#1863 | |
![]() Join Date: Sep 2010
#1864 | |
![]() Join Date: Apr 2006
if not its only like 2 or 3mm short of it
2015 Subaru Outback Overlander - Wagonofdoom |
#1865 |
will 17 x 10 et-1 fit on the rear of a stock body S13 at just over 1 degree of camber with just a roll? no overfenders. if so any pics? just to see how much roll it will have.
cheers |
#1866 |
Hey everyone, so I'm just looking for some DD wheels, preferably in the 16x7 or 16x8 size. I don't want to stagger them, and I don't stretch tires.
Specs of the car is s13, still on shock and spring (kyb gr2's and tein lowering springs) and circuit sports arm kit) I really don't want to roll the fender either, but I will if I need to, but I won't full the fender. Car currently has some 15x6 +10 280zx swastikas on it and they fill out the fender nicely, granted they are thin as shit. Tires have a large sidewall and sway in steep turns, like getting onto an onramp, which I just hate. Car is still 4 lug and I am still running stock brakes. Car is a DD. My gf drives it sometimes. The tires I will be running are either 215 or 225 /50 DZ101's. Love those tires and they are faily cheap. plus they should provide some curb protection, for the occasional slip. I want to buy Enkie RPF01's off tirerack and they have +43 offset. I plan on using a 7mm (1/4 in) spacer all around. I really just like the style of these rims, and the car is a DD so I want it to look good. I don't need it to be hella flush, but I don't want it to be a sunken battleship stance either. From what I hear that is a fairly decent size and offset, but ideally I'd like a 16x8 with +25 since I know they fit (my friend has a set of work Ewings in that size) almost perfectly. So if anyone can point me in that direction I'd be much appreciated. Searching this site and 240sxforums mostly pulls up 17in staggered setups with coilovers. well that doesn't help me. I've been brooding on the Enkies for a long time. It helps being stuck in France not being able to buy shit lol. |
#1867 | |
![]() Join Date: Jul 2005
Here is a 10 +0 with -4 camber: ![]()
![]() Instagram - SJKnoop |
#1868 | |
You won't be able to get rpf1 in a 4lug size that will fit an s13. I would look at 5zigen fn01r-c 17x9 +20, kosei k1 16x8 if you can find them. You can also find cheap aftermarket wheels (rota, varrstoen, xxr, etc. ) in 16/17 x 8,9 +20-25. That's probably around where you want to stay. If you go with a higher offset you will hit the struts, lower and you will hit the fender lip. |
#1869 |
They sell those enkies on tirerack, unless you mean a lower offset. I don't really want to go into 17's since I like the cushion that a 50 series tire provides, the cost of of a 16in tire, and don't want a large ass monster truck height from 17in rims with a 50 series tire. I know Tirerack also sells kosei's, but not really into the look of them.
I like the rota grids, but they are +10 and like I said they may poke out. I was looking into the 5zigens, but they don't sell that size new (16x8 +25-30ish if you find it prove me wrong) I read on this size that the ideal size would be a 16x7 +35, which is pretty much what the enkies would look like. I also don't want to go with a 9in wide wheel because of hitting the struts, plus it would just be added weight and I would need a wider tire (no stretch). XXR makes a few decent looking rims with that offset and size( 16x8.25 big whoop) and I think varrstoen makes one in that size. |
#1870 |
Man w/ CTSV & a Car Seat
Lemme get this straight, you don't want squishy sidewalks but you insist on running 16s with 50 series sidewalls and won't stretch them? That shit doesn't really add up since tall size walls will mean you'd have some sidewall flex.
Honestly don't waste your money on 7j rims, atleast go 8js and anything within +20 to 0 offset and go 225/50-16s. You run tires that are wider than the rim width makes the squishy sidewalks worst. To give you an idea 225mm roughly equates to 9 inches so 225 is square to most 9j wheels. Another cheap option, find some OEM Nissan wheels that are 16x8 +30s like ther r32 GTR or z32 TT rears only. |
#1871 |
No I do want squishy sidewalls, but I think you mean like they aren't square with the rim. If I get a 17in I'd go down in sidewall size to keep overall diameter of the tire the same to keep the speedo accurate.
225/50's are not that squishy, depending on what the sidewall is made with. DZ101's have a double steel belt and are fairly rigid, same with Khumo Ecstas. Falken azenies on the other hand (that people use to stretch) don't have as reinforced a sidewall and are therefor more plyable. A 225/50 will still absorb a speed bump better than a 225 35 or 40 on a 17in though. I hope I'm being clear. I want a "square" sidewall to the wheel. If I went with a 7in wheel I'd use a 205 or 215. With an 8in wheel I'd use a 225. Yeah I'd like to go with an 8in wheel and put 225/50's on it, but you're suggestions don't work since I'm still 4 lug. So I guess the rota grids would be decent for you're suggestion? Only pics I've seen are these: RIMTUCK.com - Setup and FS: 16X8 Rota Grids :: Low Offset :: Perfect fitment for 240SX : Wheels / Tires (for sale) I love the look of the second car, but I'm sure he has a slight pull in his rear panels. The first link the car looks kinda gay with his height and the stretch makes the whole tire/rim combo look small. Last edited by Rich260z; 11-25-2012 at 12:52 PM.. |
#1872 |
Z32 TT wheels are 8.5's FYI with a +35 offset.
#1874 |
Hey I got a set of SSR SP1 Profs 17x8 +24mm offset wrapped in Pirelli P zero 215 45 17... I need to replace the tires and does anyone have any suggestions for which size to go with and should i run spacers to have a flush fitment with stock metal? thanks!
(I was thinking of running a 15mm spacer up front and 20/25mm in the rear) again thanks in advance EDIT: on hks hipermax coils Last edited by Zilmatic; 11-25-2012 at 01:29 PM.. Reason: added more info |
#1875 | |||
![]() Join Date: May 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
Honestly Richard, just get some 16x7's or 16x8's that are cheap and look good to you. You know for a fact how my size and offset looks. Shit, I'll sell you my wheels for the right price! lol |
#1876 | |
225/40/18 fronts mild stretch 255/35/18 rears mild stretch or 215/35/18 fronts bigger stretch 225/40/18 rears big stretch u would prob need a 20-25mm spacer to clear coils up front. rears are fine with just a roll. hope this helps |
#1877 |
Hello everybody! I've searched but I'm still confused about one spec of the future wheels for my DD S13.
![]() The car is and will stay stock arched, but I'll roll and pull the fenders for sure; here in Italy we do have some sick laws about car mods so I'll be forced to run just one tyre size (F&R) that could be 215/45 R17 or 215/40 (actually I could also go for a 225 but would kill the car performance as the S13 have a CA18DET with around 220 HP). So here's the real question: will 17x9 +25 (like Rota Grids) fit with coilovers and a low ride? And if yes how much camber will be needed ? Don't want to use too much due the nature of the car that's daily driven ![]() Some people says yes and some don't without a tiny spacer. Here's some useful infos: _I'm planning to increase the steering angle (usual stuff spacer,tie rods etc) _I can't go 5 lugs or use spacers (yep it's considered illegal ![]() _Here in europe Rota wheels with 9J and 4x114.3 is only sold with +25 offset and not +12 or +15 like in the USA ![]() Many thanks for the help ![]() Cheers |
#1878 | |
![]() Join Date: Apr 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
Anyway, based on the conditions you pointed out...it won't be exactly "flush" but since you can't use spacers, I would just go with 215/45. As for camber, keep it simple: negative 2-2.5* (at most) will do you fine especially if you want to keep your fenders at a slight roll. |
#1879 |
hey guys i got some questions. I recently bought an S13 and the guy gave me a set of xxr 962 wheels. The rears are something around 10in and i believe the fronts are 8in. I cant get an answer out of the guy about the exact specs of the wheels. I also cant tell you what the offset is, Ive seen people with this wheel in different depths with offsets of 30, 35, 38 and 40mm. The back wheels seem to be fine as is. The front on the other hand is rubbing violently. Its hitting the coil. Im not sure what size spacers i need and/or camber i need to run. The suspension is completely stock as far as i know. help me out guys! I know i havnt given you guys much info. I can post pictures if you guys need them. thanks guys!
#1881 |
@fliprayzin, the guy told me that he believes he rear has a 30mm offset and the front has a 35mm. if that changes anything haha. and the wheels scrape even going strait fyi. ill try that, i just dont wanna waist money trying different spacers. could just say eff it and get 1.5 in spacers and fender flares haha.
#1883 |
![]() Join Date: Jul 2012
I got a good deal on some Square's but they're 18s. I can't really find any S13s with these wheels in this size.
Question is, would it be safe to say I could get away with these with a stretched tire(maybe 225/40??) and a slight fender pull? Maybe some camber? Not too good with wheel fitment. Any advice would help. Specs on all 4: 18x9.5 +12 ![]() Maybe something similar to this S13 (just not as beautiful, haha). Took this from the fitment whore thread. His specs written: 18x9.5 +10 225/40 -3.5 18x10.5 +22 235/40 -3.5 Rolled fenders ![]() |
#1884 | |
Trader Rating: (38)
#1886 |
WTF do you keep bringing this up? You need some spacers to push the wheel further out, away from the suspension. Just the fact that you can put the wheels on means all you need is a few mm. 3mm spacers will be more than enough. Now, stop posting, get some spacers and put it in the damn car...
#1888 |
Im looking to buy some xxr 522's for my s13. Ive been looking around online, but I can't seem to find any info on width & offset. My car is currently lowered 2 inches, and will be lowered more soon. Was wondering what would look best / fit my car. I also can't find any 17 4x114.5 lug patterns. Any help?
#1890 | |
![]() Join Date: Jun 2012
do you want to run camber or no do you want to roll or pull your fenders or no theres alot of factors you are leaving out |
