Old 12-28-2012, 11:14 AM   #5131
D.Adams
D.Adams's Avatar
D.Adams is an unknown quantity at this point
Send a message via AIM to D.Adams Send a message via MSN to D.Adams
Fixed a bunk ass rb25 s14 swap. The shops that thought they could do it decided to cut the hood latch and light mounts off so i made new ones. Small shit but its still fun to do love using my dimple dies..
Hood latch mount
Light mounts
Mounted up
Also had to section out the code to get the radiator / fans to fit
Also some high angle knuckles i made for a friend in Washington
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover
The build
http://zilvia.net/f/builds-builds-on...u-city-az.html
Owner of NVS Fabrications
D.Adams is offline   Reply With Quote
Old 12-30-2012, 12:25 PM   #5132
ShadowMan
ShadowMan's Avatar
ShadowMan is an unknown quantity at this point
You can look at my build to see exactly what I'm up to, but I'm looking for the measurement between the frame rails on my 1990 hatch. Before I cut into everything I measured as many different distances as I could, I just want to make sure what the correct measurement is.
Googling I came up with 1 post that says 31 1/4 inches. Not sure if this is right or not.
What I measured off my car before cutting and removing everything.
outsides=31 7/8 in (so I'm wider by about 5/8 in. This seems like alot to be off by to me but I'm an amatuer so maybe I'm wrong)
insides=27 3/4 in
The previous owner took this car to a shop that didn't align or measure a whole lot as the the whole radiator support/headlight unit was installed crooked. I would expect a little room for error but they were way off. the measurements from the center of the adjusment screw on the coilovers are off by 5/8 in.
Strut tower to passenger headlight bolt= 19 1/2, driver is 18 7/8. This is probably part of the reason why my headlights were pointing extremely to left iI would assume.
in any situation....thou shalt blaze
ShadowMan is offline   Reply With Quote
Old 12-30-2012, 12:43 PM   #5133
D.Adams
D.Adams's Avatar
insides=27 3/4 in
I can measure my buddys race car today and post it up. Its a straight frame car
The build
Old 12-30-2012, 10:32 PM   #5134
ShadowMan
ShadowMan's Avatar
That would be awesome. I did more measuring and I noticed the distance between the rails gets wider towards the front of the car. The difference is about a 1/2" from measuring over the steering rack, then measuring at the very front of the rails. Not sure if this is right. I appreciate any info you can get.
Old 01-01-2013, 05:35 PM   #5135
Purestock240
Purestock240 is an unknown quantity at this point
Oval track car
Purestock240 is offline   Reply With Quote
Old 01-10-2013, 08:08 PM   #5136
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
this thread = my mind melted
Tegheim - Home made 4 rotor Wolvo 142
Old 01-18-2013, 12:06 AM   #5137
ShadowMan
ShadowMan's Avatar
Throwing this out there to the wolves, don't be gentle with the critiques.
A lot of this has been doing and undoing it, to do it in what I think is the right way. Also just wanted to see if there was anything that needed to be undone quick, fast and in hurry because it's unsafe. I'm pretty much just using free scrap aside from the piping I had to go buy. Also, no pipe bender either, so that's not helping things either. And I'm just putting a cutoff wheel on my angle grinder to cut everything so that shit takes forever. Just keep that in mind when giving "suggestions".
Old 01-18-2013, 09:52 AM   #5138
C-unit
C-unit's Avatar
C-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to all
From my fabrictor:
Billet aluminum fiting for my VQ power steering pump.
C-unit is offline   Reply With Quote
Old 01-19-2013, 12:50 AM   #5139
EvoVIII808
EvoVIII808 is an unknown quantity at this point
Send a message via AIM to EvoVIII808 Send a message via Yahoo to EvoVIII808
I think everything looks good, except for some of the welds. It doesnt look like they were hot enough. Could be the camera and angle though.
Check Out My S13 Build
EvoVIII808 is offline   Reply With Quote
Old 01-19-2013, 01:58 PM   #5140
ShadowMan
ShadowMan's Avatar
Actually the problem was that I was using an extension chord for the welder which was smaller than it should have been. It led to inconsistent wire speed and heat. SO yes your right, it wasn't hot enough. I have a bit of grinding to do, ugghhh. I have another question though. Is it worth making the upper part of the rad/IC support removable or will it just decrease the overall strength of the whole vehicle? I plan on tracking the car for drift, autocross, and whatever else looks fun. I also have been making this air ducting and was wondering if I should weld it in or make it removable?
I figured a removable piece would be smart, but if it's more of a pain in the ass than it's worth, I'll just weld it in there.
Old 01-19-2013, 03:10 PM   #5141
The_jerk
The_jerk is an unknown quantity at this point
ive been buiding bumpers for my s13 and using a speedway motors hydro bender (3rd Generation Hydraulic Round Tubing Bender & 5 Die Set - Speedway Motors, America's Oldest Speed Shop).
it came with a bunch of different dies and seems to bend smaller pipe (1") no problem but when it came to the bumpers.. lets say it's good enough but not perfect for bending.
long story short, im using leftover bits of DOM 1 1/2" OD .95 pipe and no matter how much lube i use it is kinking in the bender.
what benders are you guys using? whats good and whats not worth messing with?
The_jerk is offline   Reply With Quote
Old 01-19-2013, 03:12 PM   #5142
EvoVIII808
JD Squared, Inc.
Old 01-19-2013, 03:17 PM   #5143
The_jerk
oh yeah, the bumpers i made..
this is the rear, its done and ready for paint now..
and the front.. work in progress. just have one upper bar for now. i hope to make a lower bar after that sits behind the lip of the bumper.
Old 01-19-2013, 06:03 PM   #5144
The_jerk
have you used the manual bender? ive heard that it works good if you have a 6 foot bar on it.
it also appears cheap @ 300 to buy but if you start adding up dies it gets expensive quick.
has anyone used or heard anything about the eastwood bender?
Eastwood Pro Former Tubing Bender - JEGS
ive used google with little to no good results on how this bender compares to other benders.
Old 01-19-2013, 11:50 PM   #5145
EvoVIII808
Alot of the guys use it. I personally dont have one yet, but it will be the weapon on choice. Dadams uses it, you can check out his buikd thread.
Old 01-19-2013, 11:53 PM   #5146
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
Nice !!! This is how I wanted to do mine but I used mild steel .120 but it would bend I need to source some Dom, also for the rear supports the ones that bolt up to the body did u used round tubing or square tubibg?
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 01-20-2013, 08:39 AM   #5147
The_jerk
i used some square tubing i had laying around. its a little bit thicker sidewall than the pipe on the bumper. i believe it is 1 1/2"
the front support is square also, i believe it is 2"
Old 01-20-2013, 08:46 AM   #5148
The_jerk
i searched for threads started by the user name "Dadams" and this came up twice..
Invalid User specified. If you followed a valid link, please notify the administrator
send me a link please!
Old 01-20-2013, 12:13 PM   #5149
PerilousActs
PerilousActs is an unknown quantity at this point
I use a Pro-Tools 105.
MB105 Heavy Duty Bender
PerilousActs is offline   Reply With Quote
Old 01-21-2013, 11:15 PM   #5150
ShadowMan
ShadowMan's Avatar
Took a few steps forward, and a couple back. Just when I think I'm on the verge of prepping the bay for paint I realize ho foolish I am.
I undid the headlight mounts because they were in the way of the upper ducting.
made it removable
new headlight mounts
made the upper rad/ic support removable. you can see where I cut it, then I welded in my old piston wrist pins inside the pipe because they were as perfect fit as one could hope for. Like they were machined to fit.
It slides all the way in. I still need to drill a hole to run a bolt through so I can secure it in place but you get the idea.
90% cmplete, I think.
modified bumper a little so it would fit around my smasmortion of an air duct
I have a long way to go as far as getting it completed. Hinsight is 20/20 and there are things I would do different given I had the ideal tools, but what can ya do? Got my buddies welder figured out. I'll admit that I didn't know using an extension chord was a big No-No. I guess it's common sense stuff but now I know and that was my problem never being able to find the right settings on the mig. So my recent welds have been better which makes things go faster. As always, any input, good or bad, is welcomed.
Old 01-24-2013, 04:18 PM   #5151
chucky norris
chucky norris's Avatar
chucky norris is an unknown quantity at this point
Send a message via AIM to chucky norris
What up guys? i have been reading this thread for a while now and there is a bunch of good stuff. I am looking to get my front end done on my s13. I need to get a full tubed front end because my car was involved in a car accident. i know i can just buy a shell with the money i am going to spend but i just don't want to give up on the car. i am located in socal, any help i would greatly appreciate it
"If you're not first ..... you're last"
Ricky Bobby
chucky norris is offline   Reply With Quote
Old 01-25-2013, 09:13 PM   #5152
EvoVIII808
He does most of the fab work here.
D.Adams
Old 01-27-2013, 01:49 PM   #5153
D.Adams
D.Adams's Avatar
Im here just PM me any questions
Thanks Mo for helping him out
The build
Old 01-28-2013, 06:31 PM   #5154
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
Quick change set-up for Dave Briggs 2013 FD s14
this is going on is s14 , the sr24vet from mazworx will put the power through a G-force gsr4 and the quick change in the back ...
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline   Reply With Quote
Old 01-28-2013, 06:38 PM   #5155
Purestock240
CA
Originally Posted by rbs14kouki View Post
this is going on is s14 , the sr24vet from mazworx will put the power through a G-force gsr4 and the quick change in the back ... we offer the service too if you want something like that !!!
did you do the work on Poirier Claude's 350 and their 240? similar setup they have
Old 01-28-2013, 10:56 PM   #5156
rbs14kouki
rbs14kouki's Avatar
Poirier set up was made by Scott (Dai Yoshihara mecanic)
I know Norm the mecanic for Poirier and he had the work done by Scott !
This is for the s13 i dont know about the z !
Im not the fabricator ! Ardo from Av Fab is ... i'm just a friend posting is stuff ! We just made the jig today . Looking foward to work on the subframe tomorow and get that car ready for FD 2013 !
AV FABRICATION
Old 01-29-2013, 02:38 PM   #5157
Otto347
Otto347's Avatar
Otto347 is an unknown quantity at this point
Quick change diff set-up for sale ! 7500$ with the diff and axles or 2000$ for the labor no parts included !
Wrong place to pedal your parts or services.
Originally Posted by atutt View Post
Or you could have stopped being a lazy asshat and done some research.
Otto347 is offline   Reply With Quote
Old 01-29-2013, 09:32 PM   #5158
rbs14kouki
rbs14kouki's Avatar
post edited sorry didnt know !
back on track with the thread . we got a good day of work left and it should be ready !
AV FABRICATION
Old 01-30-2013, 08:51 AM   #5159
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
BADFUCKINGASSMOTHERFUCKER! When I finally get my S13 on the road this might be an option!
onehundredoctane is offline   Reply With Quote
Old 01-30-2013, 10:12 AM   #5160
PerilousActs
Protip: build the rear end from dirt cheap parts available on ebay/racing junk and order the IRS parts. WAY cheaper
