Old 06-20-2012, 07:49 AM   #181
ForeignMuscle
ForeignMuscle is an unknown quantity at this point
Lol You must have misunderstood me. I just want a picture of the car, with wheels on it. I want to see how high it sits with factory suspension.
ForeignMuscle is offline   Reply With Quote
Old 06-22-2012, 11:55 AM   #182
S@nt0s
S@nt0s's Avatar
S@nt0s is an unknown quantity at this point
here you go, i want to bring the front down a little since it sits more then i want in front due to the 17" front runners
MunkyW3rkz Racing
S@nt0s is offline   Reply With Quote
Old 06-22-2012, 02:27 PM   #183
ForeignMuscle
Get back to the track. Don't come back without a 6.90 timeslip
Old 06-22-2012, 02:30 PM   #184
ForeignMuscle
I looked at some old threads on this car and it looks like you almost let it go. Would have been a sad day. Easily my favorite car.
Old 06-22-2012, 03:36 PM   #185
S@nt0s
S@nt0s's Avatar
thanx, working on it this weekend to put in the R32 diff after i weld it with J30 axles. welding up bungs on the VC to help with venting.
also hooking up the line lock
6.90's no way ill burn it if it does that after the line lock and 2 step are set up. Im looking at 6-40-6.50's in the 1/8th
MunkyW3rkz Racing
Old 06-22-2012, 04:01 PM   #186
ForeignMuscle
I want more info on your engine. (internals, head etc.) You can pm if its confidential. Just the main building blocks of your setup would be nice. I would like to follow a very similar build with my car. You don't see enough high power sr's and I know the engines can make the power fairly simply.
Old 06-22-2012, 04:07 PM   #187
S@nt0s
S@nt0s's Avatar
nothing special about the motor
wiseco .20 pistons 8:5 comp
eagle rods
stock sleeves
ACL bearing
stock head not even rebuilt
BC springs Stock retainers
curcuit sport rocker stoppers
BC 272s
freddy intake manifold
stock Tb
1680 injectors
6266 precision
god speed FMIC
AEM series 2
thats about it
MunkyW3rkz Racing
Old 06-22-2012, 04:11 PM   #188
ForeignMuscle
Wow... Sooo much more left in it. Make it breathe a little better and I bet you have an extra 200HP to unleash.
Old 06-22-2012, 04:17 PM   #189
S@nt0s
S@nt0s's Avatar
water 2 Air is next along with a Q45 TB. that im sure will open up a lot of power then ill do a Head with a port&polish stainless valves etc
MunkyW3rkz Racing
Old 06-22-2012, 04:59 PM   #190
2js1392
2js1392 is an unknown quantity at this point
2j
Im new to the forum but not to the car scene I have a s13 with a 2jz 35r in the process of rewiring the car. And I decided to read this thread. I have 26x11.5x16 mt slicks and there's no way that tire will clear stock suspension is there any other alternative options and do you think a j30 diff will handle it
2js1392 is offline   Reply With Quote
Old 06-22-2012, 05:21 PM   #191
S@nt0s
S@nt0s's Avatar
whats it measure out to?> i have see 28/10.5 on S13's without wide body
the J30's are small so they will hold a little but a Q45/z32 is the way to go which i will do later
MunkyW3rkz Racing
Old 06-22-2012, 05:29 PM   #192
2js1392
Well right now I have Megan's. And I will need spacers because it's right up on them with the 26x11.5x16 so without 40mm spacers or something I don't think it's possible and even if it would be the tire would be sticking out the quarter a rediculious amount
Old 06-22-2012, 06:07 PM   #193
ForeignMuscle
I've seen 275's which are around 11 inches and they poke out of the fender. it's not happening without over fenders. Just not enough room. Anyways, welcome to the forum! Post some pics of your ride in the gallery.
Old 06-22-2012, 06:09 PM   #194
ForeignMuscle
Btw, my info wasn't completely truthful. You can always go to town with a fender roller.
Old 06-22-2012, 06:13 PM   #195
2js1392
J
Thanks I'm glad to be aboard. I will post pictures when I get a chance.
Old 06-22-2012, 06:13 PM   #196
ForeignMuscle
S@nt0s, is your 6266 journal bearing or bb? .62 or .82?
Old 06-22-2012, 07:15 PM   #197
S@nt0s
S@nt0s's Avatar
Mine is journal I don't believe in spending $ on ball bearing
Here are pics of the 28/10.5's
MunkyW3rkz Racing
Old 06-22-2012, 07:54 PM   #198
ForeignMuscle
With a parachute right behind them...
Old 06-22-2012, 08:10 PM   #199
2js1392
J
If I'm not mistaken that's a 2jz In there
Old 06-22-2012, 10:00 PM   #200
S@nt0s
S@nt0s's Avatar
Yes I took thT at the tx2k12 event in march. It has a 2jz running low 8's on the oem rear q45 diff etc
MunkyW3rkz Racing
Old 06-23-2012, 09:16 AM   #201
2js1392
Nice
Nice so the q45 is we're it's at. Have to invest and find these parts. Thanks s@ntos big help
Old 06-23-2012, 10:02 AM   #202
S@nt0s
S@nt0s's Avatar
No problem. Nice I start breaking the hell out the rear ends I'll make the switch to a solid axle
MunkyW3rkz Racing
Old 06-23-2012, 12:02 PM   #203
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
q45 Diff with Z32 TT axle + q45 axle is the way to go for sure if your looking to make serious power unless you like snapping axles.
2muchboost is offline   Reply With Quote
Old 06-23-2012, 01:46 PM   #204
ForeignMuscle
Driveshaft shop if shit gets too serious.
Old 06-23-2012, 02:54 PM   #205
S@nt0s
S@nt0s's Avatar
Those dss axles are too much I can build a solid axle set up for less
MunkyW3rkz Racing
Old 06-24-2012, 08:15 PM   #206
S@nt0s
S@nt0s's Avatar
Here a little goodie I was working today.
Check out my "spool" 4.36 gears
MunkyW3rkz Racing
Old 06-24-2012, 09:37 PM   #207
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
Damn it Santos, you have the same set up I'm working on. I have a rear end just like yours (4.36) and the motor is almost the same..we'll have some fun later on in the year if I finish mine haha.
R@ddy is offline   Reply With Quote
Old 06-24-2012, 10:27 PM   #208
S@nt0s
S@nt0s's Avatar
Sounds good bro bring it lol
funny that your in paramount I'm in CPT
MunkyW3rkz Racing
Old 06-24-2012, 11:35 PM   #209
R@ddy
Trader Rating: (32)
Haha I'm only going for about 550whp daily driven
I you might even know me..I go to Alameda boys shop every once in a while
Old 06-24-2012, 11:42 PM   #210
S@nt0s
S@nt0s's Avatar
ya those are my homos, lol
cool bro ill see ya around. once i smog mine ill take her out and about to play too lol
MunkyW3rkz Racing
