Old 09-12-2012, 09:48 PM   #1
kouki_drifter
kouki_drifter's Avatar
kouki_drifter is an unknown quantity at this point
Question cp piston ring install/orientation? help
ok i just bored my s14 sr20det 20 over to 86.5mm, i bought me some CP pistons and the instructions suck! no clear explanation on how the rings should be orientated on the piston, like oem 90deg of each other or different like wiseco?. also I am wondering the difference in ring gap from oem 86mm to the new 86.5mm? ive already googled it and searched with no answer, if anyone can help me out i would appreciate it!
kouki_drifter is offline   Reply With Quote
Old 09-12-2012, 09:50 PM   #2
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
I used oem orientation for my cp pistons
Also checked ring gap according to cp instructions, it's been a minute but I think they were all in spec didn't need to file anything down.
Hope that sheds some light
@UpshiftEngineering
KoukiMonsta is offline   Reply With Quote
Old 09-12-2012, 09:53 PM   #3
kouki_drifter
this is all that was included with the pistons, the link all the way at the bottom of the page
Piston Tech
Old 09-12-2012, 09:55 PM   #4
kouki_drifter
thanks! i was wondering? because i had wiseco pistons on the motor before and the instructions on ring orientation was way different from oem, just wondering if cp instructions are the same? what size pistons are you running?
Old 09-13-2012, 01:05 AM   #5
oni jake
oni jake is an unknown quantity at this point
Use OEM specs for the orientation.
As for ring gap, on a turbo application, it is Bore (in inches) X .0055 = Top Ring Gap.
86.5mm = 3.40551in
3.40551in X .0055 = 0.018730305in
Top ring gap should be .0187in
The next ring is simply .004in to .008in over. So, shoot for .025in.
We just this on our SR with CP pistons and found that the gaping was not correct from the factory. So please, make sure you take the time you do this.
oni jake is offline   Reply With Quote
Old 09-13-2012, 05:43 AM   #6
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
I replied in the other thread about filing your rings, but here^that guy seems to have helped you. Listen to him.
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 09-13-2012, 07:19 PM   #7
kouki_drifter
Sounds good man thank you! One more question which side of the piston goes to the front of the motor? The wiseco pistons are labeled these aren't
Old 09-14-2012, 12:03 AM   #8
kouki_drifter
thanks! anyone know how the pistons go installed? which side goes to the front of the motor? or does it matter? my previous wiseco pistons were labled fwd-> these CP pistons are not? now if i have to file the ring gap i do not have a ring gap file, can i use a dermal with a metal cutting disk and just mount it in a vise and squeeze the ring gap around the disk and file that way? or file by hand?
Old 09-14-2012, 12:32 AM   #9
Walperstyle
If you file by hand, take your time. Don't take too much off, and keep checking with a spacer/feeler tool.
Old 09-14-2012, 01:32 AM   #10
kouki_drifter
Ok so how does the piston mount to the rod which side faces to the front of the motor? Does it not matter?
Old 09-14-2012, 05:32 AM   #11
Walperstyle
I didn't answer because I'm not 100% sure. I have CP 8.6:1 for my KA-T but I can't exactly inspect them at the moment.
Old 09-14-2012, 10:39 AM   #12
kouki_drifter
Hmm it's kind of weird that they wouldn't be labeled, even of it doesn't matter why not label any way to get rid of the guess work ?
Old 09-14-2012, 02:40 PM   #13
kouki_drifter
Ok on #1 ring gap I have .014 / 0.35mm on my filler gauge so I must be at .018 /0.45mm?
Old 09-14-2012, 04:20 PM   #14
kouki_drifter
Ok #1 is at .018 #2 I got a little file happy I guess and went to .026 which is ok
Old 09-15-2012, 12:31 PM   #15
Pinggg
Pinggg's Avatar
Trader Rating: (22)
Pinggg is an unknown quantity at this point
Feedback Score: 22 reviews
If it's giving you that much problem just let a machine shop assemble it.
That's not something you want to mess up on and think it's right.
Pinggg is offline   Reply With Quote
Old 09-19-2012, 01:21 PM   #16
kouki_drifter
na i got it done no big deal
