#1205 |
Man w/ CTSV & a Car Seat
Offset has nothing to do with brake clearance. But looking at they are and face design (how concave the face is) I dont see why they wont clear Z32/R32 brakes.
#1206 |
![]() Join Date: Nov 2011
sorry, if that's a wrong thread, but i need answer to that question:
I've got 3 piece 17/18 SSR Gartmaiers, and i want to put in a new wider 30 hole outer lips. Can i take em from Vienna's, Koenig's or other 30 hole SSR's??.. They are also 30 hole flat lips. But i don't know if they are the same size (diameter).
www.s13club.ru www.nismo.by |
#1207 | |
http://zilvia.net/f/chat/327620-wide...ls-thread.html |
#1208 |
18x10 +22 w 265/35/18 Bridgestone potenza re760s out back on an s14. Could I get away with running less than 3 degrees of rear camber, roll/and pull required obviously. I know this isn't extreme fitment, I just really don't wanna kill these tires in 5k miles with ridiculous camber. I will probably step down to a narrower tire after these wear out...unless someone wants to buy them from me?
#1209 | |
![]() Join Date: Nov 2007
#1211 |
![]() Join Date: Aug 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
ordered myself some work cr kai's in 18x9.5 +12 all around. planning to wrap them in federal 595s probably 235/40/18.
currently, im running -2 camber up front and -.5 in the rear. anyone know how well that is gunna fit? i know i'm probably going to need a pull (a roll for sure), i just don't know how much of a pull. also, i'm not very low atm. i'm at "legal" height. so basically just low enough to get rid of nasty fender gap. if i get a new job this summer, i'll probably lower her back down a bit for fun.
2016 Nissan 370z |
#1212 |
Im looking to run 18x11 +6 fronts on a Kouki s14. Would it rub/ hit anything on the inside of the wheel well? I know I'd need to get extended brackets for my Megan tracks but other than that I think with a pull it should fit nicely with some camber. What do you guys think?
#1213 | ||
![]() Join Date: Aug 2005
#1214 |
^^^Yup, largest I'd run is 10j. Anything larger than that, itll be a pain in the ass to fit and run low at the same time. Wider the rims, harder it is to run smaller tires. Wider/bigger tires will make your clearance worst than it already is.
You can run 11s, as low as you dont turn... |
#1215 |
FWIW I got them to fit w -2.1 camber and a completely flat roll, shit looks badass, credit card fitment. I'll post pics tomorrow from work
#1218 |
![]() Join Date: Sep 2008
![]() Feedback Score: 17 reviews
I was thinking about purchasing these wheels for my type x..
http://zilvia.net/f/wheels-tires/449...37-norcal.html would i need some 25mm spacers to get the clean look?
You drive DA 2 fo tay? |
#1220 |
#1221 | ||
But if you insist, put the wheels, measure how sunk the wheels are and get spacers with the same measurement. To give you an idea, 10.5 +20 can fit under the stock fenders. You slapped 50mm fenders on top of that, 50mm equates to rougly 2 inches. So you'd need in the ball park of that much spacers in the rear. 9j +35 is sunk as shit on stock fenders, worst than your rears. 9j +0 fits under the stock fenders. So just to get it there, 35mm spacers. You got 20mm wider fenders, so thats a total of 55mm spacers up front. 2 inch spacers all around are absolutely fucking retarded. |
#1222 |
![]() Join Date: Jan 2010
Just got my wheels in, mustang reps. 17x10.5 +20 with a 225/45/17 achilles. I have a stock body s13 coupe, and am about to go on a fender rolling/pulling venture. I really don't want to pull my fenders more then I have to (I'm scare of the oil can qp dent) but I also don't want to run 10* of rear camber. Did I order more wheel then I should have? lol or can I get these to fit..
#1223 | |
#1224 | |
![]() Join Date: Oct 2010
Trader Rating: (24)
![]() Feedback Score: 24 reviews
put your front wheels on, does it clear your coilover? if not add spacer accordingly. your rears will fit just fine with like 3° of camber no pull needed. |
#1225 |
Trader Rating: (24)
yeah what fliprayzin said. do you already have the overfenders installed? if NOT, then go ahead with those specs. If you have them installed already get more aggressive wheels.
#1226 |
yea already have them on there, found some Varrstoen 18x10.5 +0, will i need a big spacer?
#1227 | |
What chassis is this going on? S13 or S14? Depending on the chassis will dictate how aggressive you can run up front. S13s suck for clearing wide rims up front. |
#1228 |
what would be the correct size tire for wheel setup
front and 18x9.5 +25 18x8.5 +35 rear* with KYB shock absorber setup suspencion gr-2 and H tein springs |
#1229 | |
But the correct wheel setup is sell those junk and buy something better than that 8.5 +35. I've seen Hondas run more aggressive setup than that... |
#1230 |
Hey guys I wanted to see if I run 18x9.5 +30 front and 18x10.5 +22 rear would I have to camber alot or will I be okay? I have stock fender which I'm gonna roll soon. Thanks in advance for the help
