Old 07-01-2012, 09:30 PM   #1
eli-s13
eli-s13's Avatar
eli-s13 is an unknown quantity at this point
Silvia front alignment
So i just got my oem silvia aero a couple days ago and i couldn't be happier with it but i do have some fine details i was hoping to improve on it. There is a small gap below the passenger side headlight that I am trying to get rid of. The only thing that I can think of is to shave down the plastic where the headlights bolt to the silvia headlight brackets, to change the angle that the headlight sits. Just wanted to see if anyone had a better idea.
[IMG][/IMG]
[IMG][/IMG]
eli-s13 is offline   Reply With Quote
Old 07-01-2012, 09:36 PM   #2
dirtijerzi240
dirtijerzi240 is an unknown quantity at this point
i had same problem and just drilled out the mounting holes a little bigger, then adjusted accordingly and tightened down
dirtijerzi240 is offline   Reply With Quote
Old 07-01-2012, 09:51 PM   #3
HKSalex
HKSalex's Avatar
HKSalex is an unknown quantity at this point
shimy it a little.
HKSalex is offline   Reply With Quote
Old 07-01-2012, 10:17 PM   #4
DreEzed
DreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfection
Why would anything oem need to be shimmed....
DreEzed is offline   Reply With Quote
Old 07-01-2012, 10:21 PM   #5
eli-s13
eli-s13's Avatar
I thought the same thing which is why i was hesitant to shave things down
Old 07-01-2012, 10:23 PM   #6
lude4life13
lude4life13 is an unknown quantity at this point
Something must be bent, broken, or sagging. Find that and fix it
lude4life13 is offline   Reply With Quote
Old 07-01-2012, 11:21 PM   #7
!Zar!
!Zar!'s Avatar
Loosen the four bolts that hold the bumper support, then try to push up on the support as you tighten it down. That should help remove some of the sag.
In other news, your car is looking like a nice build. Just get a gtr grill for it.
Old 07-01-2012, 11:59 PM   #8
eli-s13
eli-s13's Avatar
Thanks for the complement, yeah the cars come a long way but i actually like the silvia grill better imo
Old 07-02-2012, 12:43 AM   #9
myKAl
myKAl is an unknown quantity at this point
ughh oem aero does wonders on a sil front
just curious how much did you pay for your front?
myKAl is offline   Reply With Quote
Old 07-02-2012, 07:09 AM   #10
eli-s13
eli-s13's Avatar
The bumper was the most expensive part paid just shy of a grand but I had my mind set on this bumper for awhile, so when I finally found it I jumped on it.
Old 07-02-2012, 09:06 AM   #11
ShadowMan
ShadowMan's Avatar
ShadowMan is an unknown quantity at this point
because the car and aero is around 20 years old, things don't stay perfect forever. Its a fact of life, titties sag and bumpers sag as they age.
in any situation....thou shalt blaze
ShadowMan is offline   Reply With Quote
Old 07-02-2012, 09:55 AM   #12
Edwin562
Edwin562's Avatar
this is worthy of a signature. lol
OP, just push up on the bumper support, my K bumper had the same issue and all I did was loose up the bumper support, push up and tighten it down. sag fixed.
Old 07-02-2012, 10:03 AM   #13
eli-s13
eli-s13's Avatar
It doesn't really seem to me like its sagging its more like the angle that the headlight is sitting is causing the gap. I'm going to have to pull out a level see what is off.
Old 07-02-2012, 04:51 PM   #14
ShadowMan
ShadowMan's Avatar
Okay so its not sagging titties, just lop sided tittes. Grab a ruler and take some measurements from the rad support to see if both headlights are aligned the same, if not, make some adjustments. Shim it or whatever. Look at where everything gets bolted to as well, make sure its not bent or worn out.
Old 07-04-2012, 01:55 PM   #15
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
I see ya finally got your bumper! My front did that when I first put it on, one of my headlight brackets was bent, but yah just gotta loosen bolts and move things around everything should line up fine.... That's if the car hasn't been in any kind of fender bender, also, does you car have AC? I had to notch a little bit of the headlight bracket in the passenger side because one of the metal AC line and everything sat perfect
Mishkin_707 is offline   Reply With Quote
Old 07-05-2012, 08:50 PM   #16
eli-s13
eli-s13's Avatar
Yeah man finally got the bumper after much searching. Don't have a/c though, gotta love that cali heat
