01-10-2013, 09:59 PM | #31 |
Will a DET pump swap over? That would be your best bet.
I'm not sure how fast the added stress on the clutch fan would wear out the VE pump, if at all. I'm sure there is a limit to what the pump can handle. You would be adding rotating mass out away from the bearings causing a higher side loading.
01-11-2013, 07:57 AM | #32 |
Man w/ CTSV & a Car Seat
I'd give it a shot. I mean, it wouldnt bo so hard to replace it if it does go bad. Figured, as long as the fan is balance and doesnt have a whole lot of harmonics on the pump, it shouldnt affect it too much.
01-21-2013, 06:23 PM | #33 |
Found this thread:
waterpump issues : CA18DE / CA18DET Forum Granted, they are old CA18 pumps, but I think I will go with electric fans just to be safe. Also, I obtained an OEM S15 SR20DE exhaust manifold and discovered that it fits onto the VE head directly, without needing to have the holes slotted. So the OEM S15 turbo manifold will probably fit directly as well. |
06-13-2013, 06:00 PM | #34 |
Bump.
The 20V single solenoid bolts onto the P11/SR16VE head, and apparently clears the firewall in an RWD configuration. Not sure if when using the head on a DE(T) block one would still need the oil feed line, but if not, it would eliminate the need for relocating the twin solenoids. The single solenoid can only switch both cams at the same time, but most people seem to configure their twin solenoids to do the same anyway. If one obtains the P12/X-Trail motor, they are all set. P11/16VE solenoids. 20V. |
06-13-2013, 07:20 PM | #35 |
I still think it would be extremely tight on the S14 chassis based on my observation with my motorset. Good to actually see the mounting plate surface though, seems to be almost identical with the P11's.
I'm convinced there is more space behind the motor in the S13 than there is in the S14
06-13-2013, 07:47 PM | #36 | |
However, the seam on the firewall may need to be cut/bent, judging by the picture of the S13 above. I am not too keen on doing that, so I will try using lower motor mounts. From looking at pictures online it seems that S14's actually have the seam much higher, which must definitely be nice for the VE swap. |
06-13-2013, 07:49 PM | #37 |
That's just it, the P12 CAS would not work on my car/motorset. It hit the bulkhead and intruded by a good inch towards the center where it bulges out.
06-13-2013, 08:01 PM | #38 |
I don't think the S13 or S14 pinch/seam is bigger on either car, just on the S14 the bulkhead bulges out towards the engine bay more than the flat S13 bulkhead.
06-13-2013, 08:18 PM | #39 |
That is interesting indeed. Others seem to be able to get away with the P12 CAS. I wonder why it is not fitting in your car. The only things causing it could be the motor mounts and cross member, though I do not see why they would.
And I think the S14 seam is actually bigger, but it appears to sit higher, at least from what I can tell. |
06-13-2013, 08:41 PM | #40 |
Perhaps it's my setup, Nismo mounts with Mazworx Z32 crossmember/transmission, but it's not different than an Sr transmission and crossmember distance wise...
06-13-2013, 11:16 PM | #41 |
If you want more room with the firewall ! My tuner did this set-up on is race car and now does it to every ve swap or almost !
If im not mistaken : U need the stock distributor (for parts...he weld the parts that goes into the cam to the epm) and a aem epm for honda (need a little griding to have the bolt to fit on the ve head) ! Here are pics
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 Last edited by rbs14kouki; 06-13-2013 at 11:48 PM.. |
06-13-2013, 11:30 PM | #42 |
I personaly went with the mazworx hallsensor ! If i would of waited abit more i would of chose Taarks hallsensor that way i would of saved machining my head to fit te sensor !
On my engine i also have the mazworx conversion kit but o didnt like the way the line were going behind de shock tower so i did custom lines to hide it Here are pics of my set-up
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
06-22-2013, 04:26 PM | #43 |
Matej, can you measure the 20V solenoid block from the back of the head to the furthest point out? I'd like to go measure mine and see what the available room is. Not that I plan on swapping them out, I like the idea of switching both cams and different rpm ranges.
07-02-2013, 12:57 PM | #44 |
Would love to, when I obtain one.
More silly discoveries: There is no need to mod the RWD oil pickup or buy the Mazworx one. Just buy a 370Z/G37 oil pickup. It bolts right on, has the correct diameter, sits in the proper place in the oil pan, and costs 20-30$ new. The late model 350Z/G35 (with the newer oil pan) uses the same pickup as well, just do not use the early model one because it is bad. |
07-04-2013, 07:25 PM | #45 |
Do you have pictures of said 370z setup installed?
07-06-2013, 09:30 PM | #47 |
Waiting on my oil pan baffle and strainer gasket to come in. I do not like putting parts on until I have everything necessary.
The VQ37 pickup is basically the same style as the VE, except the slit is oriented for an RWD configuration, and it sits lower. Last edited by Matej; 07-06-2013 at 10:25 PM.. |
08-09-2013, 05:28 PM | #48 |
The 370Z/G37 strainer did not work out after all. It is a few millimeters too tall and/or a few degrees off. It could be mended by cutting and welding it, but my goal was to find an OEM pickup that would fit without needing to be modded.
There are a couple of others I will be test-fitting. Nearly every Nissan V6 and V8 uses the same oil pickup tube diamater and flange bolt pattern, so I have been trying to find ones that look as if they could work. It would be neat if someone mass-produced a 'cup' similar to this that could fit the distributor. Preferably with the end removable from the inside, thus allowing access to the distributor from under the dash. Maybe I will use a cooking pot or something, or just drive with a hole in the firewall. Also installed a crank scraper. |
08-16-2013, 11:46 PM | #50 |
To keep up with the title of the thread, here is a set of VVL 'killer' cams.
This car is powered by a VE with similar cams. It currently holds the Bonneville land speed record in the 2.0L and under production class. This car is powered by an SR15VET and also holds some sort of a class record at Bonneville. Cool! |
08-17-2013, 08:44 AM | #51 |
The S13 has a class record at 165.5mph. There is a full article on Motoiq about that car.
Edit- the NX sounds cool and all, but if you plan on driving your car on public roads, I'd consider that a nightmare. No low-end and did you hear how long he had to slip that clutch to get it moving? Now, I understand he probably has a long gear in there for top-end runs, but it doesn't sound like it would be fun at all.
08-17-2013, 09:32 AM | #52 | ||
Regarding the 20V solenoid on the P11 head, there is a small issue with the placement of the oil return slot, which is moved over a bit. P11. P12. Here is how someone on the internet solved it. However, this fellow who seems to know quite a bit about the magical VVL process claims that it is alright to block the oil return off completely. Interesting. Quote:
08-18-2013, 09:03 PM | #53 |
Thank you for updating the title, whoever is responsible.
Came across a blog about the old Scorch S14. I did not know it had an NA VE. シルビアNA|スコーãƒä½ œæ¥*日記 |
08-28-2013, 05:32 PM | #55 |
One thing I'm curious about is compression numbers. I have yet to find any solid information as to what a VE head swap and DET bottom end should yield. I'm assuming it should be in the 170-180ish range, but that is a best guess scenario. However, I have seen some claims that people are in the 210-220ish range with the DE bottomend on a VE head swap. Anyone have solid numbers they'd like to share? I know what my sitting for 3yrs motor has cold, but I'd like something to compare it too.
08-28-2013, 07:09 PM | #57 |
I'm not talking about static compression. I'm speaking specially about actual compression.
08-28-2013, 07:34 PM | #58 |
Yellow, yes I got the timing kit, water neck setup, and timing relocation all for $450 usd shipped. I wanted their oil blocks because they look better than Mazworx and they come with fittings, but got tired of trying to sell my Mazworx setup with all the typical lowballers on this site and their eBay dreams.
08-28-2013, 07:35 PM | #59 |
My stock VE motor pulled 210, When I built it with SR16VE pistons the numbers were even higher and I had huge Franklin stage 4's in them. I hit around 280psi. I think your guess will be right on the money.
08-28-2013, 07:35 PM | #60 | |
