#64 |
![]() Join Date: Dec 2010
I use a few depends on were i'm at in the shop or what I'm doing
I mostly use miller dynasty 350 it's the shit, and a Lincoln precision TIG 275 sometimes when I'm building handrails on the big layout table i use this old fucked up dynasty machine. And then when I do portable welding use couple different ones depends on the situation both are dynasty machines ones a 110v with a thumb control the other is a bit more umph for jobs that arent in fucked up places |
#65 |
![]() Join Date: Jul 2010
Hey not trying to thread jack your build but I was wondering if you tried those spacers out to see if they work or if its enough of a spacer. I'm not sure im even going to run a front sway bar as my spring rates are 12k swift springs on stance gr+ pro's and my suspension has next to ZERO travel. Anyways I had to make some spacers with a step up because of the way the sway bar mounts are. Haven't test fitted the sway bar on the car with the motor in yet tho.
#69 |
![]() Join Date: Dec 2008
Trader Rating: (79)
![]() Feedback Score: 79 reviews
Gangsta ass Intercooler! Looks Intense!
My Build: The "Coupe De Ville" 1JZ Build!! |
#73 | |
Anyways back on topic. Love your build, glad you're taking your time and able to do things on your own the way you want. I'm sure ill see you down at PARC once you're done! ![]() |
#75 | |
Sorry to the OP for leading this thread off topic. Could you post pics of your sway bar clearance from the ground and your pan once you get that far? |
#76 |
Whats this about the modded stock ecu removing boost cut? Are you worried about timing problems with the stock ecu?
Reason i ask is im running the stock ecu with a he 341 holset and a safc from apexi. |
#77 | |
stock sway bar is your best bet i'll try and get some pics of it when I get it on the ground |
#79 |
mounted up the rad today also I got some aerocatch hood pins gunna finish mounting the fenders etc and tranny mount do a drive shaft then pull everything out and prep for paint this weekend
![]() ![]() ![]() and a bunch more goodies are on the way stay tuned |
#80 | |
The fab work is GREAT! Just think that shroud is going to block alot of air flow for no reason really... Looks good don't get me wrong. These motor's create a shit ton of heat and unless that fan is a high CFM flowing fan with a 3 row core you might have some overheating issues at lower speed tracks like PARC. |
#83 | |
Sounds like a good plan, wasn't sure if you were going to lay some beads to the tube rad support and frame so I just wanted to give some info to ya! Comin along great man. You already have a clutch right? I'm selling a 1j/2j r154 ORC twin setup with low mileage and im going to Portland in the morning if you're interested. Or if you know of anything else you're missing I might have. |
#84 | |
#85 |
No worries, it's one of those bigger expensive items. A lot of people spend all the money on the engine trans and don't think about a clutch to handle the power so I doubt its gonna be a fast item to sell. I wish I had this before I had already bought my exedy twin because I paid 2 grand for it new wholesale. I only paid $1200 for this clutch and its actually a better clutchx, has the heat slits in the friction plates for better cooling and I plan on keeping it for a spare if someone doesn't want it.
#86 |
not much of an update
just kinda rolling through parts and pieces and trying to get everything perfect. These are suppose to be great power for the money ![]() there's a little modifying to get this kit to work good but definitely worth it ![]() ![]() front timing over and misc parts put back on and motor timed it's on the ground going have to mod the tranny mount a little more :/ forgot how low it was. Also can't wait to drive this beast... wire tuck coming soon and aem ems v2 etc. ![]() |
#89 | |
Thanks for the compliments guys! I'm getting kicked out of the shop haha we have some big work to do and need the space. Moving it to a new location at the end of the week to finish the build. Aiming to be running by March 2nd for Kyle Pollards Birthday Drift at PARC Final parts have been ordered stand by ![]() |
#90 |
some parts rolling in r1 stuff from Marlin. I love these guys always had the best customer service with these guys.
![]() Clutch a Seat and some power steering lines on the way. I still need to fab the catch can and PS reservoir. |
