It's Always Broken.
![]() Join Date: Feb 2010
![]() Feedback Score: 14 reviews
![]() I've been working on my friends SR20 and I can't figure out why it's doing this. It's almost like it hits fuel cut, or a rev limiter, and just completely stops building boost, accelerating, etc.
There are no boost leaks, AFR's are good, etc. His set up is: S15 T28 Turbo at stock boost Apex'i AVCR Sard 550cc injectors Z32 MAF I have checked timing,ignition timing, i've tried turning the AVCR to "off," I've checked plug gaps, etc. I've tried all I can think of. Also tried to completely remove the AVCR from the picture, by unplugging it, and routing the wastegate straight to the hotpipe, instead of the boost controller. Same issue. Any thoughts? |
![]() Join Date: Dec 2006
What are the plugs gapped to?
![]() Join Date: May 2011
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
CHECK UR TPS SENSOR next to throttle body might have a dead spot in it holddd it all the way down with a screw driver and have some one rev and see if its thatt
![]() Join Date: Dec 2004
Trader Rating: (58)
boost leak
#10 | |
It's Always Broken.
How can the spring cause it to do this? We've checked all couplers, even made a boost leak tester...there is no boost leak. However, the Greddy RS bov has a little hole on the back of it (factory), and it leaks during the boost leak test, why is this? |
![]() Join Date: Oct 2009
Trader Rating: (18)
![]() Feedback Score: 18 reviews
hi just checked my buddy car and lil update when the car was cold it goes the boost no problems and no fuel cut ...so what could be it ?..bad fuel pump or coil?
#12 | |
Trader Rating: (58)
That part is ok, it's just a little vent to aide in the operation of the blow off valve -- it leaking doesn't effect how the car runs. WHen this condition occurs, can you go WOT and the car continues to run, albiet off the 'limiter' sort to speak.
#14 | |
It's Always Broken.
When it happens, yes the car continues to run, it doesnt turn off or sputter or anything. It just hits a wall. When the car is cold, it does not do this. I'm thinking maybe fuel pump....or coil harness? The car hits a wall and does nothing...that's as specific as it can be explained haha. |
#15 |
Trader Rating: (58)
To check the coil pack harness you could check resistance and readings via Multimeter and FSM, I'd do that as if it checks out you can rule that out.
Member Jspaeth on here had an issue like this and his ultimately was solved by back probing the ECU pins and making sure they were making contact. I had a similar issue to this and it was a loose coupler, that had escaped my initial inspection of all couplers. Aside from that, use the FSM to troubleshoot your main sensors....TPS, CAS, CTS, MAF and O2. It doesn't take long to check signal wire integrity.
#16 |
u should rewire ur fuel pump
with heavy duty wire and relay definatly check ohms on coils also check the two plugs that power engine harness to see if all wires r getting full 12v... also is the engine like gurgling at 5.5 k ? or cutting off? also do u have a tuned ecu ? if so try a stock one and see wat happens
シチサnw/sr20det:stolen |
#19 | |
Trader Rating: (18)
#20 |
Trader Rating: (58)
I knwo plug gaps were checked, but what are they set at?
#22 |
also i meant the ohms on the coil packs not just the 12v source they have to be 1k ohms
put a stock ecu on it and see if it happens again
#23 |
Trader Rating: (58)
Try gapping them down to .022 and see if that fixes it up. It may be spark blow out. With the age of these components getting older and olrder, it's hard to say how capable a 20 year coil pack is anymore.
#25 |
Trader Rating: (58)
Knock sensor shouldn't even be working at that point, it's sub 4000 IIRC
#26 |
It's Always Broken.
Alright guys.
- I checked ECU codes, there is no knock sensor code. I built the motor and the knock sensor is good, and the wiring to the knock sensor is good. - Today I gapped the plugs from .028 to .025, and it's the same deal. - I tried retarding and advancing the timing, like 20 different times. Was never any better or worse, it made no difference. - I swapped my walbro fp into it, which I know is good because it powered my KA-T just fine, problem still persists. At this point, I'm thinking it may possibly be the coil packs themselves being bad? Kinda lost. |
#27 |
Trader Rating: (58)
Is there anyway you can get a video of it when it happens?
#29 |
My car is having the same exact problem! it cuts out/ hits a wall at 5000ish but when the car is cold it runs great. Please let me know if you find what the problem is i have been stumped for months.
