Old 01-08-2012, 05:27 PM   #1
nissan-fanatic
nissan-fanatic's Avatar
nissan-fanatic is an unknown quantity at this point
Trunk problem
Hey guys, I been having this problem with my trunk. The Dang thing will not close right! I tried adjusting the hinges but does not work. The trunk just stays loose and when I drive the thing rattles like crazy! Most likely it was caused from the previous guy who put the manual tranny in the trunk and forced it closed. Will a new trunk fix it?
nissan-fanatic is offline   Reply With Quote
Old 01-08-2012, 06:31 PM   #2
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
We need pics.
Mishkin_707 is offline   Reply With Quote
Old 01-08-2012, 06:36 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You dont adjust the hinges, you adjust the catcher to make sure the trunk is snug.
CLICK HERE!!!
Old 01-13-2012, 07:52 AM   #4
nissan-fanatic
i adjusted the catcher many times and still doesn't work... i'll post pics up when i get back in town... oh and also i can't even open it with the handle inside. i can only open the gas cap. and if it helps any... i have to open the trunk with a separate key from the one i use to unlock my driver door, but i can use both keys to turn the car on. hope that helps to give u guys an idea
Old 01-13-2012, 08:23 AM   #5
projectblak
projectblak is an unknown quantity at this point
mine was the exact same way i lowered the catcher all the way and it was still not sitting flush and still gaped. i went to pull apart grabbed a better catcher and drilled a lower hole for the catcher and now it sits perfectly, no water leaks or f***ing ugly alignment. i still don't know y it was doing that maybe a bad trunk....good luck
P.S. on your lever problem there is a metal line that connects to the catcher make sure its in there right i don't use mine i just use my key. i have 2 keys only one opens the trunk and the other starts the car and neither open the door lol.
projectblak is offline   Reply With Quote
Old 01-13-2012, 08:30 AM   #6
nissan-fanatic
i did that with mine too but the latch won't catch if i go lower than normal
Old 01-13-2012, 09:10 AM   #7
OBEEWON
OBEEWON's Avatar
you need to replace or buy those rubber stop pads.
Old 01-13-2012, 09:11 AM   #8
projectblak
hmmmmmm maybe u have a bent trunk do u have any friends with s14 maybe swap their trunk over to yours its only 4 bolts and see if that helps
Old 01-13-2012, 12:31 PM   #9
Mishkin_707
I know on the S13 trunk lock there is a little lever you move it down and it locks the trunk So if someone breaks In your car they can't use the handle to open the trunk, do the S14's have this lever? That could be why it won't open from the handle inside the car
Old 01-13-2012, 01:18 PM   #10
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
^yes the s14 has one as well
instagram
1on1 is offline   Reply With Quote
Old 01-13-2012, 01:22 PM   #11
nissan-fanatic
idk if my trunk is bent but when i got the car the guy had put the manual tranny and parts in there and seemed like he forced it closed and now i got this problem
Old 01-13-2012, 01:23 PM   #12
onehundredoctane
onehundredoctane's Avatar
^THIS. A thousand times THIS.
Old 01-13-2012, 01:25 PM   #13
nissan-fanatic
ur talking bout the blck rubber part that goes all around the edge?
Old 01-13-2012, 01:33 PM   #14
Zapiel
Zapiel is an unknown quantity at this point
Not to thread jack, but I also have trunk problem. I have a 90 fastback and whenever I drive on the freeway going like 65-75mph, it gets really loud in the back. Any idea what it can be? Thanks
Zapiel is offline   Reply With Quote
Old 01-13-2012, 01:43 PM   #15
onehundredoctane
NO. That is just the weather stripping to keep the water out when it rains. There SHOULD BE (but from the sound of it proabbly aren't) black rubber stoppers that are under the trunk lid that keep the trunk from moving up and down. They are probably just empty holes now if you're having this problem.
Old 01-13-2012, 02:32 PM   #16
nissan-fanatic
ah ok... i'll go ahead and check that when i get back in town...
Old 01-17-2012, 02:20 PM   #17
nissan-fanatic
ok... i changed out the rubber stoppers things... they seemed good but still replaced them. also was missing one... but... still have that rattle problem... wat else to check? i need to see another s14 to checkout the trunk... i'm going crazy! and i don't see or know anyone here who has an s14... i've only seen s13
Old 01-18-2012, 06:32 AM   #18
Wreckless35
Wreckless35's Avatar
Wreckless35 is an unknown quantity at this point
Send a message via AIM to Wreckless35
I'm dealing with the same EXACT issue with my kouki. Been rocking it for almost 2 years and done everything short of remove the trunk. I have plenty of s14 friends and I don't know why I haven't thought of swapping with one of them but now I will. Let you know what happens.
Here's a pic for those of you that don't know what we're talking about:
Originally Posted by jasoncanseeoh View Post
fucking gangster.
Wreckless35 is offline   Reply With Quote
Old 01-18-2012, 08:14 AM   #19
projectblak
^^^^ whoa thats a big gap lol mine wasn't like that its either ur catcher is to high or ur trunk is bent badly but u don't notice it in my opinion... even check the bars that bolt to the trunk they may be bent
Old 01-18-2012, 09:46 AM   #20
Darren
Darren's Avatar
Darren is an unknown quantity at this point
just looks like the catch is way too high... the lift bars being bent wouldn't cause this IMO because the gap at the bottom of the trunk is pretty even.
Check the bottom part of the latch / catch bar mechanism. it has slotted mounting holes so that you can move it up and down, try moving it all the way down, and make sure there are no spacers making the catch bar lower than it should be.
I had a very similar problem on my s13's hatch when i first got the car, some previous owner had put washers under the catch bar to space it down to "fix" the rattling hatch. all i did is return everything to normal and set the latch down more and now it's perfect.
Good luck
Darren is offline   Reply With Quote
Old 01-18-2012, 10:45 AM   #21
nissan-fanatic
Thumbs up
YES YES YES!!! THATS EXACTLY MY PROBLEM! i already moved the bottom latch/catch all the way down and still doesn't work... let me know when u try a friend's trunk on it... if that fixes it then i'm buying a new trunk!
Old 02-03-2012, 04:35 PM   #22
nissan-fanatic
Has anyone tried a new trunk yet? I will hopefully tomorrow
I like to handle my s14 like I do my woman... Sideways
Old 02-03-2012, 05:41 PM   #23
fliprayzin240sx
The cross bar that the bottom catch is attached to may be shifted. My Silvia in Japan had this issue, I had to bang it out a bit to actually line up with the latch in the trunk hatch.
CLICK HERE!!!
Old 02-03-2012, 05:59 PM   #24
Wreckless35
I am actually doing that tomorrow. I'll let you know what happens.
fucking gangster.
Old 02-03-2012, 06:19 PM   #25
nissan-fanatic
Mine are lined up already. Don't look bad either.
Right on bro let me know asap before I buy one
Old 02-03-2012, 06:48 PM   #26
fliprayzin240sx
Just because its straight on doesnt mean its lined up properly. Im telling you, the latch is more than likely shifted. When you adjust the catch, it only moves up/down and a lil bit side to side. The issue you have is the whole thing its bolted to. Like you said, the previous owner had some heavy shit in there that could have rolled and pushed the whole trunk back so the catch is out of alignment physically.
CLICK HERE!!!
Old 02-03-2012, 08:19 PM   #27
nissan-fanatic
I'll double check that tomorrow and let u know
Old 02-03-2012, 10:58 PM   #28
JKL1031
JKL1031 is an unknown quantity at this point
the angle of the bottom latch plays a SIGNIFICANT role in the gap, and how tight the trunk closes. I fixed this issue on my s14 but only using the top bolt on the lower striker, and twisting the bottom of it to the driver's side.
Try playin with the angle of the striker more, remove the bottom screw and angle it some ,but u will only have to use one screw since the bottom holes will be off centered,but ur trunk will be straight.
JKL1031 is offline   Reply With Quote
Old 02-03-2012, 11:28 PM   #29
jesse_s13
jesse_s13's Avatar
Apply Tape to the inside of the Latch. IT FUCKING WORKS!
jesse_s13 is offline   Reply With Quote
Old 02-03-2012, 11:31 PM   #30
JKL1031
it works for 5 open and close cycles of your trunk..
