05-15-2011, 01:05 PM | #1 |
KA24DE mystery part - dowel pins for?
I bought a torn down KA24DE and am slowly putting it back together. I've come across 2 solid metal pins that I have no idea what they go to. Any help would be greatly appreciated.
In this picture they are next to the hollow alignment dowel pin for the cylinder head. |
05-15-2011, 04:25 PM | #3 |
I see a dowel pin in the block above the flywheel side freeze plug. It's a bit smaller than these two. There is a hole near the crankshaft on the flywheel side where the pins fit. There is only one hole. I don't have a transmission/housing so I can't compare the pins that way.
05-16-2011, 08:42 PM | #4 |
So far the closest thing I can find to fitting these pins is the hole near the flywheel for the transmission bell housing but that's still only 1 hole. I think what I'll need to do is visit a junkyard and strip down and old KA DOHC until I figure out where they go.
06-04-2011, 04:28 PM | #5 |
After many hours searching the web and service manuals and pictures and forums and everything else I could think of I came across a single clue to what these could be. Part 11021A at nissanpartszone. There is a channel that goes straight through the block. Originally I found a hole the exact size where one of these would fit. Since the oil pump was installed I didn't notice that on the other side of the block was another hole. With the timing cover off I can look straight through the block and see out the other side. This seems to be either a coolant channel and these are freeze plugs or an oil channel. Either way, this is the only place I can figure they go and in every other picture I can find of a KA24DE - the holes are plugged!
Here is the part : 11021A 240SX PLUG-TAPER 1993 Nissan 240SX Cylinder Block & Oil Pan - 1101363 http://www.nissanpartszone.com/diagr...pan-110h01.png 11024-K0100 - Nissan PLUG - TAPER |
06-07-2011, 12:23 PM | #6 |
Looks like a DOWEL-BLOCK TO HEAD. This 2 is used on the block surface (head gasket side) to align or mate when installing the head.
Look at part code 11010A on your link 1993 Nissan 240SX Cylinder Block & Oil Pan - 1101363 *11010A240SX DOWEL-BLOCK TO HEAD 11053-734001990.07-1993.02KA24DE11010A240SX DOWEL-BLOCK TO HEAD 11053-01M001993.02-KA24DE$2.22 $1.78 |
dowel pin, gasket pin, head pin, ka24de |
