#2341 |
![]() Join Date: May 2009
Heres mine<
S14 SR Cp pistons 86.5 eagle rods cometic hg ebay intercooler homemade manual boost controler 3'' turbo back airnix 3angle valve job GT2871R .64 SAFC TUNED :O result: 330whp- 296 wtq on dynapak +- 18psi Last edited by koukistylejdm; 01-27-2012 at 09:05 AM.. Reason: forgoten |
#2342 | |
![]() Join Date: Oct 2004
#2344 |
Hey CodyAce or anyone else.
Well I currently have HKS 264/272 Step2's and was wondering if I want to keep some mid end, should I stick with a stock manifold or really go with a Freddy cause the mid-end power wouldn't make that big of a difference? Drive train is a 4.36 final S15 HLSD, Steel one piece drive shaft, and fidanza flywheel. Mostly track...
#2345 | |
But I would go 100 or better on the track, but depends on your ambient temperature too as well. Safe better than sorry
#2347 |
Hello, I am buying a new turbo setup next month and would really appreciate some quick advice. I have been reading through this thread but there is a lot to read.
My question is would i be able to reach 350+ hp by adding GT2871r .64 larger injectors (not sure what size) epiphany tune manifold Or would i need cams also to reach that goal OR a .86? And is there anything im missing that i would need or what would be some good options? Here is my current setup that has been run for a few years. S14 SR20ET Kouki motor Greddy intake w/ greddy filter Z32 MAF TOMEI 555cc injectors TOMEI RAS SAFC II Trust turbo elbow GP Sports downpipe, cat delete pipe Buddy Club Spec II exhaust TOMEI Oil block adapter Earl's Oil Thermostat
FOR SALE |
#2348 |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
Man I need to figure out how to re-subscribe to this thread. Doesn't show up in my userCP.
Anyways, me and Codyace did discuss cams options and I am indeed going with JWT S3 cams. I've already returned my BC valvesprings/retainers. Just waiting on this tax return lol
IG/TikTok-ThatS14_Z06guy |
#2349 |
Trader Rating: (26)
Guess who's #2 cylinder is 50psi low on compression?
Time for a rebuild....again... Now the hard part, choosing pistons. Wiseco CP Toda even? WHICH ONE?!?!
#2350 | |
It's Always Broken.
![]() Join Date: Feb 2010
![]() Feedback Score: 14 reviews
I'd go with Wisecos. Just personal preference though.
#2352 |
Trader Rating: (26)
I'm honestly between Wiseco and CP
I have Wiseco right now. 87mm. Got 10,000+ miles out them and for a good 1000 miles the engine was running like absolute garbage. I blame that on the early failure. My main concern right now is whether or not I have to go up a size or not. I don't want to go up because I dont want to get the block sleeved. :/ Edit-I am kinda glad this happend. Now I can send it to the shop and when it comes out it is done. I'll break it in, take it back to the shop for cams and avcr and a tune then finished. I wont touch it any more.
#2353 | |
#2354 |
Thanks SR20DETpwr.... do you have a higher res picture of your dyno? I can't see RPM's and HP/TQ cross as well.... That would help a lot. Thanks!
#2355 |
![]() Join Date: Feb 2011
So is there anything wrong with getting the compressor cover that bolts right up? or should i get a regular one? will it limit me power wise?
should be ordering stuff before the end of the month. think im going to go with id1000 injectors, as long as enthalpy says they are cool. how much boost do you think i can run with a hks wastegate? i know the internal gate limits you a bit. |
#2356 | |
'89 hatch DD'd SR'd 2871'd - Sold 2006 Legacy GT Wagon |
#2357 | ||
![]() Join Date: Dec 2004
Trader Rating: (58)
QUOTE=EsChassisLove;4488191]WHICH ONE?!?![/QUOTE]
I prefer the CP stuff, however I'd be curious as to how good the bore/block is, especially with you being at 87mm. Quote:
![]() Quote:
#2358 | |||
Trader Rating: (58)
Without a doubt putting in new stuff will not hurt anything on paper...I mean we are dealing with (essentially) junkyard engines once most of us get them. However in the same regard, just throwing any old parts at an engine is not to say that it will prevent harm/damage in actuality. Just installing big springs on an engine, that have not been RD'd, nor have any sort of meaning aside from a ton of seat pressure is just 'parts changing' if you ask me. Sure the bigger seat pressure will work (again on paper) but there is certainly a point where you can have too much, and to tight of a spring...that causes bad VooDoo in the valvetrain, and breaks stuff. 400 whp has been achieved on countless cars on stock valvetrains (minus cams) forever now...reliably at that. Gotta remember these engines are new to you and I, but were OEM 15-20 years ago to Japanese and European tuners...and lets also not forget how many Front wheel drive turbo owners existed before many of this forums current users even knew what a 240sx was. Quote:
To me, it's not worth the risk on skimping out at the last moment, or even spending money when you do not need too. Stock valvetrain failures? When...it's been a long time since seeing an SR20 have a spring break. BC stuff....well..... Quote:
1. How are the cams junk? Odd how JWT cams have time and time again made the best power, and broadest power band. How is it that JWT also designsmakes the cams for most of the Nissan Factory efforts? I mean...a company that actually designs something, and actually tests them...you're calling junk? I'd love to know how or why. Companies like JWT wouldn't exist for as long as they have, wouldn't be used across a variety of engines like they have, and wouldn't be referenced by Nissan race teams if they had junk cams...or parts. 2. Canned tunes. Enthalpy and JWT have been sending ROM tunes out for over a decade now both. Can you point me to instances where either of their tunes has specifically blown up a car? Maybe a few (they are not perfect) but that's over THOUSANDS of cars. Sure we can find many examples of a car 'not running right' with them, but 9.7/10 times those same cars that have 'bad tunes' often are plauged with other issues, that the tuned ECU only mulitplies. As above, I'll never argue that a a rom tune from JWT or Enthalpy is better than a dyno/properly tuned car...a GOOD tuner with the RIGHT software and EXPERIENCE will always create a better experience/car. The thing is, just because someone CAN tune a car, does not mean they KNOW how to tune a car...and all it takes is this thread alone to show you countless 'tuned' cars that don't come close to the results that my car, or others that have similar setups to mine. My car is not magical, it's built with good stuff, and the right parts, and on IMO a tune that is super safe (I've got more track miles then some have street miles) and it oddly has been one of the highest producing, most reliable, and referenced 2871r car for quite some time now...and there is a reason for that. Is it 'beatable'? Sure...in fact there are guys who have made more power than I have. There are guys who have been around as long as I have too...so I'm not naive to the other methods. Thing is, all of the examples surpassing mine...(which I can count on half a hand) are COMPETENT tuners, who also have similar parts (or other awesome setups). Could I fine tune mine? Sure...I know things I'd like to change to really get the last 1/10th out of it all, but in the same regard, I'm not that interested. It's fun, it's fast, it doesn't have issues...why change it up?! 325-350whp on a typical street car setup is fine...and you can cut corners there...but if you want a true SR setup that makes 400whp, that is as reliable as it came from the dealer (well the engine, can drive to Montana, or drive at Limerock...then you need to spend money where it counts, and to spend it with a reason...not just parts changing and believing what the box says. So in the end we may just need to agree to disagree. With that in mind, I'll gladly go out for beers with ya too anytime you're in the area. I do like Wild Ales though ![]()
#2359 | |||||||
![]() Join Date: Apr 2011
![]() Quote:
![]() Quote:
![]() Quote:
You are also right when it comes to why change it, if you're happy with you're setup than that is completely perfect to you, however we also gotta remember that some people prefer more power out of their setup, and with the SR no matter how much $$$ I had in my life I would never want to surpass 400 HP with it, IMHO you're asking for a lot of failure and trouble after that point, and again it has proven to hit 400+ but at what cost ??? Quote:
![]() I like it when people are able to talk engines and tuning in a respectful manner instead of using bashing techniques ... I will definitely look you up when I'm in the east coast to grab a drink and please do the same when you're in TX feed you some good meat LOL |
#2360 | |
![]() Join Date: Jun 2006
FINALLY I finished reading this whole freaking thread after 2 weeks. Lol I don't spent a lot of time read much! I love this thread so much I've learn sooo much it isn't even funny. =D
I kinda of wished I read this thread before I bought this car. I was a noob to turbo's and motor and I still am. All I know is suspension and driving. It's helped me win my class in autox last season! Anyways this is what I bought. SR Blacktop no VVT HKS Step 1 Cams Greddy intake manifold HKS head gasket CP pistons 9:9 cpr Carrilo pro rods Acl race ser rod & main bearings Micro polshed std crank Fake HKS ssqv bov Greddy (need to replace it...) Garret GT2871R .64a/r ball bearing turbo with exhaust upgrade from Garret trim .64 a/r 52 / 76 with a larger exhaust housing With water cooling kit (I think I said that right..) Denso 3 bar map Peak performance tubular manifold Sard 850cc Injectors PFC EMS And all the other supporting mods Here's my lil story. Sorry for my english if it sounds wrong. I have a dyno pic of this making 422 whp @ 22 psi with water/meth kit and had HKS step 2 cam. This setup was running rich. So I wanted a retune since I was making like 12 mpg which was a no go. A few weeks ago one of my friend thought it'd he knew what he was doing when it was going through my FC and reset my FC so I lost my tune. The tune was locked before hand so I couldn't save it and the guy I got it from said he can't get the tune bad since the guy that tuned it went bad to Japan so I was FUC---! Currently I just barely got it running with the help of Steve and his base maps. We're having a small problem with the INJ map since PFC is designed to work up to 740cc and 850cc is a lot bigger. I was have weird ass idea issue and power. If anyone has some basic INJ maps that are using Sard 850cc I could use your help!!! I really don't want to trailer or tow the car all way down to LA. I'm pretty sure I'm going to stock Exhaust MF and send it to ace for the all of that stuff. So I can get some quicker spoils and not have worry about shit breaking. I'm pretty sure I also left out a lot of info about the car and the other reason of post this. It's 4:30am and I'm BORED out of my mind now since I've finished reading this thread and I don't wanna read anymore. LOL.
#2363 |
i believe you need the wastegate bracket for an s14/15 turbo for it to work correctly. when i got my hks wastegate, ken sent me the s14 one so hopefully it works when i get my turbo in.
#2365 |
![]() Join Date: Jan 2008
hey tabasco will you let me know how that works out for you? I think i need a new one and dont want to drop 80 on the same one when i can get the hks one for 120.
#2368 | |
Trader Rating: (58)
That's the main reason I went external wastegate (as well as now sell them) for guys looking for a no worry/hassle free setup.
#2369 |
I haven't had any issues with my HKS actuator and Greddy Profec B Controller (@18.5psi)
but i will also be changing to external shortly, its undeniably more efficient, just as codyace has stated. |
#2370 |
![]() Join Date: Sep 2011
I have finally read this whole thread in 2 days... apparently hks actuator is useless, I've already got my tomei expreme manifold, is it possible/should i get an external flange welded on? do i need clocking plates for bottom mounting the 2871 [.64] to my s13 redtop? also Im pretty set on JWT S3 cams after seeing all the good talk about them in this thread, can someone post a link/pm me a link where to buy them? i can't find them.
