Old 08-27-2011, 01:19 PM   #1
93 240sx
93 240sx is an unknown quantity at this point
s13 S14 lsd to s13???
ok i read about the s14 lsd that it will fit in a s13 but i just want to get things straight and clear....so will a s14 lsd fit a 93 s13 because ima get a s14 lsd but i know you have to change the covers but what else??? i dont know how a lsd and a non lsd look like....i want to but the s14 lsd in my s13 what do i have to do to do so step by step plz?? and will the shafts fit right on???and when i do get the s14 lsd on what should i do first to make sure nothing happens????? thanks
93 240sx is offline   Reply With Quote
Old 08-27-2011, 01:24 PM   #2
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
ok dood... all you do is buy a s14 LSD, drain the oil, remove the s14 rear cover, install a s13 rear cover with a new gasket preferably, then fill it up with new oil and bolt it into your s13. done.
Old 08-27-2011, 01:34 PM   #3
93 240sx
ok thanks.....
Old 08-27-2011, 02:17 PM   #4
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
Don't forget to buy solid front bushings. You can't use the s14 rubber bushings, or else the rear studs of the cover will start breaking.
I heard this one before, it's funny, do you know if you currently have a LSD of some type in your car already?
I hear friends telling me they want an LSD in their car, after a burnout I tell them it's got a LSD already. They fucking have no clue what the fuck LSD rear end is for and how to use it.
So before you start swapping parts, figure out what you have, figure out what your getting, does the used one your getting even work? Why are you getting a LSD for?
Hashiriya415 is offline   Reply With Quote
Old 08-27-2011, 02:31 PM   #5
curbhuggerrps13
curbhuggerrps13's Avatar
curbhuggerrps13 is an unknown quantity at this point
Send a message via AIM to curbhuggerrps13
wrong as long as you use the s14 bolt for the bushing you will be fine. ran 4 s13 w/ s14/j30 vlsd never had this rear cover snap issue. all you need is the s14 front bolts which are longer.
curbhuggerrps13 is offline   Reply With Quote
Old 08-27-2011, 08:26 PM   #6
Hashiriya415
Trader Rating: (22)
What's gonna hold that diff from moving and putting stress on rear bolts?
It's like your saying "Hey I ran my exhaust bolted straight to the chassis without any rubber hanger/ bushing, my mani didn't break". While most people try and do this, they will end up with broken/cracked manifolds.
Old 08-27-2011, 08:37 PM   #7
Csomme
Csomme is an unknown quantity at this point
4 rear solid mounting points will hold it still enough to not put stress on some rubber ass bushings. Think about it.
Csomme is offline   Reply With Quote
Old 08-27-2011, 09:41 PM   #8
93 240sx
i dont got lsd i check when i got the car...ima use it for drifting...where can i get the bushings at????
Old 08-28-2011, 02:59 PM   #9
Hashiriya415
Trader Rating: (22)
Go ahead, do whatever you want to your car, there is reason why stock 240sx last years until kids start "building" them after after they built their lego cars, they really think they have better engineering skill then Nissan has (zip tie this, tape that, glue this, hammer this). If you want use duct tape to hold a rear wing that is putting 1000lbs of force on rear of a car, and tell me it's worked, great for you, but please stop spreading stuff like this around. I seen bunch of rear studs broken off rear covers. To the OP, you want shit done right, do it yourself and do it once, or be cheap and do it couple of times and end up calling a tow truck.
Old 08-28-2011, 03:00 PM   #10
Hashiriya415
Trader Rating: (22)
93 240sx, vLSD's are not for drifting btw.
Old 08-28-2011, 03:17 PM   #11
c-los13
c-los13's Avatar
c-los13 is an unknown quantity at this point
i bought some solid diff bushing from frsport, they come w sotck s14 bolts (longer). i would recommend to change while the diff is out, the rubber one usually make the car bounce when you take off, mine did that but after i replaced the bushing it was smooth than a muggaa.....
c-los13 is offline   Reply With Quote
Old 08-28-2011, 04:01 PM   #12
93 240sx
so should i just weld da stock one???
Old 01-16-2013, 06:17 PM   #13
jamg
jamg is an unknown quantity at this point
will the S14 VLSD guts fit into an s13 pumpkin?
jamg is offline   Reply With Quote
Old 01-16-2013, 06:21 PM   #14
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
yes but just get the whole unit and change covers
not worth the trouble unless you're swapping final drives at the same time.
Old 01-16-2013, 06:22 PM   #15
jamg
but s14's have ABS, and that will cause my drive shaft to push up against my rear main seal... i didn't want that to happen.
what should i do? haha :\
Old 01-16-2013, 06:31 PM   #16
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Drive shaft pushing on rear main seal you say..... hope you're joking.
