Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
12-23-2013, 12:55 PM | #151 |
I also want to point out that you can indeed drift a civic but it's not cheap. How? Well first off that whole rip the ebrake shit is stupid. That's power sliding not drifting. Anywho to drift a civic you need a 4wd crv motor and drivetrain, custom fab it into the chassis because civics weren't designed to have rear axles and shit (duh!) remove the front axles of the drivetrain
Brace the rear a bit and your good to go. Some guy in Japan did this and honestly it's a true head turner to see a civic get mad sideways. I had to replay the video like 7 times! Haha |
12-23-2013, 12:57 PM | #152 | |
Sent from my SCH-I535 using Tapatalk
'91 s13 (Drift Rocket Under Construction) 2000 civic Si Coupe (Daily) |
12-23-2013, 01:21 PM | #154 | |
Might even leave the front wheel drive in too, rally the fuck out of it. Sent from my SCH-I535 using Tapatalk
12-23-2013, 03:39 PM | #155 |
i am a honda guy and have been there done that with the whole crv rear subframe in a civic and i can tell you now that you will not be drifting in ANY civic with a crv awd setup.
It utilizes a FWD trans with a small output shaft that drives the rear wheels. Without major modification this system acts as a traction control rather than a 4wd syatem you guys are thinking about. the cv shafts in the rear are smaller than your pinkie finger and break with anything over 210whp. And TBH, 200whp is not enough power to drift with using the said set up. The whole 4wd/awd civic idea is trash so yeaaahhh. If there was a way to utilize a RWD set-up that incorporates a fwd output the drive the front wheels would be ideal, but a cr-v setup will not get you sideways in a honda.
95 S14 se RB25DET 348whp |
12-23-2013, 03:42 PM | #156 |
Also would like to add:
The oem awd trans does not Provide ANY torque to the rear wheels UNTIL a front wheel spins. And when it does send power to the rear it is less than 25% so at that time you would get maybe 70% to the front wheels and at max 30% hp the rear and thats guessing high numbers for the rear.
12-23-2013, 04:05 PM | #157 | |
12-23-2013, 04:41 PM | #158 | |
Sent from my SGH-T989 using Tapatalk 2 |
