#31 |
dude I dont know why you think welding is ghetto if anything it's less ghetto than shimming and it lasts longer too if done correctly. I had a nismo 2 way and it's the same shit as my welded except they need to have the oil changed a lot more frequently than a welded. Plus its true VLSDs are horrible especially on water.
I've been tracking and daily driving it for 2 years now and have 260whp on my sr and there is absolutely no problem with it and its bs that they drive funny or that you will fall off of a cliff or whatever stories they tell. But if buying everything from a BRAND NAME and paying more gives you piece of mind than by all means do it. There is no problem with that. I had a 1 piece aluminum shaft on my 300zx N/A and the response is a lot faster. You can hear them humming but I never had any vibrations. Now this car was not for drifting which is what I do now with my s13 so I'm also debating on either getting a 1 piece steel or aluminum. I kept my aluminum from my old 300zx and measured it and it was the same length as the s13 and I found the yolk that will fit into the s13 tranny. But I still dont know if I should use steel or aluminum for my application. |
#33 | |
![]() Join Date: May 2011
#34 |
![]() Join Date: Jan 2011
Trader Rating: (43)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 43 reviews
I have an aluminum DSS driveshaft on my car mated to my kaaz 2way, stock kade engine. Snappy feeling? Not a dramatic feel versus my buddy's car. Noisy? No, if it makes noise or causes a whole car vibration it needs proper balancing.
One piece aluminum compared to the steel will be the same, only difference is weight (clearly) and that the steel will break tires loose more easily. But if you're running stock and will go SR what are your plans? high power? mild power? Choose something you feel you'll need. I know of people running stockies being turbo. And yeah VLSD's are cool if you don't like your slides being predictable. Quick check on DSS website puts the aluminum abs at $480 and steel at $350, shipping not included. Stockies average at around $50. Only reason I have mine is because I have high power plans and got mine CHEEEAAP. Only $150. |
#35 |
yeah I got mine for about 80 bucks since thats how much it will cost me to modify the 300zx one. My question is, do you notice a big difference when sliding? I have no problems drifting with the stock DS but since I have the aluminum one and have plans for more power then I am thinking about it.
#37 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
1. You need to find a shaft thaft has U joints that will interchange with the slip Yoke used on the 240. 2. You also need to address the rear flange as well. So while it may only cost 15-30 bucks to find a 'used' driveshaft, you're going to spend another 30-40 dollars for the front slip yoke, and another 20-30 for the rear flange. Also gonna spend another 10-30 bucks in U joints as well. So now w'ere around 100-130 bucks in parts alone. Now you gotta measure (not hard, just time), and goto a shop that specialized in drivetrains to cut/weld/balance the entire assembly for you. Figure at a minimum this is going to cost 100-150 bucks. With all of that in mind, where are you saving money again? Even if you err on the 'small end' of costs, it's still going to be darn near the cost of a new steel one piece. Trust me when I say, I know it's possible (your process) but I also am realistic at the total cost of it all, and the time as well. To me, saving a few bucks isn't worth the total time to make it all 'work'.
#38 |
Trader Rating: (58)
With this all said, I do have a Driveshaft Shop 1 piece steel in my S14. It was not balanced well from them, and even with flipping it on the rear flange, and switching it's relationship with the trans too, it still had a horrible vibration. I took it to the shop that does our big truck driveshafts and they rebalanced it, and it's been fine ever since. I sent an email to driveshaft shop about it, and that I had it rebalanced by a shop. They were not very happy about me having it balanced by my shop, and said the warrenty on it would now by void. They suggested that I should have taken it out, shipped it back, had it 'fixed' and then had it shipped back...sorry DSS i'm not waiting 2-3 weeks for your product when I had it back up and running in 2.
Would I buy a DSS shaft again? Hard to say. Fitment was obviously perfect, but the product was not....and their return policy sucks, especially when a Spicer shop rebalances it for me. In regard to 'feel' or 'power' I can be honest that I didn't feel a damn thing with my car at all...not even in the 'seat of the pants'. However It was a worthwhile upgrade for me, considering my factory U joint failed, and I wanted to upgrade to domestic sized U joints.
#39 | |
dude Redline MT-90 made my trans run so much smoother. |
#40 | |
![]() Join Date: May 2009
![]() Feedback Score: 20 reviews
although the dude i called said he could use my old driveshaft and so long as i bring him one of the same diameter he could do it for 180... but its still easier and probably cheaper to just buy one lol just a neat idea |
#42 |
My power plans over the next 2-3 years will probably range between 250-300. Would you guys say its worth the extra money for the aluminum? or will I be just the same with the steel? Would people also agree that the steel breaks the tires easier? Thanks for your suggestions and feedback.
#43 |
im guessing you have an s13? if not heres one for sale...http://zilvia.net/f/sale-items/39351...i-exhaust.html
#44 |
![]() Join Date: Jun 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Sorry to bump up an old thread, but here's my scenario.
I've spoken to 2 guys who autox their ae86 corollas. They DO NOT drift. The subject of 1-piece driveshafts came up and they both said that the 1-piece is hard to balance. So they are sticking with the factory 2-piece setups. Keep in mind, they have live rear axles, so the driveshaft moves up/down with the axle. Now, I autox my car -- I DO NOT drift. I need to get my trans rebuild, and would like to get a 1-piece DS as well. But I'm worried about vibrations. How many here have had to get their 1-piece DS rebalanced out of the box. I'm looking at the steel DriveShaft Shop 1 piece. My car: Stock sohc KA 5MT J30 lsd Any info would be greatly appreciated.
71, 72 Celicas; 85 AE88 hatch; 89 S13 hatch; 20 86TRD |
#45 | |
![]() Join Date: Nov 2011
![]() Feedback Score: 13 reviews
I was also worried about vibrations but I feel the one piece is a lot smoother than the stock 2piece. I now have the 1piece steel DS with DriftFreaq's solid mounts and a SPEC stage 3 clutch and I don't have any vibrations. Though I know the "diff ear" bushings on my J30 diff are gone. I know ShaftMasters can rebalance the DS free of charge, you just have to pay for shipping in which case it would be cheaper to find a local spot that can do it for you. |
#46 |
I have a DSS Steel 1 piece also, I got it so I could get rid of the steady bearing.
I don't drift very often, mostly just a once in a while corner. r200 diff with Cusco 2 way and 4.08 stock SR trans RPS street clutch Nismo motor and trans mounts I don't feel any vibrations from the drive line idling or driving around. I say get it, the quality is very nice and overall a good buy IMO
Two-Tone owner#011509-Lightly Modded ![]() |
#47 |
Just installed shaft masters 1 piece aluminum shaft.
I have a s14 w/ kaaz 2way and bout 265whp sr20 I think it made it a lot snappier. 0 vibration or noises. Broke tires loose a bit easier. Haven't drifted it yet, You do have to trim the rubber collar on end of transmission Shaft masters is a worthy upgrade It makes no sense that a steel shaft would break tires loose easier than aluminum. IT'S just common sense.... |
#48 |
Trader Rating: (50)
![]() Feedback Score: 50 reviews
just throwing my recent experience on this matter. I just picked up a used 1pc steel no name from another member on here. My first impression was visually the 1pc i picked up was about 1/2" shorter than my OEM non-abs 5 spd DS. It was a concern but i installed it anyways. Its been in for about 2 months now and there is some additional sound on decel in gear and lots more in decel in neutral. It seem to help the entire RPM range but more so in the low to mid range.
I do question the noise i am hearing and wonder if it needs a speed balance. I did check for any type of play from the u-joints and did not feel any. Anyways, mods i have are: Stock Ka24E with Grounding Kit, Intake, Headers, 2.5" resonated test pipe to 2/5" HKS HiPower exhaust, and ASP Aluminum crank pulley.
FS: DSS 1pc Steel Non ABS, 6bolt axles WTB: Boost Gauge, Hatch Roof Wing Last edited by tapdeznutz; 07-16-2013 at 12:31 PM.. |
#49 |
![]() Join Date: Jun 2007
^^Pop it out, flip it 180* and bolt it back up... Sounds crazy but it's worth a shot... DSS puts this on their website- sometimes it works; and as Cody Ace said, sometimes it doesn't. Aside from that, you may have to have it balanced.
I noticed the noisiness with my DSS aluminum... Not a single bit of extra revving, pickup etc. In my case, I am building for power & have systematically refurbished the entire underbody; and additionally, going to the 1-piece merely eliminated a potential point of failure (carrier bearing) from the equation. I wouldn't call it an 'investment' if you aren't building the car to handle the amount of torque these things are designed to be able to take. I beat the living shit out of my 350+hp 180SX week after week- never had a single issue with the 2-piece.
#50 |
I had to have a u-joint replaced and have my DSS 1-piece rebalanced after a few thousand miles of use. I called them and explained the situation just as Cody did and got the same reply. However, I asked for reembursment of the cost of rebalance, obviously that didn't get me anywhere. I'm sorry, I'm not sending back the shaft to have them do something a local shop can do in minimal downtime.
I generally have my shaft rebalanced every time it is out of my car just for peace of mind. I know I know, it doesn't need to be, but I think of the shaft expanding and contracting with temperature changes(which in Fl winters can be quite drastic) and not always being bolted up(I.e. laying around on uneven surfaces or not propped up vertically). I now have a Mazworx driveshaft with my VG trans, which for all I know could've come from DSS.
#51 |
Trader Rating: (50)
thanks for feedback JR_SS and Mikester. I will give the 180 thing a shot and report back. What does a rebalance run anyways?
I mainly wanted to go with the lighter DS for MPG. Was hoping it would give me like at least 0.5MPG or so, call me stupid but that was my reason. Same for when i did my aluminum crank pulley, it gave me +1mpg maybe more if i just do Hwy driving only but with my current mixed driving of 50% stop and go LA traffic and 50% when traffic opens up, etc. I did know it freed up the revs a bit. I guess on a NA car every 1hp or so goes along ways ![]()
FS: DSS 1pc Steel Non ABS, 6bolt axles WTB: Boost Gauge, Hatch Roof Wing |
#52 |
Depending on the shop between $75 and $125 atleast down here.
#53 | |
Trader Rating: (50)
Update
#54 |
![]() Feedback Score: 10 reviews
This is common sense. Alum!!! period. Factory cars come with Alum now and even carbon Fiber..
Your making how much power? 300hp 500hp 1200hp, How about Promod cars that make 2500hp? Wonder if theirs is Alum? YES ![]() Alum isnt the question here, Its how big DIA. the Shaft is. Anything over 600hp go with a 4" Dia. It all comes down to "do they know how to fab a shaft properly" |
#56 |
Had an enjuku ally drives haft a couple 240s ago. Was a ridiculously good improvement and will be a purchase on my new knew as well. Coupled with a fidanza flywheel and the whole set of unorthodox underdrive pulleys that they used to make was just awesome. It did have quite a lot more driveline noise afterwards but who cares.
Sent from my SPH-L720 using Tapatalk 4 Beta
1996 SE |
