05-14-2012, 10:03 PM | #1 |
Location: NYC if i tell you anymore i will need to kill you!
arp head studs
ok i am puzzled, i have a set of arp head studs for the sr motor red top. i been searching up and down what order and how much torque these things suppose to have. bolts to the bottom part of the block am i suppose to torque them down to 29ft-lbs or torque? reason why i ask is i am using a 3/16 hex socket the only on that seems to fit to tighten the studs and ending up stripping them hex socket and also the hex shape on the end of the stud. any suggestions?
05-14-2012, 10:36 PM | #2 |
I suggest you do whatever the instructions that came in the box tell you to do.
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
05-14-2012, 10:53 PM | #3 |
yeah about the instructions lolz its been quite sometime it has been sitting without a box and papers that came with it....
05-14-2012, 11:14 PM | #4 |
Trq Spec depends on the Stud Model, Old design is 70ftlbs.
Can be ID'd by the top of the Stud only Saying ARP If you have the newer Stud then the Trq Spec is gonna be higher like 90ftlbs or something. Can be ID'd as the top of the stud saying ARP 2000 or something
05-15-2012, 12:16 AM | #5 |
3 step
20lb on all stud bolts 45lb on all stud bolts 70lb last one on all stud bolts. this is wat i did on my kat but my final was 80lbs not 70. plz make sure u chase the block theads, i didnt and my first set one stud snapped, and dont rush the last step belive it or not took me 30min to bolt my head on as i was taking my time |
05-15-2012, 12:35 AM | #6 |
ok cool! i'ma give that a shot tomorrow night. just to double check, the ft-lb is on the nut that is provided ^, is after the head is on right? because i just got to the step where i am putting the studs on the bottom block. and also have to get a new hex shape socket. 3/16 is the right size am i correct if anyone remember.
05-15-2012, 01:58 AM | #7 | |
idk ur socket size but i belive ur talking about a 12point socket 3/16th. try sears for the 12point ull have better luck then autozone,ex. |
05-15-2012, 06:21 PM | #10 |
Arp's are three equal steps to 80ft lbs. Make sure you use the lube supplied with the bolts otherwise you'll be breaking shit. Lube the washers and nuts as well as the threads. Put head gasket in place, put RTV where it's needed, then set head on top. Slide bolts into holes and hand tighten into the block. Then torque head using the factory torque sequence for the studs.
