Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 10-03-2012, 07:55 AM   #1
IMPORTIMAGE
IMPORTIMAGE's Avatar
Trader Rating: (78)
IMPORTIMAGE is an unknown quantity at this point
Feedback Score: 78 reviews
Send a message via AIM to IMPORTIMAGE
Arrow Fortune Auto Coilovers Series 4 (BRAND NEW!) @ Import Image Racing!******************
CALL 941-257-9618 and mention BILLY to receive special pricing ON ZILVIA!!!!!
+ COMBO WITH ANY SPL PRODUCTS!
Click here to see Fortune's for your Nissan!
Now with brake line brackets!
DIGRESSIVE* All Fortune Auto shock absorbers use Digressive piston technology. This technology allows for stiff low speed rebound force which helps give better control of driver inputs such as roll, dive and squat. However, at fast stroke speeds (i.e. high speed bumps) the suspension is kept supple in response to bumps and irregularities in the road.
- Dyno tested
- Mono-Tube damper with high pressure nitrogen
- 24-step rebound adjustable dampers
- Spherical Bearings
- IP synthetic 5w or 10w shock oil (prevents cavitation and promotes superior heat dissipation)
- 6061 Forged & Anodized aluminum mounts and camber plates**
- Height adjustment independent of pre-load
- 5 year Manufacturer's Warranty
- Swift springs upgrade available
- Rebuild-able in the USA
- Revalve-able in the USA
OPTIONAL SWIFT SPRING UPGRADE!
Optional Roller Bearing Upgrade!
Recently only available on race applications and mega dollar suspension systems. Fortune Auto now makes spring noise and spring "twang" a thing of the past. Needle Thrust Roller Bearings are essential for noise-free operation on vehicles with front strut configurations. Vehicles with front struts tend to turn the front springs on coilover applications. This results in the spring dragging on the spring perches and making an annoying "boing" or "twang" sound. This sound is harmless but can get annoying at times. This noise is more prevelant in low speed occurances such as turning into a parking spot or when temperatures are below 60 degrees Fahrenheit. We have also noticed that heavier cars benefit greatly from this solution (Evolutions & WRX/STi platforms.)
Fortune Auto now offers a solution to this common problem! Bearings come in a set of 4 for the front struts (with 8 thrust washer plates). The washer plates sandwich the roller bearings and sit at both ends of the spring / spring perch. This offers silky smooth operation and is truly a noise-free solution for any 60mm ID coilover! Our roller bearings are designed to be lubricated with white lithium grease before install. These bearings can also be installed at our facility on all new coilover purchases.
Fortune Auto 510 series coilovers
- Incorporate a "ULTRA" DIGRESSIVE" piston, 24-way damping, custom rates & a one year warranty
- 510 Series coilovers are CUSTOM built to order in the USA.
Featuring our new "Ultra" Double Digressive Piston (UDDP) with revised shim stacks, this "Ultra" Digressive piston allows for massive amounts of low speed rebound force that helps with driver inputs such as dive, pitch and roll. Furthermore, the rebound force greatly tapers off to provide the driver with a supple and compliant ride while maintaining superior mechanical grip over rough surfaces. After countless hours on the shock dyno and testing on the track, we are proud to offer these high performance coilovers that rival many high end European shocks that cost several thousand dollars more.
- Assembled in the USA
- Dyno tested
- Dyno graph supplied with all 4 shocks
- Amsoil synthetic shock oil (the ultimate in shock oil technology)
- "Ultra" Digressive piston
- Compliant track suspension solution
- Rebuild-able
- Revalve-able
Fortune Auto Dreadnaught Series!
DIGRESSIVE* All Fortune Auto shock absorbers use Digressive piston technology. This technology allows for stiff low speed rebound force. This helps give better control of driver inputs such as roll, dive and squat. However at fast stroke speeds (i.e. high speed bumps) the suspension is kept supple in response to bumps and irregularities in the road.
- Street-able track suspension
- Inverted Mono-Tube damper with high pressure nitrogen
- Swift springs standard
- Helper springs on some applications**
- Dyno tested
- Rebuild-able
- Revalve-able
- Oversized digressive piston
- Italian IP synthetic shock oil
- Rebound adjustable
- 6061 Anodized aluminum mounts and top hats
- 1 year warranty
- Modularity - upgradable at anytime to 2-way
Regards,
[email protected]
AIM: ImportImageBilly
ImportImageRacing | Discount Performance Parts | Subaru, Mitsubishi, Nissan, Mazda Import Image Racing
Phone#: 941-257-9618
Visa/Mastercard/Discover/Paypal and (amex) Google checkout!
www.facebook.com/officialimportimageracing
IMPORTIMAGE is offline
Old 10-04-2012, 11:51 AM   #2
IMPORTIMAGE
Trader Rating: (78)
Thursday Bump!
Regards,
[email protected]
Old 10-08-2012, 01:00 PM   #3
IMPORTIMAGE
Trader Rating: (78)
Monday Bump!
Regards,
[email protected]
Old 10-10-2012, 11:22 AM   #4
IMPORTIMAGE
Trader Rating: (78)
Wednesday Bump!
Regards,
[email protected]
Old 10-11-2012, 12:34 PM   #5
IMPORTIMAGE
Trader Rating: (78)
Thursday Bump!
Regards,
[email protected]
Old 10-12-2012, 02:48 PM   #6
IMPORTIMAGE
Trader Rating: (78)
Regards,
[email protected]
Old 10-12-2012, 03:35 PM   #7
slzybrzy
slzybrzy is an unknown quantity at this point
500 series for s13 shipped to 17543?
slzybrzy is offline
Old 10-14-2012, 06:48 PM   #8
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
500 serie (swift spring upgrade and roller bearing up-grade) + spl arms
for a S14 ship to montreal , canada !
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline
Old 10-15-2012, 12:56 PM   #9
IMPORTIMAGE
Trader Rating: (78)
PMed!
Regards,
[email protected]
Old 10-17-2012, 09:16 AM   #10
IMPORTIMAGE
Trader Rating: (78)
Wednesday Bump!
Regards,
[email protected]
Old 10-19-2012, 10:01 AM   #11
IMPORTIMAGE
Trader Rating: (78)
Friday Bump!
Regards,
[email protected]
Old 10-19-2012, 05:10 PM   #12
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
500 series (swift spring upgrade and roller bearing up-grade) shipped to 95827?
and another quote without the upgrades to same area code. 9k 7k spring rate. Thanks.
Driftphreak87
Okinawandrifter87 is offline
Old 10-22-2012, 12:58 PM   #13
IMPORTIMAGE
Trader Rating: (78)
PMed!
Monday Bump!
Regards,
[email protected]
Old 10-23-2012, 12:34 PM   #14
IMPORTIMAGE
Trader Rating: (78)
Tuesday Bump!
Regards,
[email protected]
Old 10-26-2012, 10:27 AM   #15
IMPORTIMAGE
Trader Rating: (78)
Friday Bump!
Regards,
[email protected]
Old 10-28-2012, 06:22 PM   #16
Matahari
Matahari is an unknown quantity at this point
Price of 500 series with roller bearing shipped to 89131?
Matahari is offline
Old 11-02-2012, 08:40 AM   #17
IMPORTIMAGE
Trader Rating: (78)
Friday!!
Regards,
[email protected]
Old 11-05-2012, 01:58 PM   #18
IMPORTIMAGE
Trader Rating: (78)
Monday Bump!
Regards,
[email protected]
Old 11-06-2012, 01:51 PM   #19
IMPORTIMAGE
Trader Rating: (78)
Tuesday Bump!
Regards,
[email protected]
Old 11-06-2012, 07:55 PM   #20
LowLifeS14
LowLifeS14 is an unknown quantity at this point
Fortune 500/510 for a S14 shipped to 75050 please.
1998 S14
LowLifeS14 is offline
Old 11-08-2012, 01:28 PM   #21
IMPORTIMAGE
Trader Rating: (78)
PMed!
Thursday Bump!
Regards,
[email protected]
Old 11-12-2012, 10:16 AM   #22
IMPORTIMAGE
Trader Rating: (78)
Monday Bump!
Regards,
[email protected]
Old 11-13-2012, 09:11 AM   #23
takechan
takechan is an unknown quantity at this point
500 for s14 shipped to 32608
takechan is offline
Old 11-13-2012, 09:27 AM   #24
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Alright fuck rebuilding my HKS coils. These are sick.
510 Series 4, Swift 8k Front/6K rear w/helper springs and roller bearings for S14 shipped to 92107.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline
Old 11-16-2012, 11:56 AM   #25
IMPORTIMAGE
Trader Rating: (78)
PMed!
Friday Bump!
Regards,
[email protected]
Old 11-16-2012, 01:03 PM   #26
IMPORTIMAGE
Trader Rating: (78)
PMed!
Friday Bump!
Regards,
[email protected]
Old 11-19-2012, 02:19 PM   #27
IMPORTIMAGE
Trader Rating: (78)
Monday Bump!
Regards,
[email protected]
Old 11-19-2012, 02:43 PM   #28
krowles
krowles is an unknown quantity at this point
Pm me a price on an s14 setup with the standard spring rate and the 8/6k spring rate
krowles is offline
Old 11-21-2012, 01:33 PM   #29
IMPORTIMAGE
Trader Rating: (78)
Wednesday Bump!
Regards,
[email protected]
Old 11-23-2012, 03:43 PM   #30
p3t3y18
p3t3y18's Avatar
p3t3y18 is an unknown quantity at this point
500 series for s14 with swift spring upgrade and helper springs shipped to 90670
p3t3y18 is offline
