07-23-2004, 08:27 AM | #1 |
17x9 35 offset on an S-13
anyone run a 17x9 on the rear of an s-13? i just got some and before i put the tire on the rim, id like to know if it will fit right or if i need to roll the fender. any one who has this setup please give some input. thanks.
240sx s-13 TURBO weekend v-8 killer 90 Talon TSI WARNING.THIS CAR IS EQUIPPED WITH A TURBOCHARGER. DUE TO POSSIBLE BREATHING PROBLEMS UNDER HEAVY ACCELERATION, ALL FEMALES ARE ADVISED TO REMOVE ANY TIGHT FITTING OR RESTRICTIVE CLOTHING FOR SAFETY. |
07-23-2004, 09:25 AM | #2 |
i have 17x9 with 255/40 tire very slight rub in very hard corners. a small amount of fender rolling will fix it but remember it also matter what camber numers you run. i think was at -1.5
Twin67 ls1/awd in the works |
07-23-2004, 09:40 AM | #3 |
i corrected my camber to stock setting from lowering the car. so in my case it might not fit as well as yours, damn it!!! thanks for the info.
07-23-2004, 11:09 AM | #4 |
i've heard of people having a lower offset without rolling their fender. just run smaller tires if you get some rub
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till. -Emerson |
