Old 05-08-2011, 06:10 PM   #4471
Razi
Razi is an unknown quantity at this point
Lookin good Josh!
Razi is offline   Reply With Quote
Old 05-08-2011, 06:10 PM   #4472
nathanong87
nathanong87's Avatar
crank dat camber
natelife.tumblr.com
Old 05-08-2011, 06:15 PM   #4473
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
im at probably -3 up front with a 225/40/18 i can still go waaay more negative but i like the fitment right now lol i have about a finger width of space between teh fender and the tire
spooled240 is online now   Reply With Quote
Old 05-08-2011, 06:18 PM   #4474
lflkajfj12123
max camber to -4.5 and throw a spacer on
rubbing goes away and increase style points
win win
Old 05-08-2011, 07:31 PM   #4475
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
Waaaaaaaat? What size are those wheels? I don't see how you could be rubbing with a 225/40.
I was running 17X10 +7 with 245/40s and it only barely rubbed at full lock.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 05-08-2011, 08:12 PM   #4476
spooled240
spooled240's Avatar
18x10 +10 (effective with 8mm spacer to clear coils) how much camber were you running?
Old 05-08-2011, 08:20 PM   #4477
lflkajfj12123
when is it rubbing? straight line under articulation or turning the wheel
maybe just need to run the front dampers stiffer
Old 05-08-2011, 08:33 PM   #4478
spooled240
spooled240's Avatar
it rubs when I'm pulling into parking spots, making u-turns..it's not too bad just annoying...when I take turns pretty hard it will rub pretty good and smell like I was drifting haha
Old 05-08-2011, 08:35 PM   #4479
icedsole
icedsole's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
if its not messing up the fender your probably running on the chassis beam or inner fender.
@pwrmves14
Old 05-08-2011, 08:38 PM   #4480
lflkajfj12123
which means you should add a larger spacer
if it rubs fender then add camber
Old 05-08-2011, 09:03 PM   #4481
spooled240
spooled240's Avatar
pretty sure it's the actual fender since there's paint missing and rub marks on the sidewall lol i might just add more camber and see how that works
Old 05-08-2011, 09:05 PM   #4482
harangatang
harangatang's Avatar
harangatang can only hope to improve
I rub in the front doing anything but going down a level, straight road lol. And I'm on 225/40's. -2 camber. 18x10 et+9
Got my kit, oem VIS hood, headlights, turn signals, and jdm grill. I'm STILL trying to find some decent oem fenders and crystal corners. Anyone have some??
^^^, also, adding more camber makes your car lower.... so it may or may not fix the rubbing issue. Might have to raise the car a tad too..?
Tyler
harangatang is offline   Reply With Quote
Old 05-08-2011, 09:16 PM   #4483
hellion240sx
hellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enough
Originally Posted by NissanEnthus View Post
......Really??
yea i think i am thinking of the type x bumper... thoght it was something like these.
Originally Posted by spooled240 View Post
matt is 95_s14 with the EDM rear and navan SS
s14_kouki better, but not low enough haha
got it thanks.
Originally Posted by 95KA-Turbo View Post
The wheels look great, it doesn't matter who makes them. If I remember correctly he has knock off aero and a D-Max hood......so he has nice brakes, lol. The car looks completely amazing, I could care less what brand is stamped on his parts.
ditto.
As long as it looks good or is functional to its purpose its good with me! xxr, rota, megan, isis, "custom", circuit sports, whateves.
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE!
240 addict miata addict
hellion240sx is offline   Reply With Quote
Old 05-08-2011, 09:22 PM   #4484
CMFD13coupe
CMFD13coupe is an unknown quantity at this point
CMFD13coupe is offline   Reply With Quote
Old 05-08-2011, 10:46 PM   #4485
lflkajfj12123
if he's rubbing on the fender then adding camber will fix it
lowering isn't going to make it worse plus it will look cooler
when it comes to rubbing s14's are a dream compared to s13
Old 05-08-2011, 11:29 PM   #4486
95KA-Turbo
95KA-Turbo's Avatar
I believe my front camber maxes out around -2.8 with the caster I have.
Instagram - SJKnoop
Old 05-09-2011, 12:23 AM   #4487
tqstarburst
tqstarburst's Avatar
tqstarburst is an unknown quantity at this point
When did this become the zenki thread?...
PS
tqstarburst is offline   Reply With Quote
Old 05-09-2011, 12:40 AM   #4488
wh0aitznic0
wh0aitznic0's Avatar
wh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enough
I was starting to lose faith in America.
SPLparts.com * PoweredByMax.net
Originally Posted by hailandkill View Post
wh0aitznic0 -- has or had a shocker sticker on his car at one point, is asian with a gooey white center
<3
Nothing says, 'I'm broke and still trying', like aftermarket steelies.
wh0aitznic0 is offline   Reply With Quote
Old 05-09-2011, 01:48 AM   #4489
Lukasss
Lukasss's Avatar
Lukasss is an unknown quantity at this point
I posted that on the last page.
Still dont mind looking at it though.
Lukasss is offline   Reply With Quote
Old 05-09-2011, 03:24 AM   #4490
manureman
manureman is an unknown quantity at this point
PS
when did this become the shitty photoshop thread
manureman is offline   Reply With Quote
Old 05-09-2011, 08:12 AM   #4491
NickIsAZero
Trader Rating: (41)
NickIsAZero is an unknown quantity at this point
Feedback Score: 41 reviews
Originally Posted by krappy View Post
Saw this car over the weekend, very nice.
NickIsAZero is offline   Reply With Quote
Old 05-09-2011, 09:06 AM   #4492
S14kouki_10
S14kouki_10's Avatar
S14kouki_10 is an unknown quantity at this point
S14kouki_10 is offline   Reply With Quote
Old 05-09-2011, 10:09 AM   #4493
ckw
ckw is an unknown quantity at this point
My car... it looks so grey
ckw is offline   Reply With Quote
Old 05-09-2011, 10:25 AM   #4494
Michael Nolan
Michael Nolan is an unknown quantity at this point
Send a message via MSN to Michael Nolan
Burnaby woop woop
Michael Nolan is offline   Reply With Quote
Old 05-09-2011, 10:51 AM   #4495
tqstarburst
Ask me if i give a fuck? No,now go back to you're corner.
kthnxbye.
more pics s14kouki10
Old 05-09-2011, 12:38 PM   #4496
Tempo
Tempo's Avatar
Trader Rating: (39)
Tempo is an unknown quantity at this point
Feedback Score: 39 reviews
Originally Posted by qwerth View Post
Photos I took a while back
coincidence lol i found this video of this car yesterday and see these pictures today
YouTube - Jesse Budano's 1995 Nissan 240sx S14
IG - allen.kerose
Tempo is offline   Reply With Quote
Old 05-09-2011, 01:13 PM   #4497
!Zar!
!Zar!'s Avatar
kthnxbye.
How about you go back to school and learn proper grammar and punctuation?
Old 05-09-2011, 01:18 PM   #4498
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
Ha, "go back to you are corner."
Old 05-09-2011, 02:46 PM   #4499
spooled240
spooled240's Avatar
i need a real camera
Old 05-09-2011, 03:15 PM   #4500
lesfriskynipps
lesfriskynipps's Avatar
lesfriskynipps is an unknown quantity at this point
Ask me if i give a fuck? No,now go back to YOU ARE corner.
friskynipples.wordpress.com
lesfriskynipps is offline   Reply With Quote
