![]() Join Date: Jun 2010
Chase Bays Power Steering Kit
Introducing our Power Steering Kit. Aluminum Reservoir and full replacement AN fittings and line.
Please view our site for more info: Chase Bays Power Steering Kit - Nissan 240sx w/ KA|SR|RB - Nissan 240sx - ChaseBays.com ![]() Optional Power Steering Cooler for +$100 There is two ways to mount this. Zipties, or on the PS cooler there is a spot where you can slide in square headed bolts in and bolt it to your chassis (drilling required) ![]() Also provided is a link to the install guide http://www.chasebays.com/content/dow... Guide.pdf.zip Thanks for viewing!
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE www.ChaseBays.com | [email protected] | (205)623-2188 Last edited by Chase Bays; 10-14-2011 at 03:43 PM.. |
NEVER USE TEFLON TAPE ON ANY POWER STEERING CONNECTION
Let me elaborate on how exactly to bleed your system. First of all double, and triple check that everything is tight. Loose connections might not leak but could allow air into the system. Do not over tighten o-ring hoses as the o-ring might be crushed. Step 1: switch ignition OFF Step 2: raise front wheels off ground (or all 4) Step 3: turn steering wheel full left Step 4:fill fluid resevoir to full cold mark. Step 5: turn steering lock to lock at least 20 times, up to 40 times. If you're using our cooler it may be in excess of 40 times. DO NOT turn the wheel fast, slow is better for the bleeding process and it could likely cause fluid overflow. Step 6: while turning wheel, check fluid level, a 2nd person is almost required. If you see any signs of bubbles/foaming, recheck all connections for leaks then repeat the steps above. Step 7: NOW we start the engine. If fluid foams while cranking, wait 10 minutes or more until dispersed air has time to accumulate and purge through the reservoir. Step 8: Return wheels to center and lower car. Step 9: run engine at 2000 rpm for two minutes. Step 10: turn wheel in both directions and check for smoothness and quiet operation.
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE www.ChaseBays.com | [email protected] | (205)623-2188 |
![]() Join Date: Dec 2003
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
so what did you revise on THIS kit? I'm definitely interested.
Any shots of the reservoir baffling?
Fu*king ginger bread man stole my wallet... SHIFTlock_slide to side d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson |
We took out the COPPER crush washers on the STEERING RACK FITTINGS ONLY they were causing the O-ring fittings to not get a proper seal. The PUMP fitting still needs the crush washer/o-ring as its always been. Replaced one AN fitting with a 90 deg fitting on the reservoir and gave detailed instructions on how to properly bleed the power steering pump.
The reservoirs were changed too, pictures in a few
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE www.ChaseBays.com | [email protected] | (205)623-2188 Last edited by Chase Bays; 06-20-2011 at 03:37 PM.. |
People who have the crush washers, should we cut them off before installing?
The thing is, it’s a gearbox, okay? It has one job to do! One job! Pull the lever… ‘Am I a pencil? Am I a cauliflower? Am I a nuclear power sta– I’m a gearbox! Oh, heavens, I’m gonna swap some cogs around!’ Jeremy Clarkson on Automatics |
![]() Join Date: Sep 2008
![]() Feedback Score: 20 reviews
I have small leak AN fitting with a 90 deg fitting on the reservoir. i did not use teflon tape and tighen less than 15 lbs. so help me solve it issue
Email us or give us a call.
#9 | |
![]() Join Date: Sep 2010
Trader Rating: (41)
![]() Feedback Score: 41 reviews
Features: Aluminum Baffled Reservoir with -6AN and -10AN Outlets FAQ: Is this can baffled? No, both outlets are on the bottom of the can, eliminating the need for a baffle. |
OOPS, thanks for the heads up. We recently went in and modified that. Fixed now
#14 |
that picture wtih all black lines is also from the old set up. different reservoir
street dancer. GLEAM |
#15 |
![]() Join Date: Nov 2004
Thanks for the fast replies, i'll be picking up one of these kits in the future. First kit kind of had bad reviews. It sounds like the kinks have been worked out though.
#18 |
All Pm's Sent!!
Bump to the Top!!
#19 |
Bump to the Top!!
#20 | |
Trader Rating: (22)
Thanks! I'll be ordering a kit once I get my tubs finished. Free Bump!
#21 |
Morning Bump to the Top!!
#22 |
All Pm's Sent!!
Bump to the Top!!
#23 |
I have the same problem. Chase Bays advised me to remove the crush washers on the rack for those leaks, but never suggested anything regarding the large fitting at the reservoir.
#25 |
![]() Join Date: Dec 2008
Trader Rating: (79)
![]() Feedback Score: 79 reviews
How shipped for a S13 w/ 1JZ shipped to 92551?
My Build: The "Coupe De Ville" 1JZ Build!! |
#26 | |
#27 | |
If you guys are having issues please call us or email! Don't just complain about it! We're here to help.
#28 | |
#29 |
The power steering pump of course uses the engines drive belt and like an AC compressor it's going to put "load" on the engine. You might also notice on your other cars (usually 10+ year old ones) when you turn your headlights on, crank the radio up, anything that puts load on the electrical system and/or engine...the idle will drop and/or lights will become slightly dim.
There is a few things that can cause this. Your IACV/AAC is supposed to regulate your idle to compensate but sometimes it can't fight with our weathered components. The first thing is going to be the alternator. Depending on your engine the alternator amp rating is 70 to 135+ amps. You want 100+ amps. Every decent sized city has a shop that can repair and rebuild an alternator or at least test it. Those auto parts store replacement alternators are awful so beware. Equally important is replacing your battery/alternator/fusebox power wires & grounds. Stock they're usually 10 or 8 gauge which is sufficient depending on your starter and alternator amp ratings but the wires are OLD. I recommend 6-8 gauge for alternator and 0-4 gauge for starter. Engine/Trans ground's 8 gauge and Battery Ground 0-4 gauge. These items from us will help you: CUSTOM LENGTH Battery Cable's Electronics/Wiring - ChaseBays.com Chase Bays Engine Ground Kit Chase Bays Engine Ground Kit - Nissan 240sx - ChaseBays.com
