Old 05-26-2012, 04:00 PM   #1
webgeek
webgeek's Avatar
webgeek is an unknown quantity at this point
ISIS Radiator vs.....
I'm in the need for a new radiator and was wondering if anyone has had any issues with the isis radiators and/or hoses?
*ISIS Radiator Cooling Package - Nissan 240sx KA24DE 95-98 - Enjuku Racing Parts, LLC
Or any recommendations would be greatly appreciated I'm also going with efans
webgeek is offline   Reply With Quote
Old 05-26-2012, 04:02 PM   #2
slydin240sx
slydin240sx is an unknown quantity at this point
Brace yourself.
slydin240sx is offline   Reply With Quote
Old 05-26-2012, 04:04 PM   #3
webgeek
webgeek's Avatar
Originally Posted by slydin240sx View Post
Brace yourself.
lol
Old 05-26-2012, 04:10 PM   #4
Promise Land
Promise Land's Avatar
Promise Land is an unknown quantity at this point
The video at the bottom of the Enjuku page is of me installing the radiator and fans into my '95. I've had no problems with the radiator or fans since installing them last year. I will be picking up a set of the ISIS hoses in the next couple of weeks also. My old hoses finally have met their time.
Promise Land is offline   Reply With Quote
Old 05-26-2012, 04:13 PM   #5
webgeek
webgeek's Avatar
Awesome! So how did you wire the fans? Into the ignition?
Old 05-26-2012, 04:22 PM   #6
Promise Land
The previous owner of my car had one electric fan and he ran the trigger off the wiper motor harness. It has a wire that has power turned on with the ignition. The constant power is inside the distribution box in the engine bay. That is running one of the fans. I haven't wired the second fan yet, but it will be triggered off a switch from the inside center console so I can control it when I would need it on only.
Old 05-26-2012, 05:06 PM   #7
webgeek
webgeek's Avatar
Only run 2 when A/C is needed? I was reading about this but I'm assuming people are running with both efans running constantly. Is this not a good idea?
Old 05-26-2012, 05:30 PM   #8
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Clutch fan > electric
Old 05-26-2012, 05:40 PM   #9
webgeek
webgeek's Avatar
From my understanding, this is strictly based on opinion.
Old 05-26-2012, 05:44 PM   #10
future
future's Avatar
Trader Rating: (42)
Run one then the other, tell me which one runs cooler
This topic has been covered. Close this thread and google it before somebody comes in here and rips you a virtual new one
Old 05-26-2012, 05:47 PM   #11
webgeek
webgeek's Avatar
Actually the original topic was referencing radiators..the efans was additional
So don't be trolling
And if people in Arizona and Florida, where I live, run efans with no issues then I'm going to try it.
Old 05-26-2012, 05:51 PM   #12
future
future's Avatar
Trader Rating: (42)
Why? What benifit are you getting? Or is it just cause everybody else does so your going to? Now your going to have wires, fuses, and relays running around waiting to fail you when you can just have your shroud and clutch fan and don't bave to worry about stuff failing
Old 05-26-2012, 05:52 PM   #13
future
future's Avatar
Trader Rating: (42)
Oh and you 26 asking this? Smfh
How does it feel getting owned now? Haha
Old 05-26-2012, 05:57 PM   #14
webgeek
webgeek's Avatar
Why are you getting worked up over a question? I plan on dropping an ls1 into my 240sx.
What does age have to do with anything? My speciality is computer based, not car based, that is why forums are made for, to ask questions or am I mistaken?
Old 05-26-2012, 06:01 PM   #15
future
future's Avatar
Trader Rating: (42)
Ls1.... Now it makes sense. Im forced to do the same. But for now you have a ka. No point in the fan. Just leave it stock. Save money. I'm undergoing my ls swap. Have your number you think your going to spend. And times it by two and some. Then the swap will get done
Good luck.
Old 05-26-2012, 06:05 PM   #16
webgeek
webgeek's Avatar
Good luck.
My radiator is leaking, hoses need replacing, and clutch fan is falling off. That is why I originally asked the radiator question because the isis comes with everything.
Enjuku will be doing my ls1 swap...but I need these minor issues fixed so I can at least drive my s14
Old 05-26-2012, 06:18 PM   #17
slydin240sx
It is!!
With a properly bled and maintained cooling system, either with e-fans or the clutch fan the temps will be in roughly the same area. Depending on weather conditions and how you drive.
Who cares why he want's to run whatever fan, it's all personal preference. Oh and clutch fans CAN fail too!
You didn't own anyone you twirp! Try and stay on topic next time you want to troll kid.
Old 05-26-2012, 06:21 PM   #18
slydin240sx
Get the Isis setup! It's probably the best bang for your buck deal. You shouldn't have any issues with it other than your fans failing at a way later date. It's not rocket science making a radiator or some hoses. If you do get the setup I would get some sort of thermostat controller to control the fans coming on and off. Otherwise they will burn up a lot sooner if they stay on the whole time the car is on.
Old 05-26-2012, 06:25 PM   #19
webgeek
webgeek's Avatar
Awesome! Any recommendations on a brand of a thermostat controller? I found one on frsport.com but it has been discontinued
Old 05-26-2012, 06:33 PM   #20
webgeek
webgeek's Avatar
Seems like this would be perfect to control the fans
Buy Imperial Adjustable Thermostatic Fan Control 226204 at Advance Auto Parts
Old 05-26-2012, 06:45 PM   #21
slydin240sx
Yeah they came out with a newer model IIRC! It should be on frsport as well.
That would work perfectly fine and it's a helluva lot cheaper than the DIF controllers on frsport.
I still need to invest in a thermostat controller for my dual e fan setup. When I bought my s14 it had one single e fan on it, but a year later it burnt up after being wired to come on with the car and only go off when the car was turned off. I still have my new fans wired that way but I plan to change that soon.
Old 05-26-2012, 07:17 PM   #22
webgeek
webgeek's Avatar
OK thanks for the input. I'm on the hunt for that IIRC thermostat controller then.
Old 05-28-2012, 11:18 AM   #23
AdamR
AdamR is an unknown quantity at this point
Maybe the way you do things. I have multiple redundancies in my electrical system so I wont ever be stuck.
AdamR is offline   Reply With Quote
Old 05-28-2012, 11:22 AM   #24
waxball88
waxball88 is an unknown quantity at this point
Your 20+ year old plastic clutch fan is a time bomb. Ever had a clutch fan take a shit? I have. Take a look at your fan, i bet it has nice little cracks in between every blade. No big deal now, but those just get bigger and bigger.
I used to run the clutch, yes it is the optimum cooling set-up. But i own a boosted KA, i'm always fucking with shit. The clutch fan and shroud are a pain in the ass when doing many things on your car.
Relays failing? All my relays are still oem and they outlasted the clutch fan?
Ever drop a VC bolt or similar while having a clutch fan? Maybe if you're a 7 year old starving child from Sudan reaching down past the clutch is cake, but if not, that bitch is annoying as fuck.
I have e-fans now and the headache they prevent is much greater than the initial headache they can produce to install (which isn't hard) As long as you get some decent fans.
waxball88 is offline   Reply With Quote
Old 06-08-2012, 07:37 PM   #25
webgeek
webgeek's Avatar
FYI
I just finished installing this today and works. At first I was like the fans aren't working WTF?!?!?! Took a drive and then opened to hood to find the fans spinning.
I wired the yellow wire, the ignition wire, right into the radio fuse and works like a charm. Also installing the isis radiator was a breeze!!! Removing the clutch fan wasn't but we got it done!!!!
Tomorrow is making the wires look pretty!!!!
Old 06-08-2012, 07:40 PM   #26
webgeek
webgeek's Avatar
BTW I want to thank you for your videos. The radiator install and changing the led lights on the ac unit. Next will be changing the lights on the cluster.
Old 06-08-2012, 07:42 PM   #27
slydin240sx
FYI
So you went with what controller? The dif one or the cheaper auto parts store one? Any pics of the setup?
Old 06-08-2012, 07:48 PM   #28
webgeek
webgeek's Avatar
Went with the cheap advance auto parts setup. Couldn't find a DIF controller any where. No pics just yet since I was testing and the fans did not turn on so I took a leap of faith and drove the car back to my house. 10+/- min drive back to see if the fans would turn on. Got home and the fans were spinning. When the engine cooled down, they turned off. The advance auto parts setup has a thermostat type plug that you install close to the upper radiator hose then connected the only ignition based item I know to their yellow cable, the radio.
I'll post pics up tomorrow.
Old 06-08-2012, 07:50 PM   #29
slydin240sx
Interested to see pics.
Old 06-10-2012, 12:24 AM   #30
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I think the better response would be to 'show us' how your setup works better.
Clutch fans are bulky, loud, and in the way. That alone was enough to make me switch. With 30 some odd track days under my belt, I can assure you that I've never EVER had an overheating issue with Altima fans.
Sure a clutch fan works fine...it's almost failsafe...but I can't stand them being in the way.
