAF or MAP plug, we have a 3 pin deutsch connector coming out at the first junction. The reason we did this is since we all know there is plenty of MAF or MAP styles and locations we let you customize where it is and how it routes. The harness routes similar to the KA harness since they're just about the same thing, under the intake manifold.
KA24DE- We have integrated the upper and lower harnesses together to keep things clean and simple. The engine to chassis plugs are long enough to reach where they need to go whether you have stock fusebox location or relocated. The harness routes underneath the intake manifold instead of over the top, significantly cleaning the motor up.
For KA we would like to offer you the choice of S13 or S14 distributor/coil setup. Still working on that however.
Pictures are kind of blurry, sorry.
S14 motor and chassis harnesses coming ASAP. We also offer a RACE/Stand Alone style harness that has fuel, ignition, starter relays integrated and flying leads for you to connect yourself.
Please ask any questions on this thread instead of PM so we can answer them and throw the Q&A on our website. Thanks for reading!
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE
www.ChaseBays.com | [email protected] | (205)623-2188
Chase Bays is offline
Old 01-20-2011, 03:47 PM   #2
rootS13
rootS13 is an unknown quantity at this point
Im curious about the price for a S13 ka setup. Thanks.
rootS13 is offline
Old 01-20-2011, 03:55 PM   #3
Chase Bays
Chase Bays's Avatar
Its posted on the site... $549
Old 01-20-2011, 04:49 PM   #4
genericforumname
Location: Florida, where we prove that shit does in fact run down hill
genericforumname is making a name for him/her selfgenericforumname is making a name for him/her self
any chance for s14 sr?
genericforumname is offline
Old 01-20-2011, 06:02 PM   #5
k0013
k0013's Avatar
k0013 is an unknown quantity at this point
if we are doing a VH45 swap into the S14 how would we go about that. would we send you our harness once we sort out what goes where then let you do your magic to clean it up?
k0013 is offline
Old 01-20-2011, 06:09 PM   #6
zoomswimmer
zoomswimmer is making his/her stupidity well-knownzoomswimmer is making his/her stupidity well-knownzoomswimmer is making his/her stupidity well-known
On the site, it says you need the stock harness. How much more if you provide it? Also, with the CM1, how much more for the starter and alternator wires?
zoomswimmer is offline
Old 01-20-2011, 06:22 PM   #7
Pure_JDM
Pure_JDM is an unknown quantity at this point
So fresh and so clean clean.
Pure_JDM is offline
Old 01-20-2011, 07:55 PM   #8
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
what is CM1, CM2, or CM Mil Spec?
CM1 harness – The CM1 harness features all new commercial grade, high heat, thin jacketing wire (rated from -49° to +257° F), individually striped for easy identification and all new sensor plug pins. It is covered in full flame retardant nylon sleeving (Operating Temperature Range -103° to 257°F; Melt temp 446°F), and adhesive lined heat shrink. All engine harnesses go directly to the ECU clips, and include all the needed wiring and plugs to make the harness plug and play to your vehicle. The harness is built with aesthetics and functionality in mind. Our harnesses have had a lot of R&D done for proper wiring technique, with all shielded wire used where needed. It features a stealthy look but is also easily accessed, keeping the motor easily worked on. This harness is great for someone looking to clean up their engine bay and replace the used and worn down stock harness.
CM2 harness – The CM2 harness features all the same great aspects and design of the CM1 harness but adds a Mil Spec quick disconnect firewall connector and Raychem connector boot. All CM2 harnesses are designed to mount to the OEM harness entry hole or former AC oval hole (if AC is eliminated) It also includes a complete new custom charge harness (for Alternator and Starter power wires). This harness is perfect for someone who wants the option of very easily removing/disconnecting the engine harness. Not to mention a very shiny firewall connector
CM Mil Spec harness – The Mil Spec harness features; All new sensor plug pins, all new thin jacketing wire (rated from -49° to +257° F), Raychem DR-25 heat shrink (operating temp. -103° to +347° F), adhesive lined heat shrink junctions, Raychem break-outs/junctions where needed, Yellow sensor labeling, and Mil Spec quick disconnect connector w/ Raychem shrink boot. The harnesses go directly to the ECU clips, and include all the needed wiring and plugs to make the harness plug and play to your vehicle. The harness is built with aesthetics and functionality in mind.Our harnesses have had a lot of R&D done for proper wiring technique, with all shielded wire used where needed.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline
Old 01-20-2011, 08:43 PM   #9
LOUD240
LOUD240's Avatar
LOUD240 is an unknown quantity at this point
please do this for the SOHC ka !!
LOUD240 is offline
Old 01-21-2011, 04:27 AM   #10
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
I’ve taken care of most of the major stuff for my car except wiring, due to the fact I know nothing about it. Can Chase bay offer a wiring harness for just the bare essential for operating the car. My car is not a daily driver and is no longer registered. I would like a simple harness to control basic functions of the car i.e. turn signals, headlights, wipers, and anything needed to get it on the track, in conjuction with your stand alone harness for the engine.
lewisfk is offline
Old 01-21-2011, 05:53 AM   #11
Chase Bays
Chase Bays's Avatar
We would need a motor since we change the routing so much. We are in Birmingham, AL would you be able to bring us a motor?
We would have to buy one, so whatever it costs us. $100+
The charging harness is included and I forgot to mention that, editing the site as well as adding some pictures of the charge harness.
Its our model names for different options and features. If you read the descriptions you can see what are the specific differences
Thats funny you ask!
http://zilvia.net/f/advertiser-annou...harnesses.html
Old 01-21-2011, 07:00 AM   #12
BoostinIX
BoostinIX's Avatar
Trader Rating: (29)
BoostinIX is an unknown quantity at this point
Feedback Score: 29 reviews
Send a message via ICQ to BoostinIX Send a message via AIM to BoostinIX Send a message via MSN to BoostinIX Send a message via Yahoo to BoostinIX
/patiently waits for awesome S14 SR Harness :P
Keep up the great work!!!
BoostinIX is offline
Old 01-21-2011, 09:25 AM   #13
airhead
airhead's Avatar
Trader Rating: (32)
airhead is making a name for him/her selfairhead is making a name for him/her selfairhead is making a name for him/her self
Feedback Score: 32 reviews
GOOD stuff. Wish i can afford this
airhead is offline
Old 01-21-2011, 09:58 AM   #14
Mr.ny 240!!
Mr.ny 240!!'s Avatar
Mr.ny 240!! is an unknown quantity at this point
those are some fresh harnesses!!
Mr.ny 240!! is offline
Old 01-27-2011, 04:18 PM   #15
Chase Bays
Chase Bays's Avatar
Thanks guys!
Old 01-29-2011, 10:39 AM   #16
casten01
casten01's Avatar
casten01 is an unknown quantity at this point
when do you guys think you'll come out with a S14 SR harness???
casten01 is offline
Old 01-29-2011, 01:27 PM   #17
revcyanide
revcyanide's Avatar
revcyanide is an unknown quantity at this point
this!
length
Originally Posted by Blackzenki82 View Post
bring da ruckus to dat ass with the braaaaaaaaaassssssssssssshhhhhhhhhhh
revcyanide is offline
Old 02-02-2011, 12:08 PM   #18
jonski coupe
jonski coupe is an unknown quantity at this point
any chance for '96 S14 Zenki with Kouki blacktop motor harness?
jonski coupe is offline
Old 02-07-2011, 07:03 AM   #19
Chase Bays
Chase Bays's Avatar
S14 stuff is coming very soon!
Old 02-07-2011, 07:49 AM   #20
NismoDriverS13
NismoDriverS13 is an unknown quantity at this point
dude, that is the sh*t!!! buying one soon, must save now!
NismoDriverS13 is offline
Old 02-09-2011, 09:13 AM   #21
Memberofthe600hpkaclub
Memberofthe600hpkaclub's Avatar
Memberofthe600hpkaclub is an unknown quantity at this point
Man, need this for a s14 with a ka
Memberofthe600hpkaclub is offline
Old 02-10-2011, 11:44 AM   #22
Chase Bays
Chase Bays's Avatar
Thanks guys. S14 stuff releases February 21st
Old 02-10-2011, 11:50 AM   #23
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
Will the SR harness work on RHD vehicles?
Driftphreak87
Okinawandrifter87 is offline
Old 02-10-2011, 12:39 PM   #24
casten01
casten01's Avatar
i cant wait!!!!
casten01 is offline
Old 02-14-2011, 02:15 PM   #25
Chase Bays
Chase Bays's Avatar
Yes. From where all the looms come into 1 we've made it about 6 feet. Which is plenty enough to run to the other side. The pictured length is about 4 feet, our production model is 6 feet.
Old 02-26-2011, 08:25 AM   #26
casten01
casten01's Avatar
Any update on the S14 harrness? Went searching on ur guys website and on here and havent seen anything yet? You guys posted aboout releasing s14 stuff on the 21s of Feb...?
casten01 is offline
Old 03-24-2011, 09:00 AM   #27
kingston240
kingston240's Avatar
kingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond repute
I also would like s14 with s14SR harness.
If i supply you with one that is complete, but the wiring has been hacked up... is that a problem?
www.facebook.com/HellaFab
kingston240 is offline
Old 03-24-2011, 10:47 AM   #28
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
Will you need our wiring harness has a Core? or is this a custom 1 off setup?
im considering one for a 1993 240sx (KA24DE)
also does it mater if its for a auto?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline
Old 03-28-2011, 06:02 PM   #29
Chase Bays
Chase Bays's Avatar
Its okay if wiring is hacked we just use plugs so yes we need the core.
S14 is still pending, sorry! Coming asap.
We dont make harnesses for automatic
Old 03-29-2011, 11:02 PM   #30
hardtime21
hardtime21 is an unknown quantity at this point
F$&@ Yeah! Finally an S14 KA Harness! Outside of me, how many others been on you guys for this? You don't have to answer! Just keep me posted!
hardtime21 is offline
