Old 12-29-2011, 03:56 AM   #31
mattack69
mattack69's Avatar
mattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enough
Send a message via AIM to mattack69 Send a message via MSN to mattack69 Send a message via Yahoo to mattack69
This thread makes me happy on the inside. GJ!
mattack69 is offline   Reply With Quote
Old 12-29-2011, 05:56 AM   #32
Br Dori
Br Dori's Avatar
Br Dori is an unknown quantity at this point
I'm just wondering if you had a 2j motor why did you decide to keep the 1j head, why not just put the whole 2j in there. You prob said it somewhere and sorry if you did, I want to do a 2j swap on my s14 so I just want a opinion before I start buying everything. OH and beautiful swap and car I am very jealous.
www.FlawlessMotion.net
Br Dori is offline   Reply With Quote
Old 12-29-2011, 08:05 AM   #33
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
He already had head work and cams on the 1j.
SW Fab
shiftdrift is offline   Reply With Quote
Old 12-29-2011, 11:38 AM   #34
aled
aled's Avatar
aled is an unknown quantity at this point
Ding ding!
Exactly xD
Really the cams made the difference. The HKS cams for these engines are stupid expensive. Also, I do go to school away from where the car is located, hence why I've been working on this non stop. I would have love to have a complete 2JZ, but this route allowed me the quickest, cheapest way to have my car up and running.
Thanks for the compliments everyone. More progress today I hope!
aled is offline   Reply With Quote
Old 12-29-2011, 12:15 PM   #35
derek king
derek king's Avatar
derek king will become famous soon enoughderek king will become famous soon enoughderek king will become famous soon enoughderek king will become famous soon enough
Jesus you do real work.
IG DearDerekKing
derek king is offline   Reply With Quote
Old 12-29-2011, 12:20 PM   #36
Phate
Phate's Avatar
Phate is an unknown quantity at this point
Good job buddy. Can't wait to see it out and about next season.
I wanna slide.
Originally Posted by nate1 View Post
8. they all smell funny
Phate is offline   Reply With Quote
Old 12-29-2011, 12:28 PM   #37
taeisbeast
taeisbeast's Avatar
taeisbeast is an unknown quantity at this point
great work here.
keep it up.
taeisbeast is offline   Reply With Quote
Old 12-30-2011, 12:28 AM   #38
aled
aled's Avatar
Successfully fired the engine tonight. I'll update later with a video of the initial start.
Old 12-30-2011, 01:14 PM   #39
N2HIFI
N2HIFI is an unknown quantity at this point
Originally Posted by blingbling View Post
It sounds like he's referring to drifting on a competitive level, in which case there would probably be a noticeable amount of understeer based on the weight and placement of the motor. I don't believe the weight of this swap would be the issue, but the placement of the motor and how far back/low it is mounted to attain proper weight distribution. /end thread jack
By competitive are you talking FD? cause i do events monthly.. this is my track car and is very purpose built. I'm running MDU events and will probley hit as many pro am/xdc events i can this year.
and i have very little understeer, if anything my car has oversteer, like i said no plowing and im only running a 215/45/17 in the front of my car
N2HIFI is offline   Reply With Quote
Old 12-30-2011, 02:01 PM   #40
aled
aled's Avatar
Old 12-30-2011, 04:19 PM   #41
h815 240sx
h815 240sx is an unknown quantity at this point
1st: 35 ft. lbs.
2nd: 90 degrees advanced from the previous position (~55 ft. lbs.)
3rd: 75-80 ft. lbs.
I did use the ARP grease provided on the threads, washers, and nuts.
That is correct they are Avid motor mounts. I paid, $120? I can't remember. Great mounts; Yes, they are solid, the air vents rattle at 60 mph, but I never cared, but were not annoying or disruptive at idle.
Hahaha thanks. That is at a friends house, I thought the same thing about that tree.
Stand corrected on the torque, checked my own sheet, my bad.
and as for the the motor mounts, I guess i should have said engine instead of motor. Mounts that bolt to the block, not crossmember.
h815 240sx is offline   Reply With Quote
Old 01-08-2012, 12:57 PM   #42
GreddyReadys13
GreddyReadys13 is an unknown quantity at this point
what did you do for your exhaust? im assuming custom work but how much clearance do you have and where does it run to
GreddyReadys13 is offline   Reply With Quote
Old 02-06-2012, 11:37 AM   #43
aled
aled's Avatar
Update for everyone.
Engine starts, runs, and idles great.
I've been running through the car fixing leaks, however. The heater hose pipe leaked, but is fixed. Next, apparently the oil drain gasket on the turbo broke, and leaked oil all over the manifold. I am going to re-make the -10 drain line with new gaskets and AN fittings.
Only concern remaining is confirmed seal of the headgasket.
Now, when we first started the engine, there was considerable white smoke exiting from the exhaust.
- Ran the car for about 10 minutes achieving about 140 degrees, slightly milky oil cap.
- Drained the oil with surprisingly almost no water/coolant in the oil.
- Fresh oil, started again, ran for 15 minutes achieving nearly 170 degrees.
Once the oil leaks are 100% fixed, I'll have a much more accurate confirmation of a proper headgasket seal.
I will be back in town in about a week to work on the car again.
- Alex
Old 02-06-2012, 11:48 AM   #44
aled
aled's Avatar
http://www.youtube.com/watch?v=Ml8SpzmXJ3A
Just a short video of the exhaust to show the usual white smoke from improper headgasket seal has cleared up.
Old 02-06-2012, 05:57 PM   #45
Prove It
Prove It is an unknown quantity at this point
good deal. i was going to say you should have copper coated your Head gasket.
Prove It is offline   Reply With Quote
Old 02-06-2012, 06:12 PM   #46
DrftKingIII
DrftKingIII's Avatar
DrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura about
- Alex
hfjkdaghfjkdag
- このノイズをファック -
DrftKingIII is offline   Reply With Quote
Old 02-06-2012, 06:29 PM   #47
1J240
1J240's Avatar
1J240 is an unknown quantity at this point
looks good man. you've just made me want to go 1.5 with my JZ.
1J240 is offline   Reply With Quote
Old 02-06-2012, 07:10 PM   #48
gobackwards
gobackwards's Avatar
gobackwards is an unknown quantity at this point
sick, dude. What spring rates are you running??
gobackwards is offline   Reply With Quote
Old 02-06-2012, 11:53 PM   #49
mxkilla450
mxkilla450's Avatar
mxkilla450 is an unknown quantity at this point
what did you do for the oil galley on the head [by cyll 6?]
mxkilla450 is offline   Reply With Quote
Old 02-07-2012, 09:16 AM   #50
tuktuk23
tuktuk23 is an unknown quantity at this point
effin dope!
tuktuk23 is offline   Reply With Quote
Old 02-07-2012, 09:47 AM   #51
Black R
Black R's Avatar
Black R is an unknown quantity at this point
Ding ding!
Exactly xD
I was wondering the same thing also, so good to know.
Is the 1j exh mani able to fit the 2j head?
And how did your old motor detonate?
Was it bad gas, over boost, or what?
Btw, you're gonna love that 2j bottom end.
The extra .5L is noticeable down low and out of boost.
It also helps to build boost quicker.
And IMO, get a retune.
Black R is offline   Reply With Quote
Old 02-07-2012, 09:56 AM   #52
aled
aled's Avatar
Originally Posted by DrftKingIII View Post
hfjkdaghfjkdag
HEY
Thank you.
Only do so if you blow your 1JZ up...
Powered by Max Coils 10/8.
This is the GTE engine.
As I understood, oil modifications were required for the GE bottom end.
No, the exhaust manifold won't fit. Had that been the case, I would have just thrown the 2J in there and rebuilt the 1J on the side.
Old Motor detonated with bad gas X__X
Old 02-07-2012, 10:08 AM   #53
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
How much did you end up spending? You can pm me if you dont wanna tell the whole world. i've been researching this and several other options and i got it down to 1jz vs ka-t. good job on your build, read your entire other thread too, shit looks amazing
collegekid is offline   Reply With Quote
Old 02-07-2012, 10:12 AM   #54
IBoughtAS13
IBoughtAS13 is an unknown quantity at this point
Oil modifications are not need for the 1.5JZ. I have all three, a 1JZ, 1.5JZ and a 2JZ. The feed hole is on an incline.
How do I know, I did a huge write up on SupraMania.com in the 1JZ section. "JZ Swap Guide For Dummies". Name is IBoughtASupra on there where I sell catch cans as well
IBoughtAS13 is offline   Reply With Quote
Old 02-07-2012, 01:08 PM   #55
aled
aled's Avatar
A fair amount for such power levels.
As far as the JZ vs. KA-T, cost discrepancies will be significant.
Build what best suits your budget and ability to maintain the engine.
Great!
I've been through that thread a few times. I'll be sure to contact you if I have any further questions regarding this headgasket sealing issue.
Old 02-07-2012, 08:54 PM   #56
driftwhat
driftwhat's Avatar
driftwhat is an unknown quantity at this point
Wow nice work man, keep it up.
I love haters!
driftwhat is offline   Reply With Quote
Old 02-19-2012, 09:20 PM   #57
aled
aled's Avatar
Just a small update.
The 1.5J is now running beautifully. Even drove it up the street today.
Anyways, the previous -10 oil drain I used on the 1J was too long. Oil was backing up and blowing out the gasket and through the seals in the turbo. I drastically shortened the oil drain which quickly alleviated that issue.
I then ran the car for a solid 45 minutes, bled the cooling system. The next day, I compression tested the engine.
Bam. Perfect compression across the board. What a huge sigh of relief. Drove the car around, idled at 13.5:1 A/F Ratio. Over spring break in a few weeks, I'll get the engine re-tuned for the extra displacement of the 2J bottom end.
Turbo off to change the drain line. Probably the 5th or 6th time I've had it off in the past two days...
About to compression test the engine. Hanging out with the 86 190E 2.3 16V.
Oh yeah, then I sold all my drift spares and got all matching wheels !
Put in my matching Recaro too!
So long for now.
Trying to track down a HKS DLI. I'll wire that up, take it to get dyno tuned. With the HKS DLI, 2J Bottom End, and the same boost level as the 1J (18.5 PSI) I expect about 550 wheel, and about 470 torque...
I'll be sure to actually take a video of the dyno this time xD
Old 02-22-2012, 09:05 AM   #58
robots
robots is an unknown quantity at this point
What turbo do you use ? What turbine AR ? When is full boost ? On 1jz compared to 2j ? How is response ?
robots is offline   Reply With Quote
Old 02-22-2012, 10:16 PM   #59
aled
aled's Avatar
60-1, .70 A/R
I was about full boost on the 1J just under 3,800 RPM.
I don't know on the 2J yet. I need a re-tune before I can even think about boost. I'd imagine with the extra displacement the spool time will only get quicker.
Old 02-28-2012, 11:59 AM   #60
IBoughtAS13
It will be much fatter under the curve. You will hit that boost even about 800-1000 RPM sooner. That 60-1 will spool utterly quick, a 6262 will be in your future. It avoids the lag of a 67 and is super responsive for your power level.
