Old 08-17-2013, 01:39 PM   #691
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
Use shorter grade 10 bolts or add a few washers
spooled240 is offline   Reply With Quote
Old 08-17-2013, 02:08 PM   #692
joefresh
joefresh's Avatar
joefresh is a splendid one to beholdjoefresh is a splendid one to beholdjoefresh is a splendid one to beholdjoefresh is a splendid one to beholdjoefresh is a splendid one to beholdjoefresh is a splendid one to beholdjoefresh is a splendid one to beholdjoefresh is a splendid one to beholdjoefresh is a splendid one to beholdjoefresh is a splendid one to beholdjoefresh is a splendid one to behold
Thanks spooled, thats what i was thinking just wanted to make sure im not being a total dunce
joefresh is offline   Reply With Quote
Old 08-17-2013, 05:41 PM   #693
billyblaze
billyblaze is a well-known jackass
I breezed thru this thread I read a lot. And learned a lot
I have the 300xx brakes up front and stock out back
My question is that is their. Any rim fitment issues?
Wanna make sure if I do this (hire someone expert I'm not)
To clear the rims I have I would suck to do the swap and I can't
Put my rims back on
billyblaze is offline   Reply With Quote
Old 08-17-2013, 09:19 PM   #694
joefresh
joefresh's Avatar
depends on the wheel/face design. stock evo/sti have 17s but designed to clear the calipers. my 18x10-1 needed a 20mm spacer to clear the brembos. my 17x10+12 clear no problem
Old 08-18-2013, 11:23 AM   #695
spooled240
spooled240's Avatar
Yeah I usually search the wheels in evo forums o get some insight on bbk clearance
Old 08-18-2013, 12:09 PM   #696
billyblaze
Forgot what size wheels/offset I have on my mb battles
Like the brembo gold thou seen a set all 4 for about $1400
I might wait to do this after my car in done and painted thou
Old 08-19-2013, 12:43 PM   #697
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
R33 Gts-t Calipers powder coated gold with painted letters. Stainless steel lines, e-brake with r33 cables , and 17/16 BMC. Was gonna do the brembo's but i got a super deal that i just couldn't pass up on these. These things have more than enough stopping power anyway. Plus, lets be real, I only wanted brembos for the bling factor. I have no shame in saying that lol. Next upgrade will be to use 350z track rotors up front because sourcing rotors for these things is a pain in the ass.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
Old 08-19-2013, 04:49 PM   #698
billyblaze
This is where I am at
EVO 8/9 or x brembos
I cant all four corners for under 1k local
From what I read EVO has 5x100 and 5x114 rotors
I like the dba 4000
Will this work?
And besides Touge factory (not sure if they have it cause site was down yesterday)
Who else sells a kit for this?
Kit can be rotors bracket and to just brackets
The less shopping around the better.
Saving money now to do this swap after my body kit purchase
Old 08-19-2013, 04:51 PM   #699
billyblaze
Revat619 what was the color code you used for the gold
Thanks in advance
Old 08-19-2013, 04:54 PM   #700
spooled240
spooled240's Avatar
evo 8/9 has 5x114.3 and the same hub diameter as our s-chassis.
the front evo calipers can be found cheap, especially if you get them in not so good condition to rebuild and paint/powdercoat them. It's the rear STi brembos that will run you some dough..
Old 08-19-2013, 05:21 PM   #701
revat619
Retired General
revat619's Avatar
Thanks in advance
Honestly man, I'm not sure what the color code was. I got them done by Auto Fashion USA if you want to contact them directly. It was one of 3 or 4 golds they had. They had a bunch of mini fire extinguisher bottles powder coated in their full line of colors and i just pointed to it and i was like " that gold looks cool. use that one" Lol. It's not the exact brembo gold since brembo uses paint and these are powder coated, but it's pretty darn close IMO. The other golds they had weren't even close, so if you contact them, i'm sure they'll know what you're talking about. You can tell them it's the same color they did for Jay's red s14 kouki. Hope that helps!
Besides getting my r33s for a steal, this was a big part of what turned me off of the brembos. Those small ass rear calipers were considerably more expensive than the fronts and they're smaller than Z32/R33 rears. At the end of the day, I just couldn't justify it...even though every bit of my ricer being still wants them.
www.Jspec.com
Old 08-19-2013, 05:59 PM   #702
spooled240
spooled240's Avatar
I have what you could call a fetish for oversized brakes so I couldn't resist lol
As for the brembo gold, it was a bitch trying to find the right color to match the STi rears but I don't think they turned out too bad from 10 ft away. I ended up using VHT gold engine enable with clear
please excuse the played out wheels -__-
Old 08-19-2013, 06:11 PM   #703
billyblaze
So your saying the sti. Rears are bigger in the back
So the correct set up should be EVO 8/9 or x in the front and sti in the back ??????
I like the gold the set of 4, egos I'm eyeing are read but that won't be for long
Old 08-19-2013, 06:11 PM   #704
revat619
Retired General
revat619's Avatar
......God those look good...
Yeeeeeeah, i'm proooooobably gonna pull the trigger on a set at some point.
www.Jspec.com
Old 08-19-2013, 06:39 PM   #705
joefresh
joefresh's Avatar
Yes you want evo fronts and sti rears. I dont think the evo rears will work at all. I have dba4000 rotors with my evo calipers no problems with them..
Old 08-19-2013, 09:57 PM   #706
billyblaze
So the sti calipers in the back
Z32 and e-brake assembly
Or different rotors and or e-brake
Old 08-19-2013, 10:02 PM   #707
revat619
Retired General
revat619's Avatar
Yes sir. Z32 rear rotors and e-brake assembly with the sti rear calipers and you're set.
www.Jspec.com
Old 08-19-2013, 10:16 PM   #708
spooled240
spooled240's Avatar
Thumbs up
The stopping power is surprisingly a lot better than the z32's.
Old 08-20-2013, 10:31 AM   #709
billyblaze
Thanks now to start saving and getting parts
Old 08-20-2013, 11:19 AM   #710
spooled240
spooled240's Avatar
another reason to go with evo calipers is that they the leading and trailing pistons would be used correctly on the s-chassis knuckles. This is for better brake modulation and prevents a more "twitchy" braking feel if I remember correctly. I know of guys running STi calipers w/out any issues, but this is something to think about.
Old 08-20-2013, 01:37 PM   #711
billyblaze
But as someone stated the evo don't work in the back
I'm thinking brembo all four corners can't be bad either EVO or sti
Old 08-20-2013, 01:47 PM   #712
billyblaze
Why not sti all around
Will the evo braket work with the sti front?
Just wondering
Old 08-20-2013, 02:46 PM   #713
spooled240
spooled240's Avatar
i meant the front.
Idk about the brackets, they seem to be specific to Evo or STi even though they are both F50 calipers
Old 08-20-2013, 03:15 PM   #714
billyblaze
Dumb question I can find the. Z32 e brake cables fine
But does someone sell this as a complete kit minus the calipers
I want everything to work with sti rears
Prefer a complete kit
Thanks in advance
Old 08-20-2013, 05:40 PM   #715
revat619
Retired General
revat619's Avatar
yeah usually you can find the whole e-brake assembly minus calipers pretty easily. The parts are used so you just have to scan the classifieds and even ebay sometimes. Buy the whole e-brake assembly, get new z32 rear rotors or if they're included and they're in good shape, resurface them, then buy your sti rear calipers. Done and done.
www.Jspec.com
Old 08-20-2013, 06:13 PM   #716
billyblaze
Another noob question
The evo 8/9 and EVO x calipers the same?
Just checking to be sure the rotors and bracket works on both
Dba 4000 is what I am leaning towards for the front
Not sure about the back rotors I will be a long time before I can get those
Old 08-21-2013, 06:11 PM   #717
billyblaze
Just seen on eBay zfever of. Tampa selling a bracket for $370
But get this its for the 8-piston caliper e55 amg
The rotors are a whooping 15"
I. Messaged what a turn key set was and wheel fitment
Issues
Old 08-21-2013, 07:01 PM   #718
billyblaze
$2250
Complete
New bracket
New 15" rotor
New pads (4 for each caliper)
New brake lines
Used calipers
I replied back what rims will fit
Old 08-21-2013, 07:16 PM   #719
florante rea
florante rea's Avatar
Trader Rating: (43)
florante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of light
Feedback Score: 43 reviews
Send a message via AIM to florante rea Send a message via Yahoo to florante rea
My new setup, evox rotors with sti fronts WITH my brackets.
fdrea
florante rea is offline   Reply With Quote
Old 10-02-2013, 12:36 AM   #720
TrunkStyle
TrunkStyle is an unknown quantity at this point
I've been looking at this thread for way to long. holy shit.
TrunkStyle is offline   Reply With Quote
