#31 | |
![]() Join Date: Oct 2012
#32 |
I just went out and spent way too long probing my ecu and cleaning connections. i reset my ecu via screw and took it for a drive. No codes for now. I'm sure they'll be back but its running alot better atm. When I get my consult port I'll update again. I think this thread should be archived for future reference.
#33 |
Danger Dorn, the vacuum should read at least a minimum of 18 inhg with stock cams, if its around 21 inhg then its very healthy at idle. Look for diagrams on how to correctly hook up vacuum lines on a boosted SR20. Also do not T anything off the FPR vacuum line.
#34 |
I haven't t'd anything...I have my FPR on the right nipple, Boost gauge on the left nipple, bottom one is plugged, pcv is good, brake booster good. My wastegate (hks 12 psi internal) is plumbed into my hot pipe securely. The only thing in question might be where the oil catch T's there is a microfilter on the part facing you. Like "Filter -Valve cover T- Catch can" but from what I understand this is either done where you put a filter on it or you put a line back into your intake which I may do tomorrow. I cant think of anything else that can be killing my vac leak other than rings/lands but this motor only has 2.5k miles on it with new rings
#35 | |
So is my vac actually good? |
#36 | |
If you have a digital boost gauge that shows readings ONLY in psi (digital l.e.d. display with 2 or 3 digit capability) then your fine (-8 psi (in the sense that it ONLY displays readings in PSI ) is 16 inhg) @ idle/vacuum then you dont have a leak more than likely. (Keep in mind there are digital boost gauges that are programmed to read like the first gauge i described above. It always helps to know what type of gauge your using and how exaclty it performs) Have you done a compression test of all 4 cylinders? Shouldn't be bad after a rebuild but you never know. If your pcv is in the valve cover but has some play when moving it around or you can pull it out of the valve cover with literally no force try this: Pull the pcv T off the valve cover. Clean the exposed port on the T, and the opening where it is inserted in the valve cover.. Take a small layer of electrical tape and wrap the exposed T port once, maybe twice at the max. Dont block the pcv lines or port opening in anyway. Your car has to have a pcv system. Now with a bit of force push the pcv valve port (wrapped in tape) back into the valve cover. Its ok if the tape sort of slides back a little but you should notice a stiffer difference than when you first pulled it out. It should slide back in with small force and the tape acts as a seal between the port going into the valve cover, and the actual valve cover opening itself. If thats what fixes your vacuum leak then you know and will now have to seal it the right way asap (that tape won't last long). A rubber sleeve or a bit of shrink wrap over the end would probably hold longer. Thats what I ended up doing to fix my vacuum leak. Better seal means better vacuum. Hope that helps. Also just double checking. You said your catch can setup includes an atmospheric vent? : Oil drain back into engine block ---- pcv T ----- catch can ----- intake boot nipple () #########################Valve cover########################## THIS IS MY CATCH CAN WITH PCV ROUTING. ITS WORKED FOR ME FLAWLESSLY If I remember correctly on turbocharged vehicles you CANNOT vent pcv to atmosphere like you can on a Naturally Aspirated engine. NOT TRYING TO FLOOD YOU WITH INFORMATION, BUT HERE IS A WAY TO HUNT FOR VACUUM LEAKS : you can develop vacuum leaks from small things really. A can of ether is your best friend in a way. Go along spraying it where a vacuum leak could occur (intake manifold gasket, throttle body, bov, intercooler, intercooler piping, all your clamps, etc) Only if nothing else seems to of worked and the compression test passed. If you have a vacuum leak whenever you spray that ether on the vacuum leak you should get a noticeable change in idle. E.G: engine is idleing, normal temps, you spray the intake manifold where it meets the cylinder head by intake runner number 2 with a mist of ether, you notice your idle kicks up for a couple seconds then goes back. If this spot affects your idle from the ether being sucked into the system you have found your vacuum leak, which in this hypothetical case could be a loose manifold or bad intake gasket. This is an all out if everything has failed. Ether is extremely flamible and dousing your engine in it isn't a bright idea but in easy moderation it can help you find your leak. If you didn't know ether is basicly starting fluid. Also don't spray in a way that will suck ether thru your maf. They tend to not like it Last edited by Diehardsr20; 09-22-2013 at 01:57 AM.. |
#41 |
My email posted your reply but here is says "in edit in edit". The copper piece in my hot pipe is my wastegate line. Its sealed well. i charged my system to 18 psi last night and had zero leaks.
#42 |
![]() Join Date: Sep 2005
I have never seen a system that doesn't leak! I can only imagine you did the test correctly.
But.... how long did the system hold 18psi. Oh and is that just intercooler piping. Or intake manifold and everything connected. Because I have people say, they have no leaks and come to find out they do, but I tend to point out, you'll have a pressure drop at the intercooler about 1-2psi and that's considered good. That's 20psi at about 30secs then at a minute 18psi. just intecooler piping. The entire system never holds more than 10-11 after a minute. Please tell me that electrical tape isn't covering up a hole?-j/k but serious. What's the deal with the 2 fpr? I have a setup sorta not really like that, but I drilled out the old oem fpr from a ka, fuel flows straight through it. But your is connected with a vacuum line otherwise a working unit connected to an adjustable unit. If you care to explain why? I'd like to hear it. Also it looks like the fuel feed line is connected wrong, going into the fpr. pictures are not really clear enough to say for sure, just enough to question. edit: fuel feed looks okay
LoverTechnologies "Half Broken Things!" Last edited by cotbu; 09-22-2013 at 11:55 AM.. |
#43 |
Ok Picture 1 and Picture 2 here show how I have my pcv system with my oil catch can. It's setup as follows :
Oil drain back into engine block ---- pcv T ----- catch can ----- intake boot nipple () #########################Valve cover########################## In picture 3 you can see my vacuum diagram from my Throttle body which is essentially how yours is setup. FPR to the left top nipple. BOV, WASTEGATE (I don't have a hotpipe nipple yet, but you do so your even better), and boost gauge are off the top right nipple. You have your bottom nipple capped. I still have my canister hooked up. either way will work Picture 4 is where I ended up finding my initial vacuum leak. You see it was just not a tight enough fit between the port end and the valve cover itself. tape tightened the tolerance and made a better fit/seal. I'm still working on an actual piece to work. DO NOT keep the tape there for long. Electrical tape doesn't do well with heat. This was just to get it down the road. Sorry about the edit post earlier i was posting with my phone and it glitched on me so I had to do this post with my laptop. EDIT EDIT EDIT 1. I don't know why it inverted the pics. I just looked and they were normal on my phone. windows is refusing to let me rotate the original imagine so your going to have to strain a little bit. ^^^^ He's right by the way no system is entirely perfect leak free! EDIT Hold on finally got them to orient right. reattaching photos 2. See the scorched marks on the side of my cylinder head/valve cover? That's from the previous owner running a pcv setup like you have. He was playing with the car and oil made it into the filter and soaked down to the header. BOOM! big fire. wasn't very pretty. Left me with quite a few things to fix when I bought the car from him. Last edited by Diehardsr20; 09-22-2013 at 11:44 AM.. Reason: PIC EXPLAIN |
#44 |
@ Cotbu I had it hooked to an air compressor so i didn'ot really see how fast it lost pressure. The only sound I heard was coming from the valve cover T since blow by is going to happen. Would I be better off running a line from the T to my intake pipe since that's how stock is?
The electrical tape is not a hole. My hood hits there and vibrates so that take helps. My fuel lines are in fact correct. The 2 fpr's work this this. you have your stock one at 43 psi. I took the return line and plumbed it into my adjustable which currently is at 43 psi also. If I want I can turn it up to say...50. So now my oem FPR is just basically an adapter. It works just fine I have been driving on it for a few months. It works just fine. I tested my manifold too via opening the throttle body. Solid w/o leaks. The only other air I heard was passing into the head. Did I miss anything lol |
#46 | |||||
AKA your leak free test. Quote:
Guys we've done made all the stupid mistakes for you already, you should only have to pick a paint color and a wheel size. <--that's me joking after explaining. ![]()
#47 | |
![]() Join Date: Nov 2010
Cotbu is right about the leaks. You should not have anything coming out of the valve cover. Your PVC valve on the Intake side is probably shot.
And get that double fpr out of there. It could be making your fuel system all weird and respond differently. I have a flow thru adapter and it looks much different. Quote:
#49 |
Have you done it? Have you ever seen it done? No ass. It works fine. It runs the same as stock except you have the abilty to increase your fuel pressure with the backup of the oem one. I have two because I though the stock one died so I bought the afpr. It didnt change anything and the adaptor sucked so I put the stock fpr back on and decided to keep both.
Cotbu: Thanks for the tips, I have my consult port coming in today or tomorrow. I had codes 12,13, and 34. MAF, CTS, and KS. Deleted them and they havent come back so now its running better but still lean at idle. I'll be installing the line from my valve cover T to intake this weekend. |
#50 | |
#52 |
![]() Join Date: Jun 2007
Without being rude like those guys, I would recommend like whoever it was above said and just hollow out the OEM if you're going to keep the adjustable. An extra FPR in the system is not so much a backup as it is an additional point of potential failure. The tee in the system adds additional points of potential failure as well. When it comes to regulating fuel pressure, the KISS concept is the way to go.
Just my thoughts.
#53 |
Thanks Mike I will be reverting to stock fpr as long as my fpr is good. If not i will drill it out and use my afpr. I'll be doing my catch can line to my intake this weekend. Also my consult port just came in but I didnt realize my computer doesnt have the correct port so I need to shop around and try to find an adapter. I'll update what happens when I change a few things this weekend.
#54 | |
#55 |
Also the ecu talk should show codes. Get conzult too its kinda nice and has some different features.. such as timing mode and codes are easier to read i think
#57 |
Bought mine on eBay. It was a little fussy the first time I got it hooked up it wouldn't connect. But after some fiddling with the com ports I got it to connect.
#58 |
Just ordered an adapter cable but now I have a new problem lol. I just cant win
![]() New problem is my clutch or my flywheel bolts came loose so I'll be doing that this weekend. The motor is running very well. I have to drive 20 miles to work on the high way and it pulls well with AFR's just about perfect. I still have 2 fpr's but I did re route my valve cover t to my intake and I feel more safe from fire now. But I guess this clutch thing will be fun. Good thing I have a place nearby I can rent a lift since my jack isnt big enough. |
#59 |
I never thread sealed them so I guess its my own fault. I try to shift into any gear from neutral and it doesnt let my or it grinds. Also I hear a fair amount of noise when pressing or releasing as if the flywheel is touching the cluch all the time. Awesome
#60 |
So all my bolts were tight. It was my throw out bearing. Replaced it and now its good. Also I used 2 quarts lucas 80w90 and a half bottle of the oil stabilizer...works magic.
I have my consult with ecutalk and a conversion cable and cant get it to connect so I am working with the company to find out why. That's awesome. I replaced the microfilter on the valve cover T with a line going to my intake...much better. Still running the 2 fuel pressure regulators. Still running Great. Also found out that my gauge is in fact measuring -8/-9 PSI. It has a switch on back to switch my reading to bar and it reads -.5/-.6 which in turn is equivalent to -16/-18 In.HG. BAM BITCH ![]() My car is now running awesome and now my only issue is my front cover leaks under heavy load. Sounds like a job for oil resistant rtv. Last edited by Danger_Dorn; 10-08-2013 at 10:04 AM.. |
