Old 10-28-2012, 11:53 AM   #1
slidewaysII
slidewaysII is an unknown quantity at this point
WTF is in my SR20DET tranny...
Hello zilvia,
So I yanked my transmission out of my S13 last night and this is what I found chillin' in the output shaft... WTF is it? I'm thinking of just junking the tranny after I take the bell housing off, or can it be cleaned and saved?
slidewaysII is offline   Reply With Quote
Old 10-28-2012, 12:52 PM   #2
Memberofthe600hpkaclub
Memberofthe600hpkaclub's Avatar
Memberofthe600hpkaclub is an unknown quantity at this point
Urhmmm did you have the lower cover on it? Looks like u picked up some debris..pull it out and see if it Fugged anything up n get a new seal
Memberofthe600hpkaclub is offline   Reply With Quote
Old 10-28-2012, 12:56 PM   #3
slidewaysII
i took out my driveshaft out to replace the seal and when i looked to see if there was a seal i saw the end of this piece in question. I spun the output shaft and it moved freely so i grabbed it with some needle nose pliers and pulled it out...
Old 10-28-2012, 01:10 PM   #4
jr_ss
Is there anything wrong with the transmission beside having that metal rod in it?
Old 10-28-2012, 01:13 PM   #5
slidewaysII
When i drove it home it vibrated like crazy and made a humming noise, i thought it was the driveshaft, but i guess not. When i took out the VSS sensor a bunch of metal flakes came out, i plan on breaking open the case later today.
Old 10-29-2012, 12:25 AM   #6
cotbu
cotbu's Avatar
Are you saying you want us to believe, this came out of the transmission that also had a drive shaft installed?
That looks to be about 12in I could be wrong, but I call bullshit anyway. No signs of gear oil hmmmmmmmmmm.
Old 10-29-2012, 10:15 AM   #7
240pimp
240pimp is an unknown quantity at this point
check the shop manual. If that is actually supposed to be in there, something is seriously fugged up in your trans that you could get that piece out so easily.
Sounds like you need to start looking for another trans.
93 Hatch w SR20
240pimp is offline   Reply With Quote
Old 10-29-2012, 10:19 AM   #8
Sileighty_85
Sileighty_85's Avatar
lol wow thats a first. It is part of the tranmission, its a guide. its connected to the shifter side bell housing so you can just get a KA BH section and swap it.
EDIT : that is if the gears arnt all fucked up
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-29-2012, 10:27 AM   #9
slidewaysII
I've been searching the web for KA and SR tranny diagrams, breakdown illustrations and have found anything, just a general "take out trans, split case apart, pull gearbox out...ect"
I split it open yesterday and I didn't find anything wrong with it, gears, syncros,
Shift forks, all look fine....
Old 11-03-2012, 01:54 AM   #10
slidewaysII
Sileighty_85, thanks for the useful information!
I broke it down to bear bones and everything seemed fine, minus that guide. thought maybe i dont need it? wrong. I put everything back together and started shifting through the gears and i REALLY had to hunt for them, but they did go in, so i thought maybe ill throw it back in and ride her till she blows, not 2min after i thought about it the shifter got stuck in 3rd and locked up.. good thing i didnt put it in. i just searched for a new tranny on here and found a solid one in LA for $220. now just waiting on my new ACT clutch and im back on the track! Thanks Zilvia, mods can close the thread now.
Old 11-03-2012, 04:11 AM   #11
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
Remember KA transmissions will work when you swap out the bellhousing, that will save you some cash if it ever goes out again. RB20 will work as well but for some reason people tend to associate those with performance transmissions.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
