Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Forced Induction
Old 12-18-2012, 01:41 PM   #1
Jesse@PureTurbos
Jesse@PureTurbos's Avatar
Jesse@PureTurbos is an unknown quantity at this point
RB Rb25det bolt-on billet turbo upgrade!!!
ASK AND YOU SHALL RECEIVE!!!
We've had demand for a legit BOLT-ON RB25DET Upgrade Turbo, and here it is!
This is a Genuine OE RB turbo with heavy modifications.
Features:
-Oil feed, oil drain, and coolant ports accept stock RB fittings.
-Adjustable wastegate linkage
-Journal Bearing with steel 360 thrust for durability
-Billet compressor wheel
-Stage 3 turbine wheel
Note: Many RB oil feed lines have a built in restrictor
which must be replaced with a standard -4 oil feed line.
We recommend 450WHP MAX
$795!!!
+ $200 Core Charge (refunded when we receive your old turbo)
PURE TURBOS
760.721.7669
Jesse@PureTurbos is offline   Reply With Quote
Old 12-18-2012, 01:49 PM   #2
dreamin240sx
dreamin240sx's Avatar
dreamin240sx is an unknown quantity at this point
Send a message via AIM to dreamin240sx
This is awesome!!!!!
RB POWA!!!!!!!!
dreamin240sx is offline   Reply With Quote
Old 12-18-2012, 01:56 PM   #3
PrimeDirective
PrimeDirective's Avatar
PrimeDirective is an unknown quantity at this point
Is there a core exchange?
PrimeDirective is offline   Reply With Quote
Old 12-18-2012, 02:57 PM   #4
Lindsay Lohan
Lindsay Lohan's Avatar
Lindsay Lohan is an unknown quantity at this point
sick nasty.. what size is all them snails, turbine, compressor? Do we has choice?
Lindsay Lohan is offline   Reply With Quote
Old 12-18-2012, 04:13 PM   #5
Jesse@PureTurbos
$200 core deposit or send your core in first to waive the core deposit
Hi Ms. Lohan,
Them snails are stock RB which are just big enough for 450WHP. You can has custom compressor and wheel size options for specific power / spooling needs. This version is 54mm Billet compressor wheel and 57mm turbine.
PURE TURBOS
760.721.7669
Old 12-18-2012, 04:24 PM   #6
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
This is awesome! I'm going to get one for sure! I'm headed to get dyno tuned in the next month or two. I'll get ahold of you closer to the dyno day. Are they all ready to ship?
smoked240 is offline   Reply With Quote
Old 12-18-2012, 04:29 PM   #7
Jesse@PureTurbos
Yes sir. Let us know when you're ready.
PURE TURBOS
760.721.7669
Old 12-18-2012, 08:17 PM   #8
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
I basically know nothing about these turbos so maybe I might have a couple questions a noob would ask that might be helpful... a noob like me that is haha.
Will it fit on a SR? Is this turbo from a RB25? How does it compare to the stock turbo which I believe have ceramic blades or something like that?
Old 12-18-2012, 08:20 PM   #9
stricnynel0s
stricnynel0s is an unknown quantity at this point
wow i am impressed, now how about the rb26dett
stricnynel0s is offline   Reply With Quote
Old 12-19-2012, 12:13 PM   #10
Jesse@PureTurbos
No this will not fit an SR without modification. We have other turbos which are bolt-on for a SR motor. Yes this is a RB25 turbo. How does it compare? It's apples to oranges. This turbo can flow up to 450WHP! The ceramic turbines are trashed and replaced with an Inconel Stage 3 turbine.
We have done plenty of RB26DETT upgrades including Billet ball bearing. What we have advertised is "the tip of the iceberg". Feel free to contact us for details on a specific custom turbo build.
PURE TURBOS
760.721.7669
Old 12-19-2012, 05:15 PM   #11
trickey1991
trickey1991 is an unknown quantity at this point
can you get one thats externally gated?
92' R32 GTS-T 355whp
trickey1991 is offline   Reply With Quote
Old 12-19-2012, 05:17 PM   #12
Jesse@PureTurbos
Sure that's easy. We just remove the wastegate actuator and weld the wastegate valve closed.
PURE TURBOS
760.721.7669
Old 12-20-2012, 07:27 AM   #13
gonzo
gonzo's Avatar
gonzo is an unknown quantity at this point
What turbo's do you have that are bolt on for the SR motors ?
gonzo is offline   Reply With Quote
Old 12-20-2012, 09:25 AM   #14
b.series
b.series is making a name for him/her selfb.series is making a name for him/her selfb.series is making a name for him/her self
interested in the sr20 turbos as well. are the journal bearing??
b.series is offline   Reply With Quote
Old 12-20-2012, 01:32 PM   #15
Jesse@PureTurbos
Everything from upgraded SR journal bearing turbos to new ball bearing turbos. Just depends on your WHP goal and your budget. PM for details.
See the above response please. Feel free to PM us for details.
Thanks!
PURE TURBOS
760.721.7669
Old 01-30-2013, 09:34 PM   #16
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
On your website you have z31 55hp turbo upgrade, what are the specs and can the same be done for the rb25 turbo since they are similar and how much more does it cost?
WARNING: User has a low tolerance for stupidity. Post at your own risk.
redline racer510 is offline   Reply With Quote
Old 02-01-2013, 12:12 PM   #17
Jesse@PureTurbos
PM'd Thanks!
PURE TURBOS
760.721.7669
Old 02-25-2013, 05:41 PM   #18
2.5T_/<ouki
2.5T_/<ouki's Avatar
2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice
I'm very interested in this. So this turbo is rated at 450WHP max (Way beyond my needs).
- Do you know how much psi this turbo can handle?
- How much psi does the adjustable wastegate allow for?
- Can i be refunded my $200 core exchange after i receive and install this turbo?
Just to be 100% informed, i can purchase the already modified turbo for $795? I don't have to send mine in first to be modified?
I'm very interested,
Thank You
2.5T_/<ouki is offline   Reply With Quote
Old 03-06-2013, 10:53 AM   #19
sideways_s14
sideways_s14 is an unknown quantity at this point
Send a message via AIM to sideways_s14
Trying to bring this one back...
As I have a Neo motor, are you able to perform this billet upgrade mated to the OP6 rear housings?
Thanks...
Ramese
Silvia S14-RB25Neo
sideways_s14 is offline   Reply With Quote
Old 04-01-2013, 12:34 PM   #20
Jesse@PureTurbos
Thanks...
Sorry for the super-late response. Yes we can do this with the OP6 housing.
PURE TURBOS
760.721.7669
Old 04-01-2013, 02:43 PM   #21
sideways_s14
Awesome, good to hear... so, do you have stock of OP6 housings, or would I need to send mine in... and also, echoing 2.5T_/<ouki's post...
Thank You
Thanks!
Ramese
Silvia S14-RB25Neo
Old 04-01-2013, 04:30 PM   #22
Jesse@PureTurbos
No stock of the OP6 housing right now. You would have to send yours in.
- Max PSI depends on the motor specs. 450WHP is the max recommended output. For example a stock motor will make 450WHP at a different boost pressure than a motor with performance cams. Max boost will be in the 20-25 range.
- The adjustable wastegate will get you around 15psi. Use a boost controller to increase from there.
- Yes the $200 is just a deposit until we receive your old turbo.
- Correct, you don't have to send yours in first.
Thanks guys
PURE TURBOS
760.721.7669
Old 05-14-2013, 11:35 AM   #23
[email protected]
Paul@mastermindna.com's Avatar
Paul@mastermindna.com is an unknown quantity at this point
Any comparison as to how these perform over stock? Air flow charts? I have the crappy Series 1 turbo in my RB25. I not looking to upgrade the manifold so this looks like it will work perfect for my 350whp goal..
Edit: NVM I saw the other thread you had posted about a customer posting their results. I have FMIC, Blitz intake, 3' downpipe and exhaust, Splitfire coilpacks and will get tuned on a Apexi Neo. I should be ordering later in the month and can post up vids of the dyno pulls and charts.
Paul@mastermindna.com is offline   Reply With Quote
Old 05-16-2013, 01:36 PM   #24
Jesse@PureTurbos
OK great thanks. Feel free to PM us, email us, or call us directly if you have more questions.
PURE TURBOS
760.721.7669
Old 02-25-2014, 08:54 AM   #25
JDMfreak07
JDMfreak07 is an unknown quantity at this point
Will this fit on an rb20 with a stock manifold?
JDMfreak07 is offline   Reply With Quote
Old 05-18-2015, 10:46 AM   #26
ignited
ignited's Avatar
ignited is an unknown quantity at this point
Just came across pureturbos.com and am definitely going this route. Have a NEO RB25 turbo i'd like rebuilt, and upgrade to the billet wheels..
ignited is offline   Reply With Quote
