![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
![]() So as some of you know I recently parted out my SR in hopes of going with something more reliable and with much more power potential. So it was time to get rid of this paperweight and make space for something in an inline 6
![]() ![]() Then I sold my beloved BBS's ![]() And this is how she sat for a bit ![]() Til I got these 17x9.5+15 / 18x9.5+15 MB Battles to roll on (not the greatest but they wuz cheap) ![]() Stetched some rubber on em... ![]() ![]() Then it was time to empty the bay and rip the front end off - here is where we stand now ![]() ![]() Pulling as much as I can so we can get a nice coat of paint in the bay. Ill be picking up my 2j/R-154 this weekend and hopefully dropping her in to check fitment and decide if I am going to trim the radiator support for a bit more clearance. This isnt much of a build just yet (more of a demolition) so ill just throw in a few pics of the goodies that started rolling in this week. Treadstone Cast Manifold ![]() Precision 6266 .68a/r with 3-5/8" V-Band discharge ![]() Xcessive engine & Trans Mounts ![]() Tial MV-S, TRD Thermostat, and TRD Oil Filter ![]() Complete 2JZGTE gasket set including water pump, idler pulley, tensioner, etc,! ![]() So thats pretty much it for now. Ill be taking more pics as things come together... Until the next update ![]()
Didnt do much this weekend just picked up motor/trans and sent it to a buddys house for all new front seals/tensioner/timing belt/water pump/etc... Then she came home and I havent really done anything yet. I will be pulling off the stock twins this weekend and ordering some fuel components this week as well.
Pic of the shifter extension done by a local shop that S&O Teck (where I bought my engine/trans) sent it to be done... ![]() ![]() More pics/updates coming soon Hardparked... ![]() ![]() ----------------------------------------- So I found some motivation and decided to tackle the twin turbo removal... boy what a pita... After removing those I put on the treadstone manifold and turbo for a little mockup ![]() ![]() ![]() ![]() SO much more room with a single! Anyone thinking of doing this swap, do yourself a favor a ditch the twins. I pulled them off with the engine out of the car and it was a nightmare... I couldnt imaging doing this after the engine is in that tiny bay Shout out to this can of AERO KROIL for without you those silly twins would still be stuck to my 2j ![]() AERO KROIL > WD-40 ![]() Thats all I haz for now
Cool man, lookin good.
U ever use pb blaster? I've never heard of aero Karol ill have to try it.
@UpshiftEngineering |
#7 | ||
Thanks for the comments guys Just ordered a Wiring specialties Harness + Patch harness from Yury More progress pics next week
![]() Join Date: Apr 2007
Looking good bud! I'm excited to see how you have everything planned out. That turbo is gonna hit pretty hard, he should see 15-20psi around 3500
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo |
#13 | ||
![]() Fuel Injector Clinic 775cc High Impeadance Injectors + -6an Dual Feed fuel Rail ordered ![]() I just need an R154 trans mount so I can do some test fitting now
#15 |
nOw that the world hasnt ended... the build will commence
![]() Ran into some issues with the crappy treadstone manifold machining that I had to address before I buttoned up the exhaust side Pics and details coming this weekend as well as some heavy progress
#16 | |
![]() Anyway, I will be watching o.0
* S14SR22 * 9.0 c/r * GT3071R * |
#17 |
Well I havent done much....
Installed Marlin Crawler Shifter bushings which took soooo much play outta the shifter. This is a must have upgrade for anyone who doesnt already have it. Started installing driftmotion pulleys and Im currently working on finishing the stripping and painting of the engine bay Here are some shots of the machining that had to be done on the turbo to fit the treadstone manifold ![]() Holes slotted to slide turbo over about 2-3mm Original fitment ![]() ![]() Had to go with Socket Head Cap Screws due to hex heads not fitting ![]() 2-bolt to V-band wastegate adapter installed ![]() ![]()
#18 |
Wastegate installed
![]() ![]() ![]() Then this shows up today via Santa (UPS) fresh from Yury's (wiring specialties) workshop ![]() ![]() Harness comes ready for the Dakota Digital Boxes ![]() ![]() ![]() Also picked up one of these so that my sweet ass harness stays uncut and clean ![]() Ive gotta say Im impressed with the quality of this harness... cant wait to install it and fire it up Thanks Yury!
#20 |
That harness = a big pair of titties.
Keep it up
#21 |
![]() Join Date: Jan 2003
Trader Rating: (43)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 43 reviews
Let us know when u install ur harness. i'm kind of hoping yury have the race harness version asap, pretty much mill spec
fdrea |
#23 |
Did some work on the engine bay a few weeks ago now mostly prep work for paint and removal of battery tray and other useless brackets
Degreasing and removal of brake booster and other parts ![]() Battery tray removed ![]() Misc brackets removed ![]() Bit of sanding done ![]() Ordered some dry pearls (Green/Blue/Purple Chameleon for engine bay) and Green/White glow in the dark to experiment on the wheels ![]() Shooting for the one on the right ![]() ![]() After a few mins of light... ![]() ![]() More updates this weekend once we lay down some paint
#25 |
Engine bay officially painted and ready to receive an engine!
#27 |
Thanks
![]() ImageUploadedByTapatalk1359877108.322858.jpg That's the black base coat before the pearl
