Old 04-24-2011, 08:22 PM   #61
hulkster_s13
hulkster_s13's Avatar
hulkster_s13 is an unknown quantity at this point
Even with the proper vss I think it would cost closer to 300-350. 200 without the vss. Typical cluster can go for 60-100 then people charge 80-100 for the wiring. I did this cluster swap and really like it.
Alohaworld- check FOrumshawaii I had one for sale on there. No one wanted it so it's just collecting dust now
hulkster_s13 is offline   Reply With Quote
Old 04-24-2011, 09:23 PM   #62
Dark Spec
Dark Spec's Avatar
Dark Spec is an unknown quantity at this point
exactly my point, it gets expensive and no one wants to spend the money but it its a great cluster I love mine and everyone is always asking bout it and giving complements because its rare
Dark Spec is offline   Reply With Quote
Old 04-28-2011, 12:28 AM   #63
dontxploitme
dontxploitme's Avatar
dontxploitme is an unknown quantity at this point
i noticed that on the nx white plug the red/black wire is posted twice. it says
center white plug s13
s13 ~ nx
white/ blk ~ red/blk white plug
black s13 plug right side
s13 ~ NX
red/blk ~ red/blk white plug
so how does that work? do i do a triple solder?
dontxploitme is offline   Reply With Quote
Old 05-07-2011, 05:18 PM   #64
wussmonster
wussmonster is an unknown quantity at this point
any more close up pics of the fitment? looks like there's gaps on both sides. other than that, its definitely interesting.
wussmonster is offline   Reply With Quote
Old 06-25-2011, 07:06 PM   #65
traxx07
Trader Rating: (63)
traxx07 is an unknown quantity at this point
Feedback Score: 63 reviews
Anyone have a better wiring thingy for this? There are three yellow wires on the yellow plug but which one is suppost to be used? LMK Thanks!
traxx07 is offline   Reply With Quote
Old 06-26-2011, 06:25 PM   #66
nep
nep's Avatar
nep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the rough
Is there s14 support for this or no?
nep is offline   Reply With Quote
Old 08-01-2011, 08:29 PM   #67
RideOrDie
RideOrDie is an unknown quantity at this point
Anyone know where I can find the NX1600 FSM?
RideOrDie is offline   Reply With Quote
Old 09-09-2011, 02:33 AM   #68
wutangben
wutangben is making a name for him/her selfwutangben is making a name for him/her self
Send a message via AIM to wutangben
my third s13 plug has 10 wires coming out of it, and this write-up only shows 6???
wutangben is offline   Reply With Quote
Old 12-07-2011, 11:33 AM   #69
s13sickboi
s13sickboi is an unknown quantity at this point
Send a message via AIM to s13sickboi
So the NX vss is plug and play? More info needed please...
I have my '90 tranny/harness ect. and it still reads double. Anyone tried just swapping the NX pinion onto the s13 speed sensor? $40 on Courtesy Parts.
s13sickboi is offline   Reply With Quote
Old 01-19-2012, 06:18 AM   #70
ghost_22_47
ghost_22_47 is an unknown quantity at this point
I am going to pick up my cluster today and installing it into my RB26 Vert. I will be using my Dakota Digital converters tha I already have installed in the car to convert the Speed and Tach signal. I will try and post up the Dakota Digital settings once I have them all set up.
1993 240sx Vert With RB26DETT
2001 BMW 530i (DD)
ghost_22_47 is offline   Reply With Quote
Old 02-13-2012, 08:44 PM   #71
purplove
purplove's Avatar
purplove is an unknown quantity at this point
Time to bump this up! I've done all the research possible, except looking at the nx1600 fsm. I've got mine all wired up accordingly, but the clock is not working and my oil light stays on so I must have a crossed a wire somewhere. I'm using a single cam cluster harness which I'm thinking may have been the problem and if so I have a dual cam harness and a digi harness that i will wire in instead. My nx1600 cluster is from a 92. Does anyone have any info they would like to share to help me find out what I may need to do? Thanks
Sean.
purplove is offline   Reply With Quote
Old 02-13-2012, 09:10 PM   #72
wutangben
sohc and dohc s13 cluster harnesses should be the same... the HUD harness is not the same.
Old 02-13-2012, 09:14 PM   #73
Dark Spec
Dark Spec's Avatar
what he ^ said...u just have a crossed wire
Old 02-14-2012, 05:27 PM   #74
purplove
purplove's Avatar
I figured. If the s13 harness is the same for kae and kade, then the nx1600 cluster wiring is a bit different? Something is not colored right, cus i've looked over it about 15 times trying to figure it out. Have any of you got one out of a 92 working properly?
Old 02-14-2012, 08:07 PM   #75
Dark Spec
Dark Spec's Avatar
I have... and you need to go by pinout not wire colors...
there are 4 different clusters and the wires do vary in color somewhat depending on model and year...
just go over your fsm wireing diagrams and you will find it
Old 02-14-2012, 10:28 PM   #76
purplove
purplove's Avatar
Ive been using both pinouts and colors. Either way I'm gonna take it back out soon and go over everything one last time. Thanks.
Old 02-23-2012, 02:50 PM   #77
purplove
purplove's Avatar
update: everything on the cluster functions properly, besides the speed still reading double. I've tried the single cam VSS and the nx1600 VSS but they do not fit in the hole where the dohc speed sensor sits. Ive tried taking the pinion off and swapping it, but that one is much bigger too. What VSS's are you guys using?
Old 03-02-2012, 09:51 AM   #78
nurvcom
nurvcom's Avatar
nurvcom is an unknown quantity at this point
Send a message via Yahoo to nurvcom
240SX S13 NX1600 DIGITAL CLUSTER - YouTube&fs=1&hd=1" width="858" height="508">240SX S13 NX1600 DIGITAL CLUSTER - YouTube&fs=1&hd=1" />240SX S13 NX1600 DIGITAL CLUSTER - YouTube">http://www.youtube.com/watch?v=240SX S13 NX1600 DIGITAL CLUSTER - YouTube
Ripping up the Highway since 03
nurvcom is offline   Reply With Quote
Old 03-10-2012, 10:34 PM   #79
Dori90
Dori90 is an unknown quantity at this point
phuc
yeah i have the same problem..im lost let me know if anyone figures it out thanks
Dori90 is offline   Reply With Quote
Old 03-10-2012, 10:38 PM   #80
StryfeS13
It's Always Broken.
StryfeS13's Avatar
StryfeS13 is an unknown quantity at this point
Would it be possible to use a dakota digital speed translator to get the speed right?
Universal Speedometer Signal Interface
Originally Posted by KoukiMonsta
once its done you can drive it off a fucking cliff for making such a fucking stupid thread.
Gotta love Zilvia.
StryfeS13 is offline   Reply With Quote
Old 03-11-2012, 12:09 AM   #81
nurvcom
nurvcom's Avatar
on my current 240sx I using the nx1600 on ka24de auto and it reading good
Old 03-11-2012, 12:26 AM   #82
yetijeff
yetijeff's Avatar
yetijeff is an unknown quantity at this point
I have the sohc vss and works perfect... I dunno
yetijeff is offline   Reply With Quote
Old 03-12-2012, 12:21 AM   #83
Cease_Super_Hicas
Cease_Super_Hicas's Avatar
Cease_Super_Hicas is an unknown quantity at this point
Send a message via Yahoo to Cease_Super_Hicas
are u sure u dont have it in kilometers cuz it has kilo and mph? check that out cuz i have the same custer with the stock speed sensor and works perfect
Cease_Super_Hicas is offline   Reply With Quote
Old 03-12-2012, 09:10 AM   #84
Chaluska
Chaluska is an unknown quantity at this point
guys, it all depends on the NX cluster you get, 91-94 there were 2 gens of clusters, and of those, there were 5 spd, and auto. only 1 of the clusters will work with the stock speedo.
Chaluska is offline   Reply With Quote
Old 03-19-2012, 09:48 AM   #85
ProjectZero240
ProjectZero240 is an unknown quantity at this point
Exclamation nx1600
Ok here's what I'm.wondering... I just got the nx1600 cluster, I want to wire it into my 93 240.. its obviously dohc but it used to be auto and I got it swapped.. I would also like to know if wiring a hud would be possible.. hit me up with any info you got on my setup.. also I'm not sure what year or type the nx1600 is from yet so ill update when it gets to me... My email is [email protected] ..
ProjectZero240 is offline   Reply With Quote
Old 03-19-2012, 06:47 PM   #86
ProjectZero240
Exclamation (update)
The nx cluster i got is a 92.. so any updates on how the plugs are different from the original write up will help out.. thanks
Old 03-26-2012, 05:26 PM   #87
Stunt'nSlide
Trader Rating: (-1)
Stunt'nSlide is an unknown quantity at this point
Feedback Score: -1 reviews
I know this is a old thread but i'm so confused. You said green wire goes to blue and yellow wire from black and yellow plug. On my nx1600 cluster it has 3 yellow wires one from each plug and the yellow wires are connected into 1 yellow wire. So do I eliminate the other 2 yellow wires from the other plugs?
Stunt'nSlide is offline   Reply With Quote
Old 04-24-2012, 03:37 PM   #88
babillaracing
babillaracing is an unknown quantity at this point
how high the mph can go? can it reach 180 mph ? Thanks....Omar
618 whp tuned by alpha
babillaracing is offline   Reply With Quote
Old 04-24-2012, 06:27 PM   #89
Cease_Super_Hicas
Ive taken it to 140 on my Sr with this cluster If that helps
http://i643.photobucket.com/albums/uu153/RB20DETHKS/b022769b-1-1.jpg
Old 04-25-2012, 06:12 AM   #90
babillaracing
cool thanks ,i guess it won't be a problem reading in the 180mph plus
last question you think is accurate? cause i don't like to be going around town with a gps also the gps is slow updating your speed
