11-21-2011, 12:57 PM | #1 |
Godspeed Project Hydraulic E-Brake Type-2
These are going for: $100 Picked-Up OR $120 Shipped! (California customers please add 9.25% to shipped price!) Now on sale is our Type-2 Hydraulic E-Brake in these three colors: ( BLUE, BLACK, & RED ) Godspeed Project Hydraulic Handbrake Kit is a high quality aftermarket handbrake that is essential for any drift or rally vehicle. This is a universal product that can be installed into any vehicle and is specifically designed for Track or Drifting. The drift handbrake allows the rear tire to be fully locked and will make your vehicle slide to the side. The handbrake lever can either be installed in a VERTICAL or HORIZONTAL position for easy access while driving. The hydraulic system connects onto the brake line that runs to the rear calipers and requires a lot less force to completely lock both rear wheels when needed. A hydraulic handbrake is used by drivers to lock up or break loose the rear wheels when they want to Drift the car sideways or spin on the spot. Drivers regularly need to turn hard left or right and there's not enough wheel lock to achieve doing so otherwise. A hydraulic hand brake can be added into the rear brake line system without changing the original mechanical handbrake setup. This handbrake can be mounted in horizontal or vertical positions as shown in the pictures below! Product Features: - Steel bracket- less flex and better actuation to the master cylinder - Made with high quality CNC Aluminum - Purpose design 3 /4 master cylinder to lock up even large 2 port rear brakes as found on skylines. -Adjustable pre-load and pin locations allow for a custom height and feel to suit your application - Can be easily change to vertical or horizontal alignment by removing one bolt and clip - Ratchet mechanism for use as a normal hand brake. This can be disabled during drift by flipping it in the off position - Universal installation for any vehicle - Perfect for drifting , Track events - Able to fully lock the rear tires Here are the rest of the pictures:
Godspeed Project 2518 Continental Ave El Monte CA 91733 P: 626-442-3988 W:godspeedproject.com www.facebook.com/godspeedproject |
11-23-2011, 10:43 AM | #3 |
Still have this in stock!
11-28-2011, 07:36 PM | #4 |
50% off sale going on today, last day.
http://zilvia.net/f/advertiser-announcements-feedback/420917-godspeed-project-black-friday-special-50-off-msrp.html
11-29-2011, 11:41 AM | #5 |
These V2 ebrakes are still in stock!
11-30-2011, 11:02 AM | #7 |
Still have these in stock ready to ship or be picked up!
12-01-2011, 10:48 AM | #8 |
Still have these e-brakes in stock!!!!
12-02-2011, 02:51 PM | #9 |
Ver2 Instock!
12-05-2011, 03:33 PM | #10 |
In stock available!
12-06-2011, 11:20 AM | #11 |
In stock ready to go!
12-09-2011, 10:44 AM | #13 |
12-12-2011, 02:41 PM | #14 |
Still have these available!
12-14-2011, 10:53 AM | #16 | |
No we do not offer the brake lines or fittings. There are a few good DIY write ups on zilvia for installing a Hydraulic E-Brake, try to search for one that can guide you on what hardware is needed to install.
12-15-2011, 01:25 PM | #17 |
12-16-2011, 10:48 AM | #18 |
Have these available!
12-16-2011, 04:49 PM | #20 | |
We do not offer those as of now. If we do it will be posted.
12-19-2011, 10:54 AM | #21 |
E-brakes in stock ready to go!
12-20-2011, 10:41 AM | #23 |
Still have these in stock ready to go!
12-21-2011, 11:47 AM | #24 |
12-22-2011, 10:59 AM | #25 |
I still have these available for pick-up or to be shipped out!
12-23-2011, 01:25 PM | #26 |
This is still available to order!
12-26-2011, 12:15 PM | #27 |
Still have these available in stock!
12-27-2011, 04:04 PM | #28 |
Still have this offer available!
12-28-2011, 12:31 PM | #29 |
Still have these available to order!
01-02-2012, 04:07 PM | #30 |
bump for an ebrake that can be mounted both ways, other ebrakes dont do that!
