Old 06-16-2012, 01:07 AM   #31
davidg01234
davidg01234 is an unknown quantity at this point
Hey guys when I put the new rings on the pistons, does it matter which way the gaps face? Just as long as they are all offset from each other right?
davidg01234 is offline   Reply With Quote
Old 06-16-2012, 01:55 AM   #32
Miguelone
Miguelone is an unknown quantity at this point
Miguelone is offline   Reply With Quote
Old 06-16-2012, 02:17 AM   #33
davidg01234
Originally Posted by Miguelone View Post
Awesome!! Thanks man your alot of help! Now does the angle of the gaps have to be that perfect or is it OK as long as theyre pretty eye close?
Old 06-16-2012, 02:20 AM   #34
Miguelone
No worries, judging it by eye should do fine.
Old 06-16-2012, 02:23 AM   #35
davidg01234
OK thanks so much man! Everything is alot clearer now and I now know exactly what I need to do and what I need to order
Old 06-16-2012, 02:25 AM   #36
Miguelone
While you're at it you may as well get some ARP rod studs. The stockers are the weak link in the bottom end.
Old 06-16-2012, 08:14 AM   #37
davidg01234
Great suggestion but no I'm keeping it all stock. Besides as long as the stocks can hold my 400bhp goal, I'm happy
Old 06-16-2012, 10:23 AM   #38
davidg01234
How did you measure your clearances?
You need to remove all oil from the bearing surfaces, grab a piece of plastigauge stick it on the bearing surface, tighten the bolts to correct tension(46-52nm for Crank bolts & 14-16nm plus an additional 60-65 degrees for rod bolts) DO NOT TURN THE MOTOR. Then unbolt and check the width of your plastiguage with the supplied card.
You won't have clearances of .001(Thou or MM I'm not sure which you mean but either is a way smaller clearance than you need)
Clearances are.
Rods
Standard 0.2-0.3mm
Limit 0.4mm
Mains.
Standard 0.05-0.18mm
Limit 0.3mm
Yes you can just chuck ACL bearings in but during assembly you WILL need to measure again to ensure you have correct clearances. The standard bearings are all graded with the grade of each bearing in the engine stamped on the front most counterweight on the crank(Mains on the top, rods on the bottom, left to right = front to back) If you want to go stock bearings you'll need to order the right ones or go up in sizes depending on wear on the crankshaft itself.
Clearance on both mains and rods are .001in. Which is. 025mm. Seem about right?
Old 06-16-2012, 10:30 AM   #39
davidg01234
Anybody know the torque specs for the piston oil squirters? I just cleaned them out so now need to put them on. I have the r33 fsm downloaded but idk where to begin looking?
Old 06-17-2012, 12:34 AM   #40
Miguelone
All the torque settings are at the end. Right before the index.
Old 06-17-2012, 11:02 AM   #41
davidg01234
i just decided to tighten them by feel, they dont really seem like something that requires a specific torque. thanks though man!!
Old 06-18-2012, 08:31 AM   #42
JKL1031
JKL1031 is an unknown quantity at this point
Mann Zilvia spoon feeding?!
JKL1031 is offline   Reply With Quote
Old 06-18-2012, 07:47 PM   #43
davidg01234
lol sorry its my first time going this far into an engine
Old 06-18-2012, 08:08 PM   #44
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Just cuz this shit is actually techinical...not asking whether or not my damn 9j +42 wheels will fit or what's better, SR or KA-T?
CLICK HERE!!!
Old 06-18-2012, 08:23 PM   #45
greenwood
greenwood's Avatar
greenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymore
I've been reading up on this thread it's good stuff. I will be building a RB20 in my living room very soon.
greenwood is offline   Reply With Quote
Old 06-18-2012, 08:27 PM   #46
P-Funk alot
P-Funk alot's Avatar
P-Funk alot is an unknown quantity at this point
Send a message via Yahoo to P-Funk alot
its creates laziness. ^^^ a simple google search would have brought up everything you needed to know.. good luck though with your rebuild and get some pics up of the process. and even if the cylinder still have the cross hatch i would go buy a glaze breaker from your local parts store and hit each cylinder. helps alot believe it or not..
P-Funk alot is offline   Reply With Quote
Old 06-18-2012, 08:35 PM   #47
davidg01234
hahaa I hope you don't have carpet man!!
Old 06-18-2012, 08:50 PM   #48
davidg01234
[QUOTE=P-Funk alot;4755416]its creates laziness. ^^^ a simple google search would have brought up everything you needed to know.. good luck though with your rebuild and get some pics up of the process. and even if the cylinder still have the cross hatch i would go buy a glaze breaker from your local parts store and hit each cylinder. helps alot believe it or not.
Actually I Google everything I couldn't find so idk what your talking about man.
Old 06-18-2012, 09:36 PM   #49
JKL1031
naw naw nawww, its just cause he has an RB.
