#13261 |
![]() Join Date: Jan 2013
Hey, guys. Does anybody know where I can find replacement mounting tabs for s13 Silvia headlights? Mine are broken and I remember someone awhile back was making metal replacement tabs that you could glue/screw onto the headlights to replace the broken tabs. The problem is I can't remember who was making them or where they are sold. If anybody knows let me know!
#13264 |
Ok need more Zilvia Knowledge.
Around what MAF voltage does the RB20 Cut fuel? I am using a Blow through setup and Hitting cut at like barely 7psi on my turbo. what Voltage do they cut at? or UP TO what voltage is OK? so I can build a Maf voltage map in AEM... ALSO : I need recommendations on Suspension upgrade. my stock stuff is shit. it is bouncing and crappy. my front alignment is also off but that will get fixed. WHAT do you zilvians recommend to buy to Have a DECENT streetable suspension? I don't need no hella flush scraping Drifter shit. Last edited by OrangeVirus1; 04-01-2013 at 05:34 PM.. |
#13266 |
wasn't sure if this deserved its own thread or not, but I figured why risk getting flamed if I could just post here and get my answer...
Anyways, I've done a bit of a search and haven't come up with any results. I'm wondering if there is anybody that makes urethane or FRP hybrid (like ings +1 makes for their body kits) over fenders. Reason I ask is because I'm really not sure how prone FRP is to cracking, and I'd really hate to find cracks in my over fenders after pulling my car out from winter storage or just avoid them cracking from anything short of an accident as I plan on putting on a fairly expensive paint job. I was planning on running 9" wheels in the front with 245/40/18 rubber and 10" in the back running 275/35/18 and I would like to have absolutely no tire stretch because I don't like the look and I don't want to run the risk of debeading the tires.... Unless someone can tell me whether running a small amount of stretch can guarantee they won't debead. if no one makes urethane or FRP hybrid over fenders, can anyone vouch for the durability of Origin over fenders? Or if even the OEM metal fenders can be pulled enough without looking too ugly to support those kinds of wheels and tires? Dang, that's actually more than one question, but I want to find the best option for what I want to do. |
#13267 | |||
![]() Join Date: Dec 2004
Trader Rating: (58)
Parts Store, or posting a WTB add in the classifieds here.
#13268 | |
Already Figured it out. My Rb20 Cuts If the maf hits more than 4.7 Volts. So I just used AEM to maf clamp it and Set the Maf Voltages to whatever I wanted and the Ecu see's what Volt I tell it at what RPM I tell it. Also Could I fix my bouncy ride with let's say... 650? |
#13269 |
![]() Join Date: May 2010
![]() Feedback Score: 21 reviews
Spend an extra $250, but some Fortune Auto's. Street valving, 8k 6k spring rates, and enjoy. Can go super low if you decided you ever wanted to, but can also just "drop the car a little". Ride is excellent as well.
#13271 | |
Trader Rating: (58)
That is totally strange stuff for sure. Good to know though The second half of the question is how low do you need to ride, and what do you do with the car? If you don't need it super low, you can go with Koni yellow's and a spring setup of your choice. Also doesn't hurt to put caster/camber plates on it too Koni Yellows Install on Nissan 240sx
#13272 | |
no map sensor I could find. I use the Map sensor on my AEM ecu to tune everything. I would like to be able to drive the car, streets, highway, etc with only mild discomfort. And maybe the attempt at a half ass 5 second drift every now and then. I don't need it more then 1 inch lower than stock. I just don't want it to bounce and wobble |
#13274 |
Philosopher King
KADE fuel pump and no start issue.
Fuse is good. Makes sound when key is in on position but not the normal sound.. No pressure or flow. Any help diagnosing this would be much appreciated.
G O L D E N B E A R R E P U B L I C |
#13275 | ||
Trader Rating: (58)
If not get some Fortune Auto 500's and ride. It's gonna be rougher than stock no doubt, but better than a totally cheapy set.
#13276 | |
Look in the trunk and check, first, the fuel pump, it may be bad Check the wiring from the fuel pump to the fuse box by using long ass leads on your multimeter after you disconnect the wire at each end. Check the input wire to the fuse panel If you get totally lost, get the wire diagram, print it up nice and big, connect the pages, and lay some thin clear film over it. Use dry erase marker to trace so you can clean it after and use it for the next ghost in the machine essentially, you are isolating each connector, in the entire fuel system, and seeing if there is a short, and testing all parts
1996 Zenki 'Baraketsu Tenshi', Burst Angel My work in progress... |
#13277 |
![]() Join Date: Jun 2011
Thanks man. I was thinking that it would go on the frame but the wiring specialties guide says it goes on the housing. My problem is my tail/brake lights, cluster, and windows aren't working. In the engine bay fuse box the 75 amp fuse labeled FL75A keeps blowing. I can't find a short anywhere. Thanks for any help
#13278 |
![]() Join Date: Apr 2010
![]() Feedback Score: 7 reviews
so my s14 was converted from auto to manual when i bought it and im acquiring z32 front brakes to upgrade. i was told that the auto bmc is stronger than the manual bmc, so i wont have to switch to the z32 bmc when i do the conversion. can anyone verify this?
#13279 | |
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 |
#13280 |
Philosopher King
@I'm Redline
It looks like I'm getting power. The plug for the pump was massively corroded but after cleaning it I'm definitely getting power. I guess I'll pull the pump and hope that it's just really dirty. Thanks for the help.
#13281 |
![]() Join Date: Dec 2009
For some reason my posts tend to get avoided.
What does the ambient air temperature sensor do exactly? It got in the way of mounting my intercooler, so I pulled it out. Will my climate control be affected by the removal of it? Retaining A/C is one of my goals.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#13283 |
![]() Join Date: May 2011
![]() Feedback Score: 23 reviews
I have a problem with my car. I did a wire tuck and now it won't start. First thing I did was check all grounds and and check if all any wires were spliced. No problems were found so I'm stuck. The weird thing about the problem is that the RPM tach jumps when I try to turn the car on. The car itself does nothing, no crank or anything. I checked the starter and it was fine. Now when I was messing with it I forgot to plug the starter wire from the ignition, and this did not caused the RPMs to jump. Basically, connected starter wire for ignition=jumping rpms, and NOT connected starter wire=no jumping RPMS.
Any ideas? |
#13285 |
So my Car's Speedo is not working at all, but I have a KA speed sensor in my RB20 tranny and hooked up.
what to check? also best place to put a temp sensor on RB20 to get best coolant temp readings.. |
#13287 |
Alrighty just ordered some suspension parts, rims and tires.
One thing I am wondering, Since my tach don't work, IS IT SAFE to just rev me engine @ full boost until the ecu limits? ( not all the time ) but sometimes? ( Rb20 ) and when does the ECU cut? is it really 8500 rpm? ( with a good tune ) |
#13288 | ||
Trader Rating: (58)
It goes from the housing to the frame. Check to make sure you main alternator wire isn't grounding out on the alternator case itself. Should have a plastic spacer between it and the case. Quote:
To retain working AC on the SR20 you'll need the DOHC components and compressor, the ECU working with the HVAC controls, and one of my conversion brackets ![]()
#13290 |
Recently dash lights started to go dim and I was having acceleration issues, like the car would cut up and hesitate then catch itself while accelerating.
Today I started the car and seemed like it had a weak start. I turned car off after driving it then went to turn it back on and it would not start. Just kept getting multiple clicks. When I took my key out, all my lights on my gauge cluster stayed lit? Jumping the car did not work. Had to push start the car to get it to turn on. Bad Alternator? Battery? Fuse? |
Tags |
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki |
