Old 01-18-2013, 07:02 AM   #61
BlewByYou
BlewByYou's Avatar
BlewByYou is an unknown quantity at this point
Nice Build
BlewByYou is offline   Reply With Quote
Old 01-18-2013, 10:01 AM   #62
Tw1st3d
Tw1st3d's Avatar
Tw1st3d is an unknown quantity at this point
Thanks guys!
Tw1st3d is offline   Reply With Quote
Old 01-18-2013, 05:43 PM   #63
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
Send a message via MSN to Big Zee
what tig welder do you use ?
Big Zee is offline   Reply With Quote
Old 01-18-2013, 07:55 PM   #64
Tw1st3d
Tw1st3d's Avatar
I use a few depends on were i'm at in the shop or what I'm doing
I mostly use miller dynasty 350 it's the shit, and a Lincoln precision TIG 275
sometimes when I'm building handrails on the big layout table i use this old fucked up dynasty machine. And then when I do portable welding use couple different ones depends on the situation both are dynasty machines ones a 110v with a thumb control the other is a bit more umph for jobs that arent in fucked up places
Old 01-23-2013, 03:33 AM   #65
MC.Understeer
MC.Understeer is an unknown quantity at this point
Originally Posted by Tw1st3d View Post
merp more shitty cell phone pics
Hey not trying to thread jack your build but I was wondering if you tried those spacers out to see if they work or if its enough of a spacer. I'm not sure im even going to run a front sway bar as my spring rates are 12k swift springs on stance gr+ pro's and my suspension has next to ZERO travel. Anyways I had to make some spacers with a step up because of the way the sway bar mounts are. Haven't test fitted the sway bar on the car with the motor in yet tho.
MC.Understeer is offline   Reply With Quote
Old 01-23-2013, 10:06 AM   #66
Tw1st3d
Tw1st3d's Avatar
Well it depends what motor etc... yes mine work just fine i recommend running a sway bar
Old 01-23-2013, 10:30 AM   #67
Tw1st3d
Tw1st3d's Avatar
okay guess i'll keep this build rollin...
more pics
wire tuck that bitch.
Old 01-23-2013, 12:00 PM   #68
blockedwizard
blockedwizard's Avatar
blockedwizard is an unknown quantity at this point
Loving the fab work in this build, those engine mounts look pretty awesome!
blockedwizard is offline   Reply With Quote
Old 01-23-2013, 04:15 PM   #69
jdm2191
jdm2191's Avatar
Trader Rating: (79)
Feedback Score: 79 reviews
Gangsta ass Intercooler! Looks Intense!
jdm2191 is offline   Reply With Quote
Old 01-23-2013, 06:40 PM   #70
I<3BEWBZ
I<3BEWBZ's Avatar
I<3BEWBZ is a jewel in the roughI<3BEWBZ is a jewel in the roughI<3BEWBZ is a jewel in the roughI<3BEWBZ is a jewel in the roughI<3BEWBZ is a jewel in the roughI<3BEWBZ is a jewel in the roughI<3BEWBZ is a jewel in the rough
Awesome fab work! That's to be expected though, seeing as its your career as well haha.
I<3BEWBZ is offline   Reply With Quote
Old 01-23-2013, 07:40 PM   #71
Mofuhcka
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
Great build coming along, youll love the JZ
@hcr32love 400whp NEO R32 Sedan
Mofuhcka is offline   Reply With Quote
Old 01-23-2013, 09:35 PM   #72
kudii
kudii is an unknown quantity at this point
that intercooler is money right there!!
kudii is offline   Reply With Quote
Old 01-23-2013, 10:42 PM   #73
MC.Understeer
I already had an rb25 so the weight is pretty close to the same. Drifting on a bank turn my car almost three wheel motions in the front because the springs literally do not compress because of how stiff they are. I'm gonna try it with and without and see if its noticeable even with the little amount of suspension travel I have.
Anyways back on topic. Love your build, glad you're taking your time and able to do things on your own the way you want. I'm sure ill see you down at PARC once you're done!
Old 01-23-2013, 11:32 PM   #74
90240sx07
90240sx07 is an unknown quantity at this point
^^^ the question is why dont you have much suspension travel on your pink s13? and start fixing that before being concerned with your sway bar
90240sx07 is offline   Reply With Quote
Old 01-23-2013, 11:48 PM   #75
MC.Understeer
First off there's a quote button for a reason. And I know exactly why I don't have travel as its my car not yours. I have custom valving, 12k swift springs and a 30.4mm Tanabe sway bar so I think its pretty obvious why there's no travel because a combo of everything is making the front suspension too stiff. Hence why i'm going to remove the thick sway bar, try a stock one, and further more try softer spring rates. Anyways this isn't the thread about how to tell me how to set up my suspension.
Sorry to the OP for leading this thread off topic. Could you post pics of your sway bar clearance from the ground and your pan once you get that far?
Old 01-23-2013, 11:54 PM   #76
007jones007
007jones007 is an unknown quantity at this point
Whats this about the modded stock ecu removing boost cut? Are you worried about timing problems with the stock ecu?
Reason i ask is im running the stock ecu with a he 341 holset and a safc from apexi.
007jones007 is offline   Reply With Quote
Old 01-25-2013, 08:38 PM   #77
Tw1st3d
Tw1st3d's Avatar
nope I picked up an aem v2 standalone didn't wanna deal with that stuff so just decided to go with a standalone.
stock sway bar is your best bet i'll try and get some pics of it when I get it on the ground
Old 01-25-2013, 10:34 PM   #78
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
subscribed! im sure i can use some of this info for my 1J build
Old 01-25-2013, 10:53 PM   #79
Tw1st3d
Tw1st3d's Avatar
mounted up the rad today also I got some aerocatch hood pins gunna finish mounting the fenders etc and tranny mount do a drive shaft then pull everything out and prep for paint this weekend
and a bunch more goodies are on the way stay tuned
Old 01-25-2013, 11:33 PM   #80
MC.Understeer
The fab work is GREAT! Just think that shroud is going to block alot of air flow for no reason really... Looks good don't get me wrong. These motor's create a shit ton of heat and unless that fan is a high CFM flowing fan with a 3 row core you might have some overheating issues at lower speed tracks like PARC.
Old 01-25-2013, 11:37 PM   #81
Tw1st3d
Tw1st3d's Avatar
I had the same thoughts but if I run into problems it only takes 10 mins to fab up a new shroud
Old 01-26-2013, 01:02 AM   #82
SaNTi
SaNTi's Avatar
SaNTi is an unknown quantity at this point
This looks promising! Moar!!!
SaNTi is offline   Reply With Quote
Old 01-27-2013, 12:29 AM   #83
MC.Understeer
Sounds like a good plan, wasn't sure if you were going to lay some beads to the tube rad support and frame so I just wanted to give some info to ya! Comin along great man. You already have a clutch right? I'm selling a 1j/2j r154 ORC twin setup with low mileage and im going to Portland in the morning if you're interested. Or if you know of anything else you're missing I might have.
Old 01-27-2013, 12:51 AM   #84
Tw1st3d
Tw1st3d's Avatar
How much taxs should be back here shortly im all the way on the oregon coast
Old 01-27-2013, 12:59 AM   #85
MC.Understeer
No worries, it's one of those bigger expensive items. A lot of people spend all the money on the engine trans and don't think about a clutch to handle the power so I doubt its gonna be a fast item to sell. I wish I had this before I had already bought my exedy twin because I paid 2 grand for it new wholesale. I only paid $1200 for this clutch and its actually a better clutchx, has the heat slits in the friction plates for better cooling and I plan on keeping it for a spare if someone doesn't want it.
Old 02-03-2013, 11:18 AM   #86
Tw1st3d
Tw1st3d's Avatar
not much of an update
just kinda rolling through parts and pieces and trying to get everything perfect.
These are suppose to be great power for the money
there's a little modifying to get this kit to work good but definitely worth it
front timing over and misc parts put back on and motor timed it's on the ground going have to mod the tranny mount a little more :/ forgot how low it was. Also can't wait to drive this beast... wire tuck coming soon and aem ems v2 etc.
Old 02-03-2013, 08:18 PM   #87
Sansone
Sansone is an unknown quantity at this point
This is awesome! Totally unexpected from the first post haha. keep up the great work man!
Sansone is offline   Reply With Quote
Old 02-03-2013, 09:13 PM   #88
D's_s13
D's_s13 is an unknown quantity at this point
this is dope! i got a question tho, is ur inner front tires gonna be exposed with the engine bay ? planning on cuttinnng mines out too , .....:! or are u going with tubes???
D's_s13 is offline   Reply With Quote
Old 02-03-2013, 09:22 PM   #89
Tw1st3d
Tw1st3d's Avatar
yes it will be exposed as is. It's a track only car otherwise I would have tubbed it.
Thanks for the compliments guys! I'm getting kicked out of the shop haha we have some big work to do and need the space. Moving it to a new location at the end of the week to finish the build.
Aiming to be running by March 2nd for Kyle Pollards Birthday Drift at PARC
Final parts have been ordered stand by
Old 02-10-2013, 12:23 PM   #90
Tw1st3d
Tw1st3d's Avatar
some parts rolling in r1 stuff from Marlin. I love these guys always had the best customer service with these guys.
Clutch a Seat and some power steering lines on the way. I still need to fab the catch can and PS reservoir.
