Old 09-08-2011, 09:51 AM   #3121
GripTerror
GripTerror is an unknown quantity at this point
It's somewhere in here.... lol can't believe this thread has become 104 pages... well.... it's an aftermarket subframe that's based on an s14 design but with adjustability... apparently the squat can be adjusted and what have you... but seriously it's madly overpriced...
I suppose OP should include details on it in the opening thread.
GripTerror is offline   Reply With Quote
Old 09-08-2011, 12:17 PM   #3122
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
I am really greatful for the list of info on the front page. I had to order a few replacement parts today and I didn't have to dig through anything to remember exactly what I had haha.
I also mailed my knuckles out to PSM today!!
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 09-08-2011, 11:04 PM   #3123
Patrick Bowering
Patrick Bowering's Avatar
Patrick Bowering is an unknown quantity at this point
so I did an alignment and put caster down to 6.25 degrees and I went out tonight and did a few laps and it handles like ass now hahaha taking it back to 7 ish so the car will atleast self steer a little and not just slap to full lock and stay there. I mean the dampers arent set and shit but I can tell that its just brutal maybe with a ton of reverse rake it would be ok.
Patrick Bowering is offline   Reply With Quote
Old 09-09-2011, 05:57 AM   #3124
PoorMans180SX
PoorMans180SX's Avatar
Sounds like you're overcentering.
Old 09-09-2011, 06:05 AM   #3125
thefro526
thefro526's Avatar
thefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of light
Seconded, based on your description.
If you're not over-centering (You'll feel a noticeable bit of resistance as you attempt to pull the wheel off of lock if you are.) then you just weren't running enough caster.
thefro526 is offline   Reply With Quote
Old 09-09-2011, 08:21 AM   #3126
SoSideways
SoSideways's Avatar
Haven't been on here in ages, and I've just started to care about car stuff again, so I'm back on here.
Basically, just wanted to report not having any problems with the tie rod ends that I made, nor have I had any problems with the modded FLCAs, and I've been driving around on the street for a few months.
Old 09-09-2011, 10:41 AM   #3127
PoorMans180SX
Originally Posted by thefro526 View Post
I apologize if this has been brought up before, but does anyone know anything about this: JUN Auto Drag Rear Member
You can see in the picture that the front pickup points for the FLCA have been dropped A LOT. This reduces anti-squat, giving some more traction for the 1320 guys.
It's not worth anywhere near $3K.
Old 09-09-2011, 10:45 AM   #3128
PoorMans180SX
Remind me of your steering modifications again... Are you adjusting caster with the tension rods?
If you can, take some pictures of the FLCA and tie rod end from below at full lock.
Old 09-09-2011, 03:44 PM   #3129
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
Thanks! They will come back looking like this:
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline   Reply With Quote
Old 09-09-2011, 04:20 PM   #3130
PoorMans180SX
You're welcome! Just trying to give back to the community in a small way.
I'm excited to see you using the knuckles to their full ability, and you always make great reviews. I'm strongly considering ordering them myself.
Also, to everyone, I'm starting work on a revision to the original posts, I'll let you know when they're up!
Old 09-09-2011, 05:48 PM   #3131
Patrick Bowering
its not overcentering because it doesnt get "stuck" i suppose it could be borderline overcentering but my steering stop is my sway bar so ya. it just feels weird becuase there is very very little self steer like it wont even transition without steering input. i am adjusting with tension rod. and I have an s13 with s14 control arms and modded pbm knuckles with 25mm rcc aswell. I have s14 inner and outer tie rods and georges spacers to make them long enough to run the good hole in the knuckles. front toe is aroun1/4 out ish and caster is 6.2 I will be putting it back to around 7 I think because i was not having any issues with 7.6. I sure did take self steering for granted though.
Old 09-09-2011, 05:51 PM   #3132
Patrick Bowering
also the car cannot turn to full lock at a standstill. I have to roll the car forward or backward slightly. I am not worried about this I am just seeing what you all have to say and if its normal or not.
Old 09-09-2011, 08:28 PM   #3133
SoSideways
SoSideways's Avatar
^Mine does that.
That's normal.
Old 09-10-2011, 10:32 AM   #3134
PoorMans180SX
Thought this was a pretty cool pic of Dan's S15. Shows the LCA drop and a little better view of the angle the FLCA's sit at with the correction.
Old 09-10-2011, 12:31 PM   #3135
JaredP
JaredP is an unknown quantity at this point
That knuckle is so awesome. Just looks good sitting there lol
JaredP is offline   Reply With Quote
Old 09-10-2011, 07:46 PM   #3136
prego
prego is an unknown quantity at this point
i have the psm flca and need ideas for a bolt on adjustable lock stop anyone have ideas all i can think of is something like this
prego is offline   Reply With Quote
Old 09-11-2011, 04:54 AM   #3137
az_240
az_240's Avatar
Trader Rating: (41)
az_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really nice
Feedback Score: 41 reviews
Send a message via AIM to az_240
delete...........
az_240 is offline   Reply With Quote
Old 09-12-2011, 06:55 PM   #3138
DC Dan MAX USA
Trader Rating: (79)
weld one on like the above picture?
Old 09-12-2011, 07:20 PM   #3139
Pandapants
Pandapants's Avatar
Pandapants is an unknown quantity at this point
Send a message via AIM to Pandapants
Dan, did you say we could purchase the psm rc mod independently from the max pro angle mod right? would the rc mod also include lowering the tie rod mounting point like previously pictured?
Pandapants is offline   Reply With Quote
Old 09-12-2011, 08:06 PM   #3140
DC Dan MAX USA
Trader Rating: (79)
Yes we have the ability to do 45mm roll center with stock angle, stock quickness, stock ackerman, and no bump steer
yes that includes lowering the tie rod mounting point down like the pic of the angle mod, but it is not shortened for super angle.
Our CNC jig that we do this work on is precise and the settings are mirror images left to right side. Its properly engineered.
Your choice, Its $400 either way for the 45mm Pro grip or Pro drift knuckle mod.
Old 09-18-2011, 11:27 PM   #3141
mikerbike
mikerbike is an unknown quantity at this point
I got to drive an S13 with the rack moved forward. Not sure how far. He said he had to extend his steering shaft a bit, so I assume he moved it as far forward as it will go.
Anyway, in mine, with ~13mm shorter knuckles and tie rod pickup lowered ~13mm, I usually give the wheel a flick to full lock to start a transition. And usually at full lock, I get some wobble. I assume that's from over-centering.
With his, I flicked it and the wheel didn't stop where I expected it to stop. So the transition was much harder than I anticipated and I thought I had spun us out. I left the throttle on and let the wheel go to full lock. I had lost way too much speed, and I was basically backward, but the rear end didn't come all the way around.
He has a lot more rear grip than I, but I'm still pretty excited to get some offset spacers. That way, I can add some caster again and get rid of my wobble.
mikerbike is offline   Reply With Quote
Old 09-19-2011, 11:08 AM   #3142
PoorMans180SX
Did both cars have the same knuckle mods?
Old 09-19-2011, 03:11 PM   #3143
mikerbike
No. He modded his with less ackerman. Probably dropped and shortened pretty close to the same though.
Old 09-20-2011, 09:56 AM   #3144
SoSideways
SoSideways's Avatar
I haven't been around reading this thread, but what other mods have you done? Because a wobble could be loose/old worn out parts.
Old 09-20-2011, 01:11 PM   #3145
mikerbike
Not much I guess..
I did this a few weeks ago.
It seems to work great. I cooled it in a bucket of sand, but I heard some guys still break them. I made another pair with the spindles I took off the car. I'm definitely installing them on my second car, and making a third pair for when they do break.
I don't use rack spacers with these, but I still have the factory stops on the control arms.
I found out some interesting stuff this week.
Since I modified my knuckles, I stopped using MAX rack spacers, since my outer tie rod hit the control arm before the rack bottomed out. But, in the quest for a flatter contact patch, I was reducing caster via tension rod adjustment.
As the wheel moved back in the well, it gained angle as a trailing wheel. I liked that a lot, less ackerman without losing leading wheel angle. My 17x9 +9 was hitting the tension rod/sway bar hard.
But, as the leading wheel, the rack started bottoming out before the tie rod hit the control arm. I installed the MAX rack spacers again, and goofed around with it for a few hours to find a happy medium.
That's with the front of the wheel about 1/4" away from the sway bar.
That's about it. But I can see that the line from the inner tie rod end to the outer tie rod end might go right through the lower ball joint pivot. It's close.
Old 09-20-2011, 02:43 PM   #3146
SoSideways
SoSideways's Avatar
That looks like you actually have more angle on the trailing wheel than the leading wheel.
That is probably where your problem is.
Your leading wheel is supposed to have more angle than the trailing wheel, or both wheels have the same angle, not the other way around.
Old 09-20-2011, 09:49 PM   #3147
mikerbike
Either you're high, or you're looking at the pictures backward. The top picture is my left wheel, bottom is right wheel. Both wheels are at full lock to the left. I took them standing behind the wheels.
And when I wrote that, I was confused about leading & trailing wheel. I was thinking the wheel in front while drifting was the leading wheel.
Old 09-20-2011, 09:54 PM   #3148
mikerbike
And now I read your post again, and I'm confused again. The 'leading wheel' is the wheel that follows during a drift, correct? Because if one were gripping the same corner, it would be the in front. Argh. Confusing.
Old 09-20-2011, 10:28 PM   #3149
Otto347
Otto347's Avatar
Otto347 is an unknown quantity at this point
Well then why would they call it leading as opposed to following......
Originally Posted by atutt View Post
Or you could have stopped being a lazy asshat and done some research.
Otto347 is offline   Reply With Quote
Old 09-21-2011, 12:15 AM   #3150
95KA-Turbo
95KA-Turbo's Avatar
I was a little worried they wouldn't allow my LCA to clear my rotor since my LCA is spaced down as well. Luckily they have more then enough room!
Instagram - SJKnoop
anti-squat, best thread ever, kpi, roll center, steering angle, suspension
