Old 04-05-2013, 04:17 PM   #121
OrangeVirus1
OrangeVirus1 is an unknown quantity at this point
RB20 pull. ..........................zoom..........
OrangeVirus1 is offline   Reply With Quote
Old 04-10-2013, 11:23 PM   #122
OrangeVirus1
So getting my Back struts installed tomorrow, All new tires and rims going on aswell.
Drove my car around quite a bit, about 20-30 miles. I noticed that I couldn't get it to overheat.. and I tried, just to check.
Even without ever turning the fan on, my car would not go past 186* F and was constantly going back down in temp! I got it to 186* idling it for about 30 minutes.. no fan.
and usual cruising temps were around 173-182*F
Seems a bit cold. I read the thermo is for.. 170?
just interesting as other car's I've owned run more around the 200-210 temp as normal.
Old 04-11-2013, 07:55 AM   #123
DJZ
DJZ's Avatar
DJZ is an unknown quantity at this point
I have a koyo rad on mine and forget to turn the fans on all the time and its never overheated ever
DJZ is offline   Reply With Quote
Old 04-11-2013, 08:44 AM   #124
Duke89
Duke89 is an unknown quantity at this point
186 is real good. I would be worried at all
Duke89 is offline   Reply With Quote
Old 04-11-2013, 02:10 PM   #125
greenwood
greenwood's Avatar
greenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymore
where is your temp probe?
My rb20 is running a mishimoto aluminum radiator, 12 inch puller on the rear and a big 14 or 16 baller 200 dollar fan on the front. in this heat, 80 degrees, humidity, 180-190 on the highway, this is having the temp pickup on the bottom radiator hose.
in traffic I have to have the fans on. In cooler weather, Unless im idling around I dont need the fans, on the track temps went up to like 190-200 oil was at 210. Oil is usually 180. I'm running an oil cooler with grex thermostat setup as well.
I have ducting for the radiator and fresh coolant, although I am just running 50/50 green stuff.
Also running a rb25/26 pump which seems to have helped.
greenwood is offline   Reply With Quote
Old 04-11-2013, 02:14 PM   #126
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
I'm @ 180-190 with mine but I have the clutch fan on. When I had electric fans in it would see 200-210 all the time with the fan going. It's warmer out here in Socal tho so the fan clutch really keeps the temps down even after romping on it.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is online now   Reply With Quote
Old 04-11-2013, 04:36 PM   #127
OrangeVirus1
I have an oil temp gauge and I rarely see over 180 in oil temps.
my water Temp sensor is Right next to where the stock 2 are, Drilled and tapped a whole for it.
I saw 187* today.
When is it considered too hot?
Old 04-11-2013, 08:52 PM   #128
OrangeVirus1
whatdafaka
Old 04-12-2013, 04:12 AM   #129
559fresnodrifter
559fresnodrifter's Avatar
559fresnodrifter is an unknown quantity at this point
I have a rb20 wirh 400hp and spend.less than a stockrb25 stock and.have more power
FRESNO TANSO MENMBER-RB S13 all the way
559fresnodrifter is offline   Reply With Quote
Old 04-12-2013, 09:25 AM   #130
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
This is a decent thread, really looking forward to seeing a dyno sheet from you later. Are you street tuning it or you renting out a dyno? Also, your online behavior is just like my friends;he always used to argue with everyone but it just comes down to not giving a fuck because they don't buy you parts. It's your car, do what you want, let them sit there and be the keyboard commando.
I personally wouldn't have bought the rb20 just because of what I read online (not many car friends in real life) about parts availability and shit but its working out for you so more power to ya. Don't worry about them, let them think they are superior with their sr20s and what not.
I do think you need to chill out though, I see that you reply in the thread with kids asking about swaps, but you don't need to argue with everyone. First of all, the kids asking don't know shit but can find everything in the stickies on here and 240sxforums if they were really going to do the swap. Second, it's not worth it to argue on every goddamn thread for you or the people who argue back, it's a waste of brain cells. Just be happy that you got a decent motor (your junkyard motor runs well, be happy) and you are making decent power or are shooting for more power.
For the car though, I would suggest that when you pull the motor you should re do the engine bay. Look in the engine bay thread, they have some decent rattle can jobs from Home depot that look sexy. I assume you primered the car in prep for a paint job.
Keep it up
collegekid is offline   Reply With Quote
Old 04-14-2013, 04:39 PM   #131
OrangeVirus1
Keep it up
I have decided to just chill and if people want to say shit then whatever I don't care anymore. I am having fun and for a rb20 it's freaking fast.
also I just did a crap rattle can spray job, not a whole lot of prep. I just wanted to make this my fun car, I don't care much about it's beauty. It's completely sleeper because it looks like ass.
The only time I interject in a swap thread is when I want the OP to know that RB20 is still an option, and if they dedicate the resources to it, it's definitely a worth-while swap.
Old 04-14-2013, 05:43 PM   #132
RiskyRick
RiskyRick's Avatar
RiskyRick is an unknown quantity at this point
Not sure if you've said already or not, but just out of curiosity what size of s200 is that turbo?
RiskyRick is offline   Reply With Quote
Old 04-14-2013, 06:26 PM   #133
OrangeVirus1
it's the very small size like my penis
Old 04-14-2013, 06:50 PM   #134
RiskyRick
RiskyRick's Avatar
It's kinda hard to find info on them. it comes off a CAT construction vehicle.
it's a Borg Warner S200G
.76 AR cold / 1.00 AR hot T3 divided housing
I can't remember the compressor wheel size, it's Billet I know that, I think 58mm or 62.. something.
Wow, sounds pretty responsive for a turbo like that on a 2 liter. I've got to give you a big thumbs up, man- you've got balls pushing that much air through an RB20, especially w/ as aggressive of tuning as you were getting flamed for. Can't wait to see how high you go with the stock bottom end.
Old 04-14-2013, 06:57 PM   #135
240boi115
240boi115's Avatar
240boi115 is an unknown quantity at this point
glad to see more progress with the build posted up.. the motorlooks real nice and props on the intake manifold piping.. looks pretty cool.
240boi115 is offline   Reply With Quote
Old 04-14-2013, 08:10 PM   #136
OrangeVirus1
thanks thanks much appreciated. I'm going to get it dyno'd here shortly. I have to get some better clamps because my couplers keep blowing off at full boost.
Old 04-16-2013, 05:17 AM   #137
ayrtonlucyk
ayrtonlucyk's Avatar
ayrtonlucyk is an unknown quantity at this point
nice keep the updates comming!
ayrtonlucyk is offline   Reply With Quote
Old 04-16-2013, 07:27 AM   #138
Kryptik89
Kryptik89's Avatar
Kryptik89 is an unknown quantity at this point
Damn Matt!! You've been busy!! Wish I had monies to work on mine...
Sent from a Parallel Universe
Kryptik89 is offline   Reply With Quote
Old 04-16-2013, 11:09 AM   #139
240boi115
240boi115's Avatar
just curious but are you going to keep the cam gears showing with no cover? or be a badass and get a clear cover over em like i see on all those rb26's xD
Old 04-16-2013, 01:04 PM   #140
OrangeVirus1
I wanna get a clear cover but they are just too expensive for what they are. to get one shipped to my house is almost 200$.
Old 04-16-2013, 03:17 PM   #141
greenwood
greenwood's Avatar
that turbo is a monster. where did you get your intercooler fmic kit from, or is this custom?
Old 05-07-2013, 11:26 PM   #142
OrangeVirus1
went booom, took a shit
Old 05-08-2013, 12:09 AM   #143
Yellow4g63
Did you inspect the oil pump and the drive?
91 Nx2000 VVL yo
Old 05-08-2013, 12:18 AM   #144
OrangeVirus1
hell nah who da fuck does that. run it dry
Old 05-08-2013, 12:43 AM   #145
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
The interesting part is that I was looking at the stock pistons really really really closely and they are not perfect circles ( obiously no piston is a PERFECT circle ) but I mean these things look like they were cut out by hand.. Nissan engineering!
They are cut out by hand, that's how old RB20 technology is.
Old 05-08-2013, 12:51 AM   #146
OrangeVirus1
lol I'm not kidding though, Up really close, these pistons look like hexagons..
Old 05-08-2013, 12:46 PM   #147
nissanpwrds14
nissanpwrds14 is an unknown quantity at this point
Your forgot one key reason to go with a RB20. The exhaust note! Love the way they sound!
S14 mini street grudge car. 5.xx 1/8mile
nissanpwrds14 is offline   Reply With Quote
Old 05-11-2013, 10:06 PM   #148
OrangeVirus1
They do sound amazing in the high rpms.
Old 05-12-2013, 09:22 AM   #149
R_34
R_34 is an unknown quantity at this point
I've been following your thread from a couple weeks (even if I'm new here).
What injectors are you using ?
Will you use an e-clutch to drive the M90 or letting it always powered even when the turbo kicks in ?
R_34 is offline   Reply With Quote
Old 05-12-2013, 09:25 AM   #150
OrangeVirus1
Always on, The M90 doesn't have a electromagnetic clutch. it will compound the boost.
I am using Siemens Deka IV EV6 60lb
