Old 12-27-2012, 01:38 PM   #781
jr_ss
Originally Posted by S@nt0s View Post
well for sure i can fo i for less then 1k for the rears and it will have more adjustment then anything offered out there. these will put those HKS coilovers to shame lol
Ill get it rolling and go from there.
That's good to hear, especially considering how many cheap ass s-chassis owners are out there. Mark me down as interested and keep us posted. Any idea what type of damper you are going to run? You don't have to release "secret" information or drawings, I'm just curious that's all.
Old 12-27-2012, 02:53 PM   #782
S@nt0s
S@nt0s's Avatar
S@nt0s is an unknown quantity at this point
nothing secert about it , i have been lokoing at the QA1 double adjustables right now but will be looking at others as soon as we get down to that point.
\spoke with my buddy who has my car and once we get the car running then we will look at suspension but in the meantime i will make the billet mounts since they will work with others as well.
MunkyW3rkz Racing
S@nt0s is offline   Reply With Quote
Old 12-29-2012, 02:44 AM   #783
slow92
slow92's Avatar
slow92 is an unknown quantity at this point
I am interested as well, but price is definitely going to be the deciding factor.
Sr22 in the works
slow92 is offline   Reply With Quote
Old 01-03-2013, 06:37 AM   #784
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
Might be asking a dumb question here but for those of you running a setup that uses tubes, are you actually using your tubes without screwing the tires to the rim? Reason I ask is I am looking to setup my MT ET Drags on my Z32 TT wheel and do not feel comfortable installing the tubes due to the fact that I wouldnt be screwing these into the rim. My fear is that somehow the valve stem could get damaged/cut off leaving me with NO tire pressure. Might be a dumb ass fear but since I dont have much experience with Tubed Drag tires I wanted to know what you guys do/recommend.
Also, if you do not use the tubes do you guys just use lots of beadlock around the wheel? I know more than likely the air will be leaking out faster than on a normal tire due to the nature of the tire I just want to be as sure as I can that the wheel is stuck to the rim.
Thanx
2muchboost is offline   Reply With Quote
Old 01-03-2013, 07:52 AM   #785
S@nt0s
S@nt0s's Avatar
you can use tubes with or without screws but you have to drill the valve hole on the wheel to use the tubes since they have a biger valve . mark your tire to see if you are getting rim slip. if you have slipping then go on to screws or beadlock them. we ran screws for a long time but now on the current set up its outside beadlock and screws inner side. my corolla has none and the S13 had none either.
MunkyW3rkz Racing
Old 01-03-2013, 09:54 AM   #786
2muchboost
Trader Rating: (33)
Sounds good thanks for the info and for the pointers.
Old 01-03-2013, 10:45 AM   #787
S@nt0s
S@nt0s's Avatar
no problem, im trying to make the IFO event we have out here next month but its going to be tight
MunkyW3rkz Racing
Old 01-09-2013, 03:51 PM   #789
drscooper
drscooper is an unknown quantity at this point
thought everyone would enjoy this beast! ran 6's damm fast if you ask me!
drscooper is offline   Reply With Quote
Old 01-09-2013, 05:52 PM   #790
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
I think I heard it hit VVL in 3rd gear.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 01-09-2013, 08:59 PM   #791
drscooper
thats what im thinking thing is so dam sick and quick lol
Old 01-10-2013, 12:16 PM   #792
sr20s13abel
sr20s13abel's Avatar
sr20s13abel is an unknown quantity at this point
Abel is back !!
Originally Posted by rb25_s13*CHUKI View Post
Why isn't abel all over this thread?
ABEL IS BACK !!!
BACK IN 2010 MY CAR MADE 624whp... gt35r @30psi +75shot of nitrous ..... RAN 10.10 @ 140MPH
NOW IN 2012 MY CAR MAKES 740whp... pte6766 @ 33psi no juice RUNS 9.85 @ 142MPH
sr20s13abel is offline   Reply With Quote
Old 01-10-2013, 12:19 PM   #793
sr20s13abel
Last time to the track..
1.4 60ft..
6.4 @ 113 in the 1/8 mile
Abel Blanco Nissan 240sx VVL SR20DET @ Irwindale 9/13/12 - YouTube
Old 01-10-2013, 03:52 PM   #794
sr20s13abel
1.4 60ft not only one time but every time..testing and letting off the gas...
Old 01-10-2013, 03:53 PM   #795
sr20s13abel
last time at the 1/4 mile.
Old 01-10-2013, 04:02 PM   #796
kyles1988
kyles1988's Avatar
kyles1988 is an unknown quantity at this point
I'll embed that for ya
http://www.youtube.com/watch?v=mpFGNnbqY2U
kyles1988 is offline   Reply With Quote
Old 01-10-2013, 04:06 PM   #797
sr20s13abel
HERE IS A LIST OF WHAT IS INCLUDED IN THE BUILD...
BLOCK.....
90MM SR20VE CP PISTONS (9.0:1)
MANLEY TURBO TUFF RODS
ACL RACE BEARINGS (main, rods, thust washers)
ARP MAIN STUDS
NEW OEM WATER PUMP
NEW OEM NISSAN SR20VE OIL PUMP (new timing chain KIT )
NEW OEM REAR MAIN SEAL
DARTON SLEEVES (bored to 90mm)
CHECK, POLISHED AND BALANCED CRANK
GREDDY OVERSIZED OIL PAN
ATI DAMPENER
NISMO GMAX TWIN PLATE CLUTCH
MAZWORX 90MM HEADGASKET (1/2 custom machined)
MAZWORX SRVG TRANSMISION ADAPTER KIT
CYLINDER HEAD.....VVL/VE
SUPERTECH VALVETRAIN (Supertech dual valve springs
Supertech Titanium Retainers
Supertech Valve Guides
Supertech Valve Seals
Supertech Intake & exhaust oversized valves )
COMPETITION VALVE JOB
CNC COMBUSTION CHAMBER (90MM)
CLEANED R/R OIL PORTS
RESURFACED HEAD
KELFORD 292/303 TURBO VE CAMS
TOMEI CAM GEARS
MAZWORX VVL/RWD CONVERSION KIT
MAZWORX HALL SENSOR KIT (eliminates cam angle sensor)
MAZWORX VE CUSTOM INTAKE MANIFOLD
INJECTOR DYNAMICS (2000cc)
MAZWORX TURBO MANIFOLD KIT
TIAL 44MM WASTEGATE
PTE6766 TURBO
Old 01-10-2013, 07:52 PM   #798
jimefam
jimefam is an unknown quantity at this point
I'm almost done with my drag 240. Hope to make about 1, 000whp and run 4's in the 1/8 and high 7's in the 1/4. Its an Rb25 with a th400.
jimefam is offline   Reply With Quote
Old 01-10-2013, 07:53 PM   #799
Yellow4g63
+1 jimefam's setup is legit.
91 Nx2000 VVL yo
Old 01-10-2013, 07:56 PM   #800
jimefam
Haha thanks but we'll find out soon enough when it goes on the dyno.
Old 01-10-2013, 10:02 PM   #801
drscooper
wow man thats sick and glad to see some sick ass cars in here forsure!
Old 01-11-2013, 02:43 PM   #802
slow92
slow92's Avatar
That is awesome. Both of those cars move, especially that corolla. I can't wait until my car is done.
Sr22 in the works
Old 01-11-2013, 03:15 PM   #803
S@nt0s
S@nt0s's Avatar
what corolla?
MunkyW3rkz Racing
Old 01-11-2013, 04:49 PM   #804
drscooper
no corolla dude 240 and a datsun... lol
Old 01-11-2013, 05:09 PM   #805
S@nt0s
S@nt0s's Avatar
im totally lost
MunkyW3rkz Racing
Old 01-12-2013, 06:27 AM   #806
slow92
slow92's Avatar
Ooops. I watched the video when I was half asleep and I thought maybe this was Santos' Corolla.
Sr22 in the works
Old 01-12-2013, 08:53 AM   #807
S@nt0s
S@nt0s's Avatar
What color was it
MunkyW3rkz Racing
Old 01-12-2013, 09:00 AM   #808
slow92
slow92's Avatar
no bushing mine is solid
the corolla is a 74 SR5. this is a pic of it around 99-00 time frame at Pomona Raceway.
Somewhat similar in a quick glance while you are falling asleep.
Sr22 in the works
Old 01-12-2013, 09:55 AM   #809
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
If one builds a 500rwhp+ SR, then adds an SRVG adapter setup, Z32 trans and heavy duty one piece driveline and Kaaz 1.5 LSD,
Would anything else be pron to breaking at the drag strip out of curiosity? Do you need to install heavy duty rear zxles/half shafts?
Seraphim38 is offline   Reply With Quote
Old 01-12-2013, 11:37 AM   #810
sr20s13abel
If u use anti-lag and pop the clutch.. U can break axles if the slicks hook good. if u use a drag radial u be fine.. If u ride out the clutch u be fine with a slick as well. Axles break but not that fast..
