06-05-2011, 12:59 AM | #1 |
blowing coilpacks?
Just blew two coilpacks in a week
I'm.thinking wiring problems but what kind of wiring problems would POP a coilpack like a fuse.
06-05-2011, 01:06 AM | #2 |
Trader Rating: (68)
Feedback Score: 68 reviews
I had this problem but i think you have a different problem then mine.. My spring inside the coil pack was compressed so it wasn't or barely touching the spark plug at all, which caused it to pop. Well, atleast i think so.. Cause when i swapped it for a new one and it worked perfectly fine when i made sure the spring was actually touching the plug itself.
Shit also caused my spark plug threads to strip, i had to re-thread the head for that cylinder..
Late Night Crew... #02 <3 Bought anything from me? Please leave me a review! http://zilvia.net/f/private-sellers/...meistah21.html |
06-05-2011, 07:02 AM | #4 |
Mods? I assume sr. :P
The coils ground through the ecu right? I dont think the ecu could just be blowing up coil packs for fun. Its POSSIBLE, just not PROBABLE. Whats more likely is the PTU, also known as an ignition control module, sending faulty signals to the coil packs thus the coils failing... That is POSSIBLE and PROBABLE. But that might not be the issue, could be bad wiring, something melted, common ground arching out to the signal wire. etc. Let us know what your working with so we can better diagnose whats going on...
0 horsepowers.· \ ' ' ·.1000 horsepowers |
06-05-2011, 12:35 PM | #5 |
Well its on my miata and the miata forums are full of jackasses. There are a few smarties here.
You really think just a loose ground could POP a coilpack? I'm thinking more along the lines of a power wire grounding out.....but even that seems unlikely to me.
06-06-2011, 09:55 AM | #6 |
it could be either or
but the ground can cause this the sr20det has a ground loop on the coilpack harness on the back of engine mae sure its grounded properly
シチサn w/ka20det:in progress シチサnw/sr20det:stolen |
06-06-2011, 12:03 PM | #7 |
Did it blow 2 coilpacks in different spots or 2 coilpacks in the same location? makes a difference...
1991 Nissan B13 Sentra sr20det 300whp/1991 Nissan S13 240sx sr20det ~260whp |
06-07-2011, 02:17 PM | #8 |
Trader Rating: (22)
Feedback Score: 22 reviews
I used to do this when I ran the coil pack cover. I've since dumped that in favor for a Phase2 grounding plate and haven't had an issue. It gets pretty hot under that cover.
