Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
07-27-2011, 04:28 PM | #841 | |
yep welded with low power is win stock sr is also better with a welded I love mine still |
08-03-2011, 08:48 AM | #843 | |
To go faster.
For a second, forget that drift cars are moving sideways. Imagine it going around a corner without any slip angle. In order for it to go faster around the radius of the turn, a wider tire is preferable to have more lateral grip force. The same applies for drifting. Some of the grip force is used for spinning the tires to get some slip angle, the rest is for sticking to the road. The rear tire (closest to the most outter side) contributes a lot to the overall grip of teh car.
HouseBuyers365.com Quote:
08-03-2011, 09:22 AM | #844 |
Because they think 500+ horsepower is needed to drift.
http://bhworld.wordpress.com/ |
08-03-2011, 02:10 PM | #845 |
it has to do with competition. What is faster off the line. a small tire, or a big tire. well the big tire will get more traction (surface area) than the small tire. Well if the guy next to you has the maximum tire allowed for the amount of weight he has, and based on your weight, you have the maximum, you "should" be equal. As horsepower doesn't judge how much forward traction you can acheive. It's not the power of the engine that puts traction down. it's the tires. Now with that understood, Torque is what spins that tire. If you have the maximum tire for your required weight, that doesn't mean you have enough power to actually spin those. And that's why Justin's running a Mustang with almost 900whp and a 295 tire. If he ran that tire with less power, it will be harder to spin cause the friction will still be the same on the tire regardless of power. Basically more power, just means it's easier to spin required tire. Less power, for the same size, just makes it harder to break that traction. And unfortunately, money determines power. Justin's driving around in a Roush built motor worth 40k. That's what sponsors provide ;D. And as you can see...it's giving him podiums with his driving also being on par. Winning in FD means forward traction. Eventually there is a limit to how much grip you can acheive without doing willies around the track sideways (which according to ross petty, he says he at some point actually has both his tires leave the ground cause of traction). |
08-03-2011, 02:20 PM | #846 |
You say potato, I say potato!
08-04-2011, 01:41 AM | #847 |
Hm. I get it now. Thanks boys! Just sucks cause FD is such a high level of drifting and it's quite inspirational. Too bad to drift at that high of a level, you need to have LOTS of money.
I mean, yeah... sponsors pay for all that shit. But how do you get those sponsors? With a high performance drift car. High performance drift car = LOTS OF money. EFFING WHACK SAUCE There's a couple people I know locally that are spoiled by their parents and made it to FD because of them.......... makes me frown. |
08-04-2011, 01:47 AM | #848 | |
Everything is expensive.
08-05-2011, 03:57 PM | #850 | |
NWN had a contest where the member with the most votes got a sponsorship. Also why don't you go read the post that Walker directed toward you after you tried to call him out on "his parents payed for his entire drift car build". Ignorance must be bliss. |
08-06-2011, 12:09 PM | #852 | |
I still don't see what is wrong with people being supported by their family? Someone enlighten me? You think ANY of the Formula 1 drivers would be where they are if they weren't supported by their family? Funding is just ONE part of the equation. You can't buy a podium finish. That takes SKILL. Getting a sponsor takes more than an awesome car. You have a lot of learning to do, and judging by your age you seem to think you know everything, when in reality you have a long way to go.
08-06-2011, 03:25 PM | #853 | |
get over it |
08-06-2011, 05:24 PM | #854 |
Trader Rating: (38)
Feedback Score: 38 reviews
so i remembered that the guy who i bought my diff from said he put friction modifier in it. and since that makes the diff lock less aggressively, does that mean that once i change the fluid, it will lock easier and i wont need to try as hard to lock it? lol
i know the low hp of the ka is still in play, but im just wondering if it will get easier once i change diff fluid.
2016 Nissan 370z |
08-06-2011, 05:32 PM | #855 | |
on another note, friction modifiers are used as an additive for regular gear oil to make it LSD compatible. Do you have an LSD? Assuming you do, it's just you. |
08-06-2011, 05:44 PM | #856 | |
Trader Rating: (38)
yes i have a 2 way. but i also have a basically stock car. fully stock suspension. go a page back if u want to know whats on my car. and while i know i havent mastered it, i can assure u, its partly the car. i can lock the diff up fine if i ebrake, clutch kick, or power through it. im just having a hard time locking it up on brake drifting. even when going like 35-40 through a 90 degree turn. im not gunna state where its at, but lets just say theres little room for mistake or il crash, so im a little reluctant to go in full blast through the turn.
2016 Nissan 370z |
08-06-2011, 05:55 PM | #857 | |
08-06-2011, 06:55 PM | #860 | |
What corner? There is no set speed for drifting. Telling someone that they need to go X speed at an unknown location/surface is a horrible idea.
08-06-2011, 07:29 PM | #861 | |
By corner I meant whatever thing he's drifting around |
08-11-2011, 03:12 PM | #862 |
Not necessarily -- it depends on other things, like alignment setting, tire quality, surface condition, and the corner itself...
Drifting is just a compromise between you and your car. |
08-11-2011, 03:23 PM | #863 |
Am I the only one who never felt the need to initiate through, 'brake' drifting?
Weight transfer, clutch kick, ebrake. All that is needed. No?
08-11-2011, 04:10 PM | #864 | |
But what do you do when you've got a straight, followed by a hairpin? You could kick the clutch super early, balance the car while it scrubs off speed, and enter the turn. Or you could do a little dance with the e-brake through the straight before entering the turn. But it kind of gets a little old too after doing it for a full day. You're right, you never really NEED NEED to brake drift. I just like doing it... it's a matter of preference I think. I like it because at least for me, it's more difficult, and you really feel your car and its setup. You really have to do things the right way or it just won't work. Like, take any car... Pull hard on the ebrake and the rears lock up. That's predictable. It doesn't matter what kind of coilovers you have or changes you made. Cars are going to react relatively the same. But the way a car reacts to pedal braking will always be different depending on the car and what you did to it. (unless you lock up the brakes). You can really feel your setup and you can feel the changes you made. And technique matters a lot more... how fast you turn the steering wheel, how hard you brake, when you brake... It's hard to explain, but I hope you know what I mean. You can go up to the corner entrance faster.... threshold brake to slow the car, keep some weight on the front, and brake drift it into the turn. Then you can appreciate the hard work you did with setup and polishing your technique. I find this a lot more rewarding, but that's just me. Kind of feel like I rambled on... o wells
08-11-2011, 04:48 PM | #865 |
I agree with Zar (although now I can't take him seriously and LOL everytime I see his sig and avatar hahaahhahaha). The only people I've met that actually NEED brake drifting is the, anything higher power than a KA at Adam's Track in Riverside. That's only because the course is tiny.
08-11-2011, 05:17 PM | #868 |
If your car locks up trying to brake drift, you're probably locking up the fronts only, and that's a one-way trip to understeer land... You want to brake to pitch weight forward, but you don't want to do it so hard that you lock up the fronts.
08-11-2011, 05:19 PM | #869 | |
I can dig it. But I have drifted a gokart track before, and ebrake was enough. I rather enter fast and slow down mid drift. Braking into a hairpin like that sounds rad, but a I find that it doesn't allow you to build revs up once you are mid corner, as well as it sounds like a recipe for understeer.
08-11-2011, 05:31 PM | #870 | |
Understeer, happens too. You just have to do it right. Don't brake too hard when it's time to pitch the car into the turn. Play with pads. Some people don't like brake drift because it seems to require more effort. Like there's a lot of extra variables and caca to think about. Some people like it for that same reason.
