Old 03-31-2012, 01:43 AM   #1
violak90
violak90's Avatar
violak90 is an unknown quantity at this point
s13 KA24de Check engine light
(1992 240sx hatch KA24DE (s13))
I bought the car a few days ago, i test drove it 20 miles, No light. I buy the car, i drive it 3 hours home. About 150 miles in, engine light comes on. I drove the car a bit wild around some of the turns, and a few times when i was testing the cars limit I noticed that the light went off, and then came back on. (someone suggested "knock?" sensor?) Car had No cat, straight pipe. Also, leaking power steering fluid. I fixed the power steering leak, and put a cat on it. (hopefully the correct way, doesn't sound funny or anything) I disconnected the battery for an entire day while working on the stereo. I reconnected the battery later that evening, and started the car; the engine light is still on. Any ideas? I can't drive the car to a shop until I register it on Monday, (police are bored and looking for reasons to pull people over out here) so I was just hoping for some idea's to try and solve this light issue before I take it into a mechanic.
Or if there is an easy way to read the OBD code without a reader x_X
thanks for your time
violak90 is offline   Reply With Quote
Old 03-31-2012, 02:17 AM   #2
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
first car? why dont you check the code the ECU is flashing, you do know where the ECU is at, right?
andisan is offline   Reply With Quote
Old 03-31-2012, 02:22 AM   #3
violak90
violak90's Avatar
first car that im working on myself. I didn't know you can check a code just by looking at the ECU, i thought you needed an ODB reader lol, thanks
Passenger side kick panel according to google, ill google reading the ECU itself and figure it out, thanks
Old 03-31-2012, 02:24 AM   #4
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
Feedback Score: 82 reviews
yes!!!! he can search!
NEED Bolt kits for your car?
Old 03-31-2012, 02:28 AM   #5
violak90
violak90's Avatar
LOL google is my best friend...forums are always last resort =P
Appreciate your help guys, found the ECU reading guide, and will find the solution to my problem tomorrow!
Board Closed!
check engine light, ka24de, obd, s13 240sx
