01-30-2012, 11:47 AM | #121 | |
01-30-2012, 05:36 PM | #122 | |
01-30-2012, 10:28 PM | #125 |
Trader Rating: (79)
Feedback Score: 79 reviews
anyone need a Pressure Plate?
http://zilvia.net/f/sale-items/42764...ate-cheap.html
My Build: The "Coupe De Ville" 1JZ Build!! |
01-31-2012, 06:57 PM | #126 |
How is everyone running there hot pipe with the fuse box right in the way? I want the pipe to as simple straight as it can but i dont see it with out cutting more of the car, any pics would be great, thanks
93 s13 coupe 5 speed- Ls2 swap in the works 97 sc300-gte/v160 |
02-03-2012, 09:40 AM | #132 |
Ill add to this as well.
You can check the blog out for more pics and updates as stuff gets done. I have alot to do still. Car is going to be full track car. Needs cage, cell, and alot more till its done. Focus lately has been on new chassis harness and redoing engine harness.
http://allies-drift.blogspot.com/ |
02-14-2012, 08:31 AM | #135 |
It's is actually a green to purple flip. It is not going to stay that color though.
It eventually will be silver to match the bay and the covers will be black to match the exterior. Or maybe vise versa.
02-14-2012, 09:33 PM | #136 |
do any of you guys happen to know the specifications/ measurements to have a custom drive shaft made for the 2j into an s14? im looking into shaft masters, their pricing seems pretty reasonable
02-14-2012, 09:36 PM | #137 |
Your best bet will be to get under the car and measure it yourself. That's what they had me do. thwy will tell you exactly where/how to measure. Good guys, thats where i got mine from and I love it.
02-15-2012, 12:53 PM | #139 |
also do you guys know if you have to modify the cross member to run the ebay mounts? Im also looking into The Turbo Dave's mounts which i know for a fact you dont mod the cross member, but if i can get by with the ebay ones that would help out a little
02-16-2012, 11:09 AM | #144 |
i feel the same way, im even friends with a guy that works for them and i can barely ever get ahold of him. I might just opt for the ebay mounts just to save a few bucks that i can put towards a nice harness
02-16-2012, 11:21 AM | #145 |
from everything I've seen and everything I've done there's really no need actually buy a wiring harness when you can just do the wiring yourself and save about 500 dollars
02-16-2012, 09:56 PM | #147 |
i really dont even want to attempt doing that harness id rather have somebody that knows what theyre doing wire it up so i know im getting it back 100% working order
02-17-2012, 05:16 AM | #149 |
Figure id throw it out there.
My swap is mounted with the Ebay mounts. dropped in very easy. trans mount lined right up to the R154 with no issues too. Just leave it all loose when your putting it in and then tighten it.
