09-25-2012, 04:37 PM | #1 |
DOC Race Turbo Manifolds
DOC Race Manifolds from Assaultech.com
Please post up or PM us for pricing We Sell Turbos for All Setups As Well! SR20DET Nissan SR20DET T25 Bottom Mount -T25 Flange -Retail: $695 Nissan SR20DET T3 Top Mount Manifold -T3 flange -Option for 2-bolt 38mm, Tial MVS or MVR/44mm wastegate flange -Retains AC -Stainless downpipes are also available upon request for $350 in 3" Stainless with 4-bolt, 5-bolt or V-band flange. -Retail: $695 Nissan SR20DET T4 Front Facing Manifold -Open T4 flange -Single Tial MVR or Dual MVS gate option -Retains Powersteering and Air Conditioning on S Chassis -Retail: $945 Nissan SR20DET V-Band Top Mount Manifold -Tial V-band Inlet flange -Option for MVS or MVR V-band wastegate flange -Retains AC -Stainless downpipes are also available upon request for $350 in 3" Stainless with 4-bolt, 5-bolt or V-band flange -Retail: $745 KA24DE KA24DE T25 Bottom-Mount -The DOC Race Nissan KA24DE T25 Bottom-mount Turbo Manifold was designed to be a bolt-on manifold that will support most Internally Gated T2 frame turbo's. This manifold is able to use the SR20DET T25 Turbo outlet and retains A/C and Powersteering. -Retail: $695 KA24DE T3 Topmount Manifold -Fits ALL Twincam KA24DE Engines, 91-98 240SX -Powersteering pump bracket modifications necessary -Available with a MVS or MVR wastegate flange, this T3 turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. The DOC KA Topmount turbo manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit much larger frame turbo’s then our traditional bottom-mount T25 manifold. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds. -Retail: $695 RB20/25/26 RB20/25/26 Openscroll Topmount -T4 Open Inlet Flange -Single MVR Wastegate flange standard -The DOC Race RB Topmount Turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. The DOC Topmount manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit Larger Frame Turbo's. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds. -Retail: $1695 RB20/25/26 Openscroll Topmount -Standard with Dual Tial MVS V-band wastegate outlets -Up to 4" downpipe -Tubing specs: 1.660" OD, 1.380" ID, 0.140" wall rated for 1300hp -The DOC Race Twinscroll Turbo manifold is similar to our Topmount manifold application. Our Twinscroll manifold is for maximum flow of your engine and turbo including the best possible spool and no limitations of the maximum output of your combination. DOC Race Twinscroll manifolds have had years of development in order to utilize the proper exhaust pulses to eliminate unwanted exhaust backpressure and vale overlap, in-turn giving you maximum airflow. This manifold is simply the most efficient available on the market! D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds. -Retail: $1995
Danny @ Assaultech Performance | [email protected] | 205-588-0960 | AIM: AssaultechDan |
09-26-2012, 01:23 PM | #6 |
09-26-2012, 02:38 PM | #7 |
bump to the top
09-27-2012, 01:10 PM | #9 |
09-28-2012, 09:34 AM | #10 |
bump to the top
09-30-2012, 03:04 PM | #12 |
What are the prices on the rb25 manifolds?
..IMO (nothing personal) retail doesn't mean crap and if you're going to post retail price why not save the bs and just post actual price? I never got the hang of that as I see it all the time! Lol
10-01-2012, 09:00 AM | #13 | |
-Danny
10-02-2012, 10:36 AM | #14 |
bump to the top
10-03-2012, 12:25 PM | #15 |
bump to the top
10-04-2012, 01:00 PM | #17 | |
-Danny
10-05-2012, 08:56 AM | #18 |
bump to the top
10-08-2012, 01:26 PM | #19 |
bump to the top
10-08-2012, 02:32 PM | #21 |
10-09-2012, 09:55 AM | #23 |
Edit: 2 year warranty as long as it isn't install error!
Danny @ Assaultech Performance | [email protected] | 205-588-0960 | AIM: AssaultechDan Last edited by Assaultech; 10-09-2012 at 12:42 PM.. |
10-10-2012, 01:17 PM | #24 |
bump to the top
10-15-2012, 11:49 AM | #25 |
bump to the top
10-16-2012, 12:40 PM | #26 |
bump to the top
10-17-2012, 09:47 AM | #27 |
bump to the top
10-22-2012, 02:17 PM | #28 |
bump to the top
10-23-2012, 02:45 PM | #30 |
bump to the top
