Old 04-23-2012, 04:33 PM   #1
ultimateirving
ultimateirving's Avatar
ISIS RS3871 install thread
To begin my old turbo was starting to fail spitting out quite a bit of oil in the hot pipe. I bought a new one recently, and sunday me and 2 buddies started taking it all apart!
I got the ISIS rs3871 plan to be running around 18-20psi of boost.
heres some pics of the install
New turbo with mocked up intake elbow, 3in intake is so tight!
stock turbo as it sits
Here is empty engine bay, cleaned up the exhaust mounting surfaces on both the head and manifold.
last 2 pics are after install was pretty much complete.
Here is my ghetto ram air haha, Only way i could get it to hook up with what little 3" intercool pipes i had. i need to get my car down to my fabber sometime this week to get the hard pipes redone so i can fit my intake inside my hood.
Car was running today, but one of the coolant lines wasnt fully tightened and is leaking coolant, gotta tighten that up.
also need to rerun the 02 sensor signal wire to my ecu since i removed my stock 02, and plan to use the simulated narrowband from my Innovate lc1.
Was a fun experience, first time changing turbos, took longer than expected(when does it not?) didnt have to much of problems fitting it in there. Just needed a little muscle and wiggles to get it in and out.
More of my build is done now and i will report on performance soon, ill try to get to a dyno within a month or so to really compare to what my stock t28 put out.. i was at 300hp at 15psi before.. so hopefully this thing can make a bit more, without being to laggy
thanks for reading!
Z32 with lq4 swap
Old 04-24-2012, 01:06 PM   #2
unreal-
unreal- is an unknown quantity at this point
Looks good! I got a few questions:
Did you use 14x1.5 coolant fittings for the turbo? and if so, do they require teflon tape?
Also, when does the turbo spool? and what is the wastegate set at from the factory? Ive been told 8-10psi but no one knows for sure, even enjuku lol.
Im throwing this on my KA in a few weeks
unreal- is offline   Reply With Quote
Old 04-24-2012, 06:53 PM   #3
ultimateirving
hey man! i had stainless lines from my other turbo, so im unsure of fitting sizes. I did not use any teflon tape.
Havnt got the chance to run turbo yet, been to busy with work to finish up the little things i need to, to get it on the street.
and i swapped the Wastegate actuator with my HKS one i bought. However the isis WGA is adjustable, so im sure you can get it to work.
Z32 with lq4 swap
Old 04-24-2012, 07:02 PM   #4
Corbic
Corbic's Avatar
Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic
I don't think that air-filter is going to clear the hood...
Corbic is offline   Reply With Quote
Old 04-26-2012, 03:02 PM   #5
unreal-
Thanks. i bought some 14x1.5 banjo to 3/8 hose adapters from ATP turbo for my coolant lines. Going to grab coolant from the TB circuit.
I understand that the WG is adjustable, i was just wondering what it is set at out of the box.
ill be keeping an eye on this thread I really want to see how the turbo performs from people that actually have it and use it.
Old 04-26-2012, 04:45 PM   #6
ultimateirving
well im still waiting to get my car going, i been to busy with work. Turbo is on just havnt gotten to fine tune things yet.
only been able to verify it idles and no boost leaks
And since my swap, based on pics from Circuit Sport, i have their stainless braided lines.
Z32 with lq4 swap
Old 05-04-2012, 01:01 PM   #7
jsu1012
jsu1012's Avatar
jsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to behold
subscribed. I'm curious to see how this turbo performs against your old setup.
jsu1012 is offline   Reply With Quote
Old 05-16-2012, 03:43 PM   #8
unreal-
any updates?
Old 05-18-2012, 08:05 PM   #9
ultimateirving
sorry guys, i know its sounds crazy but i havent even had time to take my car out.. Went out of town for a funeral.. but im back home now.. hopefully this tuesday ill get it going and can get some good "butt dynos"
Z32 with lq4 swap
Old 05-19-2012, 11:06 AM   #10
Frank_Jaeger
Cut a whole in ur hood and let the intake hang out!1
Mad tyte
Frank_Jaeger is offline   Reply With Quote
Old 05-20-2012, 02:15 PM   #11
Jez
Jez's Avatar
Jez is an unknown quantity at this point
I'd be interested also to see how this performs, but I'm more interested in how long it lasts!
Jez is offline   Reply With Quote
Old 05-22-2012, 07:53 AM   #12
jsu1012
jsu1012's Avatar
I'm right there with you . lets see how this goes..
Old 05-22-2012, 03:27 PM   #13
ultimateirving
OK Guys, Initial run. Primed turbo, Cranked engine 4 times for approx 15 secs with injectors disabled. Reconnected injectors, and she fired right up =)
Let her idle for a bit some of the smoke burnt off.
Took it out, Stock ISIS waste gate Approx 12.5-13psi full boost around 3500.
I have Freddy Intake mani and stock head.
Now im gonna recheck all my connections and take it out crank it to about 18psi.
Lets see how it holds up.
Z32 with lq4 swap
Old 05-22-2012, 05:52 PM   #14
ultimateirving
So after some work with my boost controller.. trying to reset it. Blew a coupler and had to pull off to fix.
But got it to boost 18psi no problem 3600ish came on hard(no homo) However this is on 91 oct and its running rich, like 10's. 850cc injectors are for my e85, i need to switch tunes back to really feel the power... We shall see.
Prev dyno on s14 t28 with same mods was 298Hp.
This thing was pushing 15psi, and about 12.0 a/f
Z32 with lq4 swap
Old 05-23-2012, 12:30 PM   #15
jsu1012
jsu1012's Avatar
good shit!
Old 06-06-2012, 02:06 PM   #16
ultimateirving
Been driving for a few weeks now. Turbo pulls hard. I need a newer boost controller or soemthing. Mine is very slow to respond (HKS EVC III) i been over boosting hitting at least 20psi.. which is where my boost controller caps out. But its running rich in boost so i need a retune for sure
Z32 with lq4 swap
Old 06-07-2012, 08:54 AM   #17
jsu1012
jsu1012's Avatar
I want to see some video of it pulling.
Old 06-07-2012, 08:08 PM   #18
TAP240
TAP240's Avatar
TAP240 is an unknown quantity at this point
my t28 bb turbo went out on me so I'm looking in to the the isis sr20 replacement turbo...
From what you've posted so far, these isis turbo's don't seem too bad.
*subscribed; I too would like to see some footage of the car pulling.
TAP240 is offline   Reply With Quote
Old 06-24-2012, 09:56 AM   #19
ultimateirving
So i Know its been a while since ive posted. Went out to the drag strip last night. SPeedworlds annual Midnight Run. Was hella busy only got 2 runs in for the 2 hours i was there. New personal best of 13.99 @ 105.00mph. 2.19 60' explains why i slipped first gear well off the line, but immediately lost traction once boost built. Missed second due to old beater tranny. Finally got into gear, and still at full boost the rear end breaks loose again. 3rd gear hooks good, and so does 4th. SO yeah turbo was great. spools great til i shift at 7k.
oh ya i busted my head open on the corner of my hatch, had blood coming down my face
Z32 with lq4 swap
Old 06-24-2012, 10:13 AM   #20
ForeignMuscle
ForeignMuscle is an unknown quantity at this point
Did you say your old setup was using a t28 and it made 300HP at 15psi? What supporting mods, cams? Correction factor on the dyno? T28's usually do not make that power without pushing them past 18psi so I'm curious how yours did. A basic bolt on sr20det with a 2871r makes around 300whp @ 15psi. Good write up. I looked into these turbos at one time. Interested in what it can do.
ForeignMuscle is offline   Reply With Quote
Old 06-24-2012, 10:30 AM   #21
ultimateirving
Mods are the same as what is in my sig, e85 plays a major factor in the power produced. and this is on a Dyno Dynamics Dyno so numbers are pretty accurate. The new turbo Im trying to keep around 18-19 psi. so i expect 350 whp np.
dyno website here
http://www.dynocomp.com/
Z32 with lq4 swap
Old 06-24-2012, 10:44 AM   #22
ForeignMuscle
I noticed the e85 after I posted. I was confused for a moment. I think it should be close to 400hp with the Isis.
Old 06-25-2012, 06:40 AM   #23
zurud
zurud is an unknown quantity at this point
105 trap indicate 270whp the most. I believe in trap speed more than dyno rating. Trap speed don't lie. If you can trap more than 120, then you have 400 hp.
zurud is offline   Reply With Quote
Old 06-25-2012, 06:46 AM   #24
ForeignMuscle
Trap speeds don't lie, but rear tires do.. If he couldn't catch traction, how do you expect the car to show it's full potential? Trap speeds are useful when you post an ideal run. Not when you spin all over the place and miss shifts.
Old 06-25-2012, 12:09 PM   #25
ultimateirving
Haha skeptics eh. I have 225 street tires in rear and partially bald. I was trying to find some Dr's but no luck. So my times suck ass.
ps
my friend was also their with his turbo probe, rated at about 340 whp, he ran 12.8 @115 with drag radials, so it makes a huge difference being able to hook up.
Z32 with lq4 swap
Old 06-25-2012, 05:17 PM   #26
TAP240
TAP240's Avatar
Just installed my ISIS RS this past weekend, waiting for my valve cover to get back to start the car up..(not to thread jack lol) but I'll let you know how my results are as well..
Old 06-25-2012, 05:37 PM   #27
ultimateirving
yeah man! thats good, no worries we can make this RS3871 info thread for all to read
Z32 with lq4 swap
Old 06-26-2012, 09:50 AM   #28
TAP240
TAP240's Avatar
Sounds good to me! I used my stock turbo lines (coolant and oil) and stock copper washers...did you do anything different? The copper washers don't seem to seal the best.
Old 06-26-2012, 12:09 PM   #29
Pinggg
Pinggg's Avatar
Trader Rating: (22)
Pinggg is an unknown quantity at this point
Feedback Score: 22 reviews
Should of gotten AN turbo lines while you were already there changing shit.
Pinggg is offline   Reply With Quote
Old 06-26-2012, 12:19 PM   #30
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
try tuning the damn thing already.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
