Old 07-19-2012, 03:32 PM   #1
1320VR4
1320VR4 is an unknown quantity at this point
Power steering pump line torque
240SX How To: Removing/Replacing your PS pump
Following this write up exactly I torqued that banjo bolt to 65ft/lbs as it says after hand tightening. The threads stripped and the housing around it cracked. Is it supposed to be inch pounds rather than foot pounds? I know I had to impact that bolt off the old pump.
Is this my fault or a faulty part?
Matt
94 240SX, 93 Stealth, 92 VR4, 93 RX7 , 88 Yota
1320VR4 is offline   Reply With Quote
Old 07-19-2012, 04:47 PM   #2
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
If you had the crush washers on each side of the banjo bolt, I'd say faulty part.
di-devol is offline   Reply With Quote
Old 07-19-2012, 05:13 PM   #3
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
This is why you should use the FSM instead of NICO writeups ...nicolol
FSM says 36-51 ft-lbs
edit: which part did you break? The pump housing?
96Turbo is offline   Reply With Quote
Old 07-19-2012, 05:50 PM   #4
1320VR4
I did have new washers on either side.
I broke the pump housing. It split down the side of the housing. The split is about the length of the funky banjo bolt that holds it down. A majority of the crack goes right down the seam where the two pump halves I guess were cast or joined together.
The guy at the store said "65ft/lbs? oh it's a banjo bolt it shoudl have been 65 in/lbs" There's no way a power steering line is in inch pounds. I have screws on my r/c car tighter than that, haha.
Old 07-19-2012, 06:53 PM   #5
Dorifto Machine
Dorifto Machine's Avatar
Dorifto Machine is a well-known jackass
Wow, I usually stay away from using a impact to remove or re-torque items like these. Can strip way to easy.
40 ft-lbs should of been sufficient . Its The crush washers do a good job at sealing it let alone.
Dorifto Machine is offline   Reply With Quote
Old 07-19-2012, 10:26 PM   #6
1320VR4
40 ft-lbs should of been sufficient . It The crush washers do a good job at sealing it let alone.
To be clear I used an impact to remove it from the old pump because I couldn't get a hammer situated in a way to get the thing cracked loose, I didn't use the impact on the new pump
Old 07-19-2012, 10:37 PM   #7
leung
leung's Avatar
Trader Rating: (73)
leung is an unknown quantity at this point
Feedback Score: 73 reviews
Meh i hand torqued all the bolts when i did my sr swap including PS lines and such, no probs whatsoever still.
leung is offline   Reply With Quote
Old 07-19-2012, 11:09 PM   #8
1320VR4
I did it by hand and tried it and it sprayed fluid everywhere, then I went for the torque settings and no beans. I think the casting was flawed before hand, I just want to know if it was my fault or not, haha.
Old 07-21-2012, 10:01 AM   #9
ixfxi
ixfxi's Avatar
Location: bangin on my chest Account: BANNED #fucksupreme
ixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfection
exchange it from the store you bought it from
and next time, dont overtorque it like a knuckle head
ixfxi is offline   Reply With Quote
Old 07-21-2012, 10:29 AM   #10
cmg
cmg is an unknown quantity at this point
If your crush washers are still in usable condition theres no reason why you can't hand tighten it to the point it feels tight. Ive always just hand tightened by feel with good washers and never had a problem.
cmg is offline   Reply With Quote
Old 07-21-2012, 10:40 AM   #11
srTonydet
srTonydet's Avatar
srTonydet is an unknown quantity at this point
+1...better to be safe than sorry
S13 Coupe...DD
srTonydet is offline   Reply With Quote
