Old 05-12-2011, 04:56 PM   #6031
chiboy002
chiboy002 is an unknown quantity at this point
Originally Posted by JKL1031 View Post
I know that would be the correct way, but after this new engine, I don want to touch the cooling system, although there shouldn't be an internal leak this time which left me mind screwed about bleeding on my first engine. Also want to use a swirl pot. I'll have to get over itand get those done eventually.
then get a stance water neck adapter, or one from DIF (comes with gasket maker, no other difference)
it literally just sits between the water neck and the block, and since you make gaskets (or you can buy two new ones, i guess) there won't be a leak. As supposed to the hose adapter, which there might be but a pretty low chance.
Nisport sells adapters so you can put two sensors into one bung, but i don't recommend this since it's just another spot that can develop air pockets
street dancer.
GLEAM
Old 05-12-2011, 04:57 PM   #6032
KOME
KOME's Avatar
KOME is an unknown quantity at this point
Originally Posted by KOME View Post
So after editing my e-mail notification to "Do not sen e-mail" i still keep getting damn e-mails every time someone post on a subscribed thread or get a new PM!! I gave up junking all my e-mail as i have over +300 new ones.... :[
Help?
Anyone?....
KOME is offline   Reply With Quote
Old 05-12-2011, 06:54 PM   #6033
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
Feedback Score: 82 reviews
Anyone know the battery wire size for a e36 ? The battery is located in the back ...
NEED Bolt kits for your car?
Old 05-12-2011, 07:57 PM   #6034
S14kouki_10
S14kouki_10's Avatar
S14kouki_10 is an unknown quantity at this point
What website does everybody get their tires from. I'm looking to get some s-drives.
S14kouki_10 is offline   Reply With Quote
Old 05-12-2011, 08:00 PM   #6035
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Local performance shop in 909 area? Not a machine shop but a shop that can build a low compression motor cams, built head. All that
Old 05-12-2011, 08:49 PM   #6036
leung
leung's Avatar
Trader Rating: (73)
leung is an unknown quantity at this point
Feedback Score: 73 reviews
how much is a base model 95 zenki worth? in real good condition.
leung is offline   Reply With Quote
Old 05-12-2011, 09:07 PM   #6037
benarovi
benarovi is an unknown quantity at this point
anywhere 2500 to 3500
depends on lots of shits, mileage, 5 speed, ect
benarovi is offline   Reply With Quote
Old 05-12-2011, 10:47 PM   #6038
Kevin_S14
Kevin_S14's Avatar
Kevin_S14 is an unknown quantity at this point
QUESTION: i currently have an s14 with 18x9.5 +12 and 18x10.5 +15 (basically perfectly flushed). But now i kinda want 20mm front fenders and 40-50mm rearovers. what offsets would i need in order for the wheels to be flush with the new setup? Thanks
Kevin_S14 is offline   Reply With Quote
Old 05-12-2011, 10:51 PM   #6039
Farkel
Farkel's Avatar
Location: B̷͈͇̠̗͔̼̝̓̎͛͂A̧̡̠̩̭̹̼̭͔̎̃̈́̍͂ͬͬ̚Y̯̜ͨ̒̾̽͊͘ ͈͙̰
Farkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura about
Send a message via AIM to Farkel
Is rolling a fender completely FLAT necessary? Currently, my rear fenders are rolled, but they are not flat... The tire will be close to the fender so I'm wondering if it'll end up rubbing just because it's not rolled flat. Can't test fit it at the moment to see so I can only ask and speculate.
From my assumptions, as the wheel goes up, the wheel cambers in... and if it rubs, it'll rub on the fender area above where the fender lip is?
★ ★ GRANDMIGHTY.COM ★ ★
Farkel is offline   Reply With Quote
Old 05-12-2011, 11:15 PM   #6040
chiboy002
tirerack.com for s-drives
yeah as the suspension compresses the camber is more effective. rolling it completely flat is only necessary when you want to get as flush/aggressive as possible without doing a pull. You're tire pretty much is like 1mm away from the fender at this point.
if anything you can always do a newspaper pull which is pretty much like rolling them flat
street dancer.
GLEAM
Old 05-12-2011, 11:41 PM   #6041
foxystyle
foxystyle's Avatar
foxystyle is an unknown quantity at this point
really dumb question. but is the orange line on the ka manual tranny just a drain line? does it hook up to anything else after it connects to the metal U?
foxystyle is offline   Reply With Quote
Old 05-12-2011, 11:47 PM   #6042
Wake
Wake's Avatar
Its a breather. Nothing goes through it bu air, thats why it goes to the highest point on the tranny.
I see a fuckton on people on here that think its a wire or tube or something lol. Hopefully this clears it up.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 05-12-2011, 11:57 PM   #6043
foxystyle
foxystyle's Avatar
oh that makes a lot of sense now ::face palm:: alright thanks a lot wakebhr for the info.
Old 05-13-2011, 12:02 AM   #6044
heavyd06
heavyd06 is an unknown quantity at this point
my shell came with "upgraded" fuel lines..lol..n i dont know which one is the one that sends the fuel and which one is the return line..
heavyd06 is offline   Reply With Quote
Old 05-13-2011, 12:04 AM   #6045
heavyd06
and that aint my pic i just got it off the webz
Old 05-13-2011, 12:06 AM   #6046
KOME
KOME's Avatar
Will 17x8 + 35 wheels clear stock S13 fenders?
Old 05-13-2011, 12:28 AM   #6047
s14tan
s14tan's Avatar
s14tan has made poor choicess14tan has made poor choicess14tan has made poor choicess14tan has made poor choicess14tan has made poor choicess14tan has made poor choices
Originally Posted by ignited View Post
has it been retuned with all of those parts installed together? only reason I am asking is because it wasnt written that you did or didnt. peace.
Originally Posted by codyace View Post
Yes, no issues
Check the tune if anything, or even log a run. Hard to say with an AFC really.
The car ran exactly the same when it was stock, most of the parts that have been replace were due to the OEM piece breaking, (stock turbo ex housing cracked, etc.)
There is no tune on the AFC, everything is zero'd out Except MAFS IN and OUT are changed for the Z32.
s14tan is offline   Reply With Quote
Old 05-13-2011, 12:31 AM   #6048
jandysil80
jandysil80's Avatar
jandysil80 is a jewel in the roughjandysil80 is a jewel in the roughjandysil80 is a jewel in the roughjandysil80 is a jewel in the roughjandysil80 is a jewel in the roughjandysil80 is a jewel in the roughjandysil80 is a jewel in the rough
Anyone have any idea on what degree the valve cover can get to when running hot or on average? ...trying to paint my valve cover with a certain kinda paint, but wanna make sure it wont crack or peel from hot temps, thanks!
jandysil80 is offline   Reply With Quote
Old 05-13-2011, 12:32 AM   #6049
Wake
Wake's Avatar
yes, with room.
S.P.P.S. Member #00
Old 05-13-2011, 01:30 AM   #6050
chiboy002
positron's hands! hahaha i've seen too many of his write ups
you can remove the gas cover and check yourself or you can follow the lines from under the car, but i'm pretty sure the right side line is feed, and the left side is return (in the picture)
then you can just find out by looking at the fuel lines from the bay, return is behind the rail and feed is with the filter on it
if you decide to remover the cover, you need to buy a new o-ring, which is like 5$
street dancer.
GLEAM
Old 05-13-2011, 01:36 AM   #6051
Torq_Meister
Torq_Meister's Avatar
Torq_Meister is an unknown quantity at this point
is wiring for the 5th gear sensor required when doing a 5 speed swap? does it matter if its for manual or auto ecu? i have been running an auto ecu after my 5 speed swap and i never wired the 5th gear sensor because i heard it wasnt required. but i just picked up a manual ecu and someone said that i needed to wire the 5th gear sensor if i was to run the manual ecu?...
Torq_Meister is offline   Reply With Quote
Old 05-13-2011, 01:43 AM   #6052
rat240
Trader Rating: (87)
Feedback Score: 87 reviews
any one no the part# for the jspec silvia turn signal lenses mine cracked
Old 05-13-2011, 01:50 AM   #6053
heavyd06
lol..it aint my hand nor mi picture..lol..but yeah the guy who had it b4 me swapped the oem stull for like i guess aluminum idk n earls an fittings..thx man thats all i needed to know which side was i guess feed n return..this is all i need to try n start the sr..=)
Old 05-13-2011, 01:51 AM   #6054
heavyd06
nvm u mean the guys name is positron..jaja.. =P
Old 05-13-2011, 02:33 AM   #6055
Wake
Wake's Avatar
Left is return, Right is send
Shouldnt be more than 250 degrees
Dont use the 5sp ECU stay with the Auto, No rev limiter or speed cut.
Pignose - (R)B6120-RS13, (L)B6125-RS13
Body Exterior :: JDM :: 240SX Parts (S13) 1989-1994 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
Chuki - (R)B6120-50F00, (L)B6125-50F00
The Nismo Shop :: West Covina Nissan
Not positive that those are the right part numbers, but you can buy em from the links.
S.P.P.S. Member #00
Old 05-13-2011, 07:31 AM   #6056
Nizmo_max
Nizmo_max's Avatar
Nizmo_max is an unknown quantity at this point
ok, i have a confusion, im swapping my front caliper back to oem, previous was on z brakes, now for some reason my brake pedal dont have any pressure to it? and yes i bled the shit out of it already, no bobbles on all four lines what so ever..im guessing did i put the lines on the wrong fitting to the BMC..does any one remember which lines goes to which fitting on a 95 s14? help would be appreciated thanks!!
Nizmo_max is offline   Reply With Quote
Old 05-13-2011, 07:58 AM   #6057
vboy720
vboy720 is an unknown quantity at this point
Send a message via AIM to vboy720
is maf wiring different on s13 sr vs s14 sr? I have a zenki s14 sr, and my car doesnt run with a zenki maf, but if i put in a s13 maf, it runs better?
vboy720 is offline   Reply With Quote
Old 05-13-2011, 01:11 PM   #6058
niteridaz503
niteridaz503's Avatar
niteridaz503 is an unknown quantity at this point
Anyone on here running PBM sub frame risers on their s13? i was aware of increased diff noises and of course the rougher ride but then i get a winding noise from my diff at higher speeds especially on the freeway once i hit 70 it was pretty high pitched & just wondering because the sub frame is raise 1/2 inch did that upset the balance of the diff therefore wearing out the ring gear & pinion gear out or am i just trippin?
Also would it be safe to say that to correct this i can run a 1/2 inch spacer on the carrier bolts on the diff to lower the font of it to even out the load on the pinion gear?
Originally Posted by yetijeff View Post
Hes higher than giraffe pussy lolz
niteridaz503 is offline   Reply With Quote
Old 05-13-2011, 02:02 PM   #6059
89SwapXE
89SwapXE's Avatar
89SwapXE is an unknown quantity at this point
anyone know a place in the ie where i can have my wheel bolts anodize? for a decent price.
89SwapXE is offline   Reply With Quote
Old 05-13-2011, 03:04 PM   #6060
STEEZxIT
STEEZxIT's Avatar
STEEZxIT is on the path to ruinSTEEZxIT is on the path to ruin
They are plastic -- how will they fix it?
replace the tank
i was asking about the labor costs, i need to take my car to a shop to replace my gas tank because of the leak so i wanted to know if anybody who frequents this thread has had to go through this since it is quite a common problem with the s14 and what sort of costs can be expected? if anyone knows...?
@dangerdamian
STEEZxIT is offline   Reply With Quote
