Old 06-26-2012, 12:22 PM   #31
TAP240
TAP240's Avatar
TAP240 is an unknown quantity at this point
Originally Posted by Pinggg View Post
Should of gotten AN turbo lines while you were already there changing shit.
Thought about it..but I saw that the stock lines would work so I figured I'd give them a try.
TAP240 is offline   Reply With Quote
Old 06-26-2012, 02:00 PM   #32
ultimateirving
ultimateirving's Avatar
I used my upgraded stainless lines, for coolant, and a had a custom oil line made from my fab guy. still uses the banjo bolt to reduce the oil pressure.
Z32 with lq4 swap
Old 06-26-2012, 09:50 PM   #33
TAP240
TAP240's Avatar
I ended up just putting some silicone gasket sealer around the fittings, seems to be stopping any leakage.
Did some pulls today with the new turbo...slight lag, not too bad though..at full boost about 3800-4k. But the boost comes in STRONG! my AFRs are at about 10.9-11.2 during the heat of the day, and when it cools down at night they are at about 11.3-11.5, right where I like them. I've no complaints about it what-so-ever
Old 06-27-2012, 01:35 PM   #34
ultimateirving
right on man.
for the price its a little sledgehammer. Hits hard haha.
Z32 with lq4 swap
Old 06-27-2012, 03:15 PM   #35
TAP240
TAP240's Avatar
Originally Posted by ultimateirving View Post
right on man.
oh no doubt! lol How's yours running?
Old 06-27-2012, 03:19 PM   #36
ultimateirving
Everything is straight for now, Could use a retune, for Phoenix conditions(mine is a mail order rom tune)
Also my boost controller is tired, and doesnt open the waste gate very quickly. so i often over boost, hitting my boost limiter, bleeding boost to 15psi..
And last complaint, tranny is pos. shifting from 1st to second at high rpms grinds.
But other then that, life is peachy. Loving my coilovers i put on 2 mos ago as well.
Z32 with lq4 swap
Old 06-27-2012, 03:34 PM   #37
TAP240
TAP240's Avatar
nice nice! sounds like a few tweaks here and there and you'll be golden!
Old 06-27-2012, 04:05 PM   #38
Nisbro
Nisbro's Avatar
Nisbro is an unknown quantity at this point
Ive been running this turbo on a basically stock s13 SR for a few months now, and i love it! Its a bit laggy on a stock motor, but ill be able to fix that soon. I havent had any problems with this turbo what-so-ever, and highly recommend it if you're looking to save money wherever you can!
3NAW/Battlestags
Nisbro is offline   Reply With Quote
Old 07-09-2012, 07:14 PM   #39
ultimateirving
Switched back to 91 octane for the time being, been doing more long distance driving.. Boost is still strong hitting 21psi in 3rd is wicked!
Stock head and bottom end, hope it holds out lol.
22.5mpg with a/c on in az heat.. not too bad for 91.
also, i notice, at idle my vac is like -10-(-12) mm/hg. where are u guys at, it was closer to -18 with my t28.
I boost leak tested my whole car and it runs fun so no, there is not a vac leak. No my bov is not leaking at idle, Just want to know if any other RS3871 owners have noticed this.
Z32 with lq4 swap
Old 07-09-2012, 07:23 PM   #40
Trinidrift3
Trinidrift3's Avatar
Trinidrift3 is an unknown quantity at this point
i have heard that after undgrading turbos, your vaccum will go down. just what i heard.
btw can anyone recommend whether this or the godspeed td05 18g is better for a stock redtop sr20. i have heard great reviews on both
Trinidrift3 is offline   Reply With Quote
Old 07-11-2012, 06:45 PM   #41
TAP240
TAP240's Avatar
at idle my vac is at about -17 to -15, and when in gear under decel my vac goes right to -21. (from what I've experienced with other cars and reading up, that's about right)
Old 07-18-2012, 09:41 AM   #42
Giuseppe@EnjukuRacing
Giuseppe@EnjukuRacing's Avatar
Giuseppe@EnjukuRacing is an unknown quantity at this point
Send a message via AIM to Giuseppe@EnjukuRacing
ultimateirving - Im glad you are happy with the turbo, if you do get any videos please post up.
Giuseppe@EnjukuRacing is offline   Reply With Quote
Old 09-22-2012, 11:35 AM   #43
ultimateirving
This Turbo really pulls. Was holding 20psi all day! Well I boosting hard this morning, my boost blewout/melted a coupler. so i had to pull over and fix the giant vacuum leak.
Here is a picture of the carnage, cheap ass orielly parts. I gotta order some of the silicon triple layers couplers.
And this is how i made it home. Electrical tape ftw,
was able to cruise to orielly on the way home to get a temporary replacement and return this POS
Z32 with lq4 swap
Old 11-05-2012, 12:01 PM   #44
Jayem
Jayem is an unknown quantity at this point
I've had my rs3871 for a couple of months now and it pulls hard just on stock 8 pounds. How do you have your boost controller hooked up? I'm ready to turn up the boost and not quite sure how to hook one up on the 3871
Jayem is offline   Reply With Quote
Old 11-05-2012, 02:20 PM   #45
ultimateirving
You can hook up a boost controller on any turbo. The controller goes in between the turbo and the waste gate actuator, depending on if its manual or electronic they hook up differently, but there are plenty of diagrams available on the web.
Z32 with lq4 swap
Old 11-19-2012, 06:18 PM   #46
unreal-
unreal- is an unknown quantity at this point
I've been having problems with my 3871. For the past few weeks ive been tracking down a overboosting issue. Ive replaced all visible vac lines, FPR has its own vac line from manifold, BOV and boost gauge share a source. Hallman MBC is installed, but it overboosts whether it is installed or not.
Boost leak check revealed no leaks except at the turbo itself. Sounds like its coming from the CHRA area. Rest of the motor is air tight (FMIC couplers, injector o rings and insulators, TB and IM gaskets, EGR blockoff gasket, BOV flange)
My setup:
3871 with garrett 7# actuator
ISIS FMIC
ISIS V1 manifold+dp+elbow
Five-o 580cc inecjtors
Enthalpy tune
Z32 MAF
unreal- is offline   Reply With Quote
Old 11-19-2012, 07:20 PM   #47
Pinggg
Pinggg's Avatar
Trader Rating: (22)
Pinggg is an unknown quantity at this point
Feedback Score: 22 reviews
^^ give ken @ enjuku a call.
Pinggg is offline   Reply With Quote
Old 11-19-2012, 07:20 PM   #48
ultimateirving
My setup:
ISIS FMIC
Enthalpy tune
Z32 MAF
any reason your not using the ISIS adjustable wastegate actuator?
because the factory ISIS WGA holds about 12-14psi... and you should not be able to overboost without a MBC hooked up..
If it is still overboosting means ur wastegate isnt opening, disconnect the actuator and see if you can swing the flapper.
Z32 with lq4 swap
Old 11-20-2012, 02:18 AM   #49
unreal-
I thought that the WGA was the culprit and replaced it with a ATP/Garrett WGA. And i was told that it (the ISIS WGA) holds 8# out of the box at its lowest setting. Even running straight WGA to compressor housing, and minimal preload, i get overboost once the RPM's go beyond 4000.
The flapper swings freely, and the actuator arm moves without binding.
Have you done a boost leak check with your setup? do you get a hissing sound from that area? Im pretty sure that hearing air from that area isint good.
Old 12-06-2012, 05:48 PM   #50
ultimateirving
hey man sorry i havent replied to this lately, but there should be no hissing from the turbo.
Do you have the crank case vent still hooked up to the intake? I noticed when i temporarily capped the T on the valve cover it made a wierd hissing/whining sound so dont do that.
Z32 with lq4 swap
Old 12-16-2012, 10:01 AM   #51
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Sounds like an issue of the internal gate simply not being up to task. You can try preloading the arm a little to see if it will help, but the only real boost creep solution is to go external wastegate. With that said, it may spike a little and then calm back down by 6000/7000 so be aware of that as well.
Old 12-18-2012, 06:31 PM   #52
mr2gons14
mr2gons14's Avatar
mr2gons14 is an unknown quantity at this point
i got 3871 hooked up a few months back and the bitch pulls hard as hell for the price. just need to get a new damn af gauge (hopefully an aem). I also wanna get a pfc so i can get a tune lol. Currently running an enthalpy but idk i feel better about getting a dyno. Back in az this sat will have my car there mid jan hope to run into a few of u out there or even in cali where im pickin my car up from.
zilvia.net/f/cars-sale/517359-95-240sx-sr20-swap-uras-greddy-apexi-ect.html
mr2gons14 is offline   Reply With Quote
Old 12-30-2012, 12:33 AM   #53
jamg
jamg is an unknown quantity at this point
bumping for more reviews on this turbo.
i might run it, as i can't really find a good brand used, for a good price.
jamg is offline   Reply With Quote
Old 12-30-2012, 01:12 AM   #54
mr2gons14
mr2gons14's Avatar
Irving and I both run it and its a great turbo for the price order through enjuku and u got a warrenty what more can u ask
Old 01-18-2013, 12:51 AM   #55
Izento
Izento's Avatar
Izento is an unknown quantity at this point
About to install my RS3871 on my CA18. I'll let everyone know how it goes.
Izento is offline   Reply With Quote
Old 02-15-2013, 12:44 AM   #56
Izento
Izento's Avatar
Install was successful. Boost hits very hard at 4k. Feels weird having a turbo spool so late. Very good bang for the buck though. But keep in mind, I don't have anything to compare it to other than a stock T25.
Old 02-15-2013, 08:53 AM   #57
ultimateirving
Awesome to hear my friend! that little 1.8 probably does have some trouble spooling it up but im sure you love how hard it hits when it does. =)
I been running mine consistantly at 17.5psi until i can get some fine tuning done.
need to order a nistune or something
Z32 with lq4 swap
Old 06-17-2013, 11:13 PM   #58
RedS-14
RedS-14's Avatar
RedS-14 is an unknown quantity at this point
Soo happy i found this thread! im running this turbo on 15psi,AFR's 10.0 on aem wide band.Spools pretty good after is got some miles on it.Im suprised how well your OEM hg is taking the 20-21psi! im scured to turn it passed 15 lol.
RedS-14 is offline   Reply With Quote
Old 06-18-2013, 11:30 AM   #59
ultimateirving
I killed my rs3871 with a bolt in the inlet, So i bought a gt2871r, Turned boost down to about 18psi now. and thats where ill keep it
Z32 with lq4 swap
Old 11-26-2013, 07:52 PM   #60
Izento
Izento's Avatar
225 whp / 205 tq on my CA18 with Poncams, 2.5" downpipe & exhaust. 15 psi.
