Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Motorsports and Skilled Driving
Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver.
Old 12-23-2013, 12:55 PM   #151
240boi115
240boi115's Avatar
240boi115 is an unknown quantity at this point
I also want to point out that you can indeed drift a civic but it's not cheap. How? Well first off that whole rip the ebrake shit is stupid. That's power sliding not drifting. Anywho to drift a civic you need a 4wd crv motor and drivetrain, custom fab it into the chassis because civics weren't designed to have rear axles and shit (duh!) remove the front axles of the drivetrain
Brace the rear a bit and your good to go. Some guy in Japan did this and honestly it's a true head turner to see a civic get mad sideways. I had to replay the video like 7 times! Haha
Originally Posted by 13esim View Post
I'll trade you my 300ZX and my older sister
my 240 broke down..again
240boi115 is offline
Old 12-23-2013, 12:57 PM   #152
Livid_240sx
Livid_240sx's Avatar
Livid_240sx is an unknown quantity at this point
I've seen sr swapped civics, s2000 engines swapped in too. Might try this with my EM1 after college.
Sent from my SCH-I535 using Tapatalk
'91 s13 (Drift Rocket Under Construction)
2000 civic Si Coupe (Daily)
Livid_240sx is offline
Old 12-23-2013, 12:58 PM   #153
240boi115
240boi115's Avatar
They are sick swaps but if you don't have moola it's not something I suggest going half ass on.
Old 12-23-2013, 01:21 PM   #154
Livid_240sx
I'd do it myself, take my time.
Might even leave the front wheel drive in too, rally the fuck out of it.
Old 12-23-2013, 03:39 PM   #155
sleepyS14se
sleepyS14se's Avatar
sleepyS14se is an unknown quantity at this point
i am a honda guy and have been there done that with the whole crv rear subframe in a civic and i can tell you now that you will not be drifting in ANY civic with a crv awd setup.
It utilizes a FWD trans with a small output shaft that drives the rear wheels. Without major modification this system acts as a traction control rather than a 4wd syatem you guys are thinking about.
the cv shafts in the rear are smaller than your pinkie finger and break with anything over 210whp. And TBH, 200whp is not enough power to drift with using the said set up.
The whole 4wd/awd civic idea is trash so yeaaahhh. If there was a way to utilize a RWD set-up that incorporates a fwd output the drive the front wheels would be ideal, but a cr-v setup will not get you sideways in a honda.
95 S14 se RB25DET 348whp
sleepyS14se is offline
Old 12-23-2013, 03:42 PM   #156
sleepyS14se
Also would like to add:
The oem awd trans does not Provide ANY torque to the rear wheels UNTIL a front wheel spins. And when it does send power to the rear it is less than 25% so at that time you would get maybe 70% to the front wheels and at max 30% hp the rear and thats guessing high numbers for the rear.
Old 12-23-2013, 04:05 PM   #157
Livid_240sx
Well aren't you a buzzkill.... lol jk.I knew about the passive AWD, but didn't know about the thin drive shaft. Good info.
Old 12-23-2013, 04:41 PM   #158
VegasDrifterS13
VegasDrifterS13 is an unknown quantity at this point
These guys I know in St. George, Utah Built a CRX with an EVO 8 4G63 AWD Setup. At 13psi bone stock everything except downpipe/straightpipe & FMIC It laid down 326hp / 306ft. Lbs. It was setup 30/70% F/R. That little Muthafugga was fast. Cornerweighted to a nice 55/45 ratio at 17xxLbs caged and all. It drifted ok, but was a monster on an autoX track or drag strip.
Sent from my SGH-T989 using Tapatalk 2
VegasDrifterS13 is offline
Old 04-14-2014, 03:59 PM   #159
DenkiMan!
DenkiMan!'s Avatar
DenkiMan! is an unknown quantity at this point
a couple overnight parts from Japan and boom
http://www.youtube.com/watch?v=NgS93jelnzo
Originally Posted by PSI240SX View Post
Although the 97 Maxima was aesthetical perfection, I thought the factory body lines could use some expert "tweaking" so I ran it into a couple of things at low speed.
Looking for another pair of 17x9 Veilside Andrew Racing V's
DenkiMan! is offline
Old 04-14-2014, 04:01 PM   #160
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
How this thread wasnt locked after 2 posts is beyond me... and now its been dug up from the dead!
ugh, LOCKED!!!
dorkidori_s13 is online now
